Question about Toshiba 36A40 36" TV
Toshiba 32 in. model cf32c50
I have an excellent picture but I have no sound I have tried the speaker buttons and also hooked up external speakers and still no sound can you tell me which part u think it may be that i need to replace
  • 129 Answers
Good day.
Please check if your internal speakers are busted. Trying out the external speakers are good isolation to the problem thats why, you can pinpoint the problem to be in the audio section.
Posted on Mar 23, 2008
No sound coming from internal speakers Toshiba Projection television Model 50h82.
Some TVs have a set up option to disconnect internal speakers when an external audio amplifier will be used.
Dec 29, 2016 | Samsung Audio Players & Recorders
Heard a loud pop noise on Toshiba TP48D90 tv.Now no sound
Its not worth it. the parts cost alone will exceed the value of the Tv. you can buy a new 50" TV for $500 or less. Time to put it out to pasture.
Jun 01, 2015 | Toshiba Televison & Video
I have a Toshiba tv model cf32c50 I have no sound I checked external speaker jacks and still no sound when I push volume button it appears on the screen and shows the volume increasing and still no sound.
check circuit board for contamination. looks like white powder. if there is, clean with alcohol let dry. before plug set backin. if you can't fix you can use a stereo to get your sound thur.just hook up your cable box or what ever through the audio video jacks on box to audio in aux. jacks on the back of srereo
Oct 02, 2013 | Toshiba Televison & Video
Toshiba 36a43 i have picture but no sound. Volume control works but again still no sound.
Things to check:
In menu are speakers (audio area) switched on or off?
If you put sound all the way up and listen right at speaker what if anything do you hear?
If using a cable or sat box is sound turned down on it?
Is sound muted on set or the box (if used)
Do you have sound with a DVD etc hooked via the rear jacks?
A few sets have a slide switch on the rear= internal or external speakers--is it set to internal?
failing all of the above you have a audio circuit problem
Mar 26, 2012 | Toshiba 36A43 36" TV
I have a toshiba m100 and i want to connect it to my tv i have a hdmi output on my tv i am getting a picture but no sound what do i do
You will have a connect a cable from your laptop headphone jack to your audio in on your TV. This is a common problem. They sell a cable that goes from headphone jack to RCA jack size. You could also just add powered external speakers to your laptop and get excellent sound that way. I have a $20 pair of external Labtec speakers and they sound great watching a movie on TV.
Mar 06, 2011 | Toshiba Satellite M100-S5211TD (4400 mAh)
Toshiba tv, model cf32c50 has a garbled sound issue.
distorted sound sometimes accompanied by buzzing is caused by detuned circuit in the SIF amplifier and sound detector circuit. a distorted sound alone is caused by a breakdown in AF amplifier circuit so try to change the sound ic since its the only options left. good luck!
Jul 27, 2010 | Toshiba Televison & Video
I have a 1994 Toshiba Television. It was working perfectly until I moved it. I can't get the volume on. PLEASE help. I've tried everything, I think. Joyce S.Model # CF32C50.
I usually do not give a one line suggestion but if you lost sound after moving it--look on the back to see if there is a slide switch--some models have this to select if internal or external speakers are being used.
It may have got moved when the set was moved. A few also have it on the front of the set.
If not this, the circuit board inside either got damaged or the speaker leads dislodged.
let me know what you find.
If this helped, rate this solution as I do this here for free.
Regards, SD TECH
Dec 18, 2009 | Televison & Video
Red light blinking no picture no sound
tart checking the cable connection to receiver, try moving or replacing cables.
If you have a surround with external speakers check surround connection cable and speakers wiring.
If the cables are OK, then the unit may be faulty.
In that case the fault can be either the audio board (often audio circuit is integrated on the main board) , or the sinput output signal board.
Also a contact on connection to internal speakers can give you same problem.
May 22, 2009 | Toshiba 32A43 32" TV
I am no pro but I hooked speakers up by using the ourputs at the back. You have to plug into a reciever or amplifier though first. You cannot just hook external speakers up mwhich is what I believe you are doing...
Jan 19, 2009 | Toshiba 32D46 32" TV
Toshiba 36A40 36" TV Logo
165 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
