Question about Apple Computers & Internet
My dvd is stuck in the CD Rom Drive thing
I out it in and now it doesnt cone back out is there ANYTHING at all that i can do to get it out myself
  • 212 Answers
If the computer is powered off and the power chord deconnected, you can use a fine pin to 'poke' in the small hole in the front panel of the CD/DVD drive. this is the backup mechanism for when the regular opening mechanism fails. this way you can retrieve the disk that's blocked inside. after this you can try if it works as before again, but the possibility exists that you will have to replace the whole drive...
Posted on Jun 22, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 102 Answers
Yes search for the emergency eject hole its usually near the eject button us a needle and push it firmly in it bingo its opened
Benq DE350/De325 dvd player has a cd stuck and no matter what we have tried can not release it to open up and retrieve the stuck cd
I think I can help you. Before you do anything turn your computer all the way off. All you need is a small paper clip. Open the paper clip up so its a straight peice of wire. Now look at the face of your DVD Rom you should see a pin hole opening about the size that paper clip will fit in to. Push the paper clip in to that hole. Push firmly and your tray should pop open enough for you to pull it out the rest of the way.Now take out the stuck CD and start your computer back up the drawer should pull back in if it doesnt give it a slight shove and it will. After that you should be able to use your player again.
I hope this helps you out if it does please give me a YES on the page you recieved this response on. Thank you.
Apr 08, 2011 | BenQ 1648A 16x Internal IDE DVD-ROM Drive...
My pc doesnt detect my HL-DT-ST-DVD-RAM-GSA-H55N LG super multi dvd/cd-rom, i tried checking ide cables but still it doesnt read, i cant even see the dvd/cd-rom on device manager------there is no...
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Oct 31, 2010 | LG GSA-H55N DVD-RAM Burner
I have an Acer Veritron and CD/DVD stuck. I looked for the tiny hole on the front of the CD drive and there is none. I attempted to go to my computer and right click drive and it is hanging.
I fyou know how to, try and remove the cd/dvd drive itself from the tower. check if there is anything stuck, and gently press the cd/ dvd drive in opposite directions. also check the cable thats powering the drive. reseat it properly.
Apr 03, 2010 | Acer (91.49C37.001) CD-ROM Drive
This drive reads a dvd but not cds. do you have
may be it's only a DVD ROM drive not a combo,
you will need a combo to read both DVD and CD
if it was reading CDs earlier then the CDs might have scratch in them, try with new CD.
did u make changes to the cables inside, if you did check if the cabels are connected properly to the drive
Dec 06, 2009 | Sony DDU1613 16X DVD-ROM Drive, Black...
I have an hp 511w that displays the message file missing or corrupted. WINDOWSSYSTEM32CONFIGSYSTEM that is the last screen i can access. anything i try to do (like push f8 or f1) doesnt work. i cannot...
The first thing I would do is remove the cables connected to the back of the CD burner and try booting it once again. BE SURE TO TURN YOUR SYSTEM OFF FIRST!!!
If it boots up, then replace your burner. It could be a dozen other things, but this is where I'd start and I've been repairing systems for 30 years. Good luck!!
Nov 11, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My cd-rom drive keeps on opnening and closing?can you help me? i remove the IDE cable but it still opens and close...TNX
Dude CD ROM's are designed to close all by themselves in case if there is anything stuck in between,just unplug the CD Rom,and u might find a small hole,kindly punch in it using a pin so that the front portion of cd rom will open and clean up the entire drive using a soft brush(b careful about lens present inside)and fix it back and check out whether it works out
Nov 10, 2009 | LG CED 8120B CD-RW Burner
CD ROM DRIVE/DVD ROM DRIVE PROBLEM!
it is infecetd by viruses.. scan for viruses..
please vote for me...im sure this will solve your problem...
Sep 14, 2009 | Computers & Internet
DVD drive stopped working!!
If you have only dvd rom then it is the problem of your dvd rom drive then you want to buy a dvd ram i mean dvd writer it can read and write dvd
Jun 28, 2009 | Acer (91.AB264.016) Internal 24x CD-ROM...
Dvd rom
Try to check the IDE connector and power supply of the DVD. also check the jumper setting of your DVD whether its slave or master. good luck!
Jun 17, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
CDRW/DVD Rom combo drive only reads CD's
the blue you are refering to is the dye on the disc, sometimes it's purple, normally the darker the better, but it's down to the individual writer and what disc it is compatable with, but your writers problem is all too common, as in my opionion the lasers that are being fitted in writers are of poorer quality than in the earlier days to enable the prices to become lower. You can try one thing, but it doesnt always work; go to my computer>right click>hardware tab>device manager, then down list to cd/dvd drives and click '+' sign and highlight your writer, right click on it and select uninstall. Restart PC and it will be automatically re installed, try again and if no change you will need to replace the drive as they are cheaper nowadays
Jun 20, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Computers & Internet Logo
180 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
