Question about Neff 24 in. S5456 Built-in Dishwasher
Wash cycle doesn't end
Water heats up OK and wash cycle works OK but doesn't end and therefore machine doesn't drain or enter dry cycle. Water can be drained by ending program and starting any other program, all of which begin by pumping out the dishwasher. No fault lights or codes appear
  • 883 Answers
SOURCE: Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
Posted on May 26, 2007
hotuna
  • 288 Answers
SOURCE: Water not running
All these sound the same, the water inlet line is plugged with deposits from the water, especially is this is an older machine and the quality is poor. take off the front panel and remove the water supply line under the machine where it attaches to the solenoid. Be sure to turn the water off first. The solenoid inlet housing will have a screen similar to the one on the end of your faucet. If this is plugged with calcium or other deposits, it will cause these type of problems.
Posted on Dec 27, 2007
  • 1314 Answers
SOURCE: frigidaire dishwasher ultaquiet , model=FDB750RCC1
the first thing that your dishwasher does when you turn it on is drain when you turn it on you hear a motor running then it stops then it fills start the washer when it stops to start filling open the door should be no water in the unit if there is you have a drain problem and in fact are washing your dishes in dirty water can be several things that can cause drain problems a piece of food blocking the line at the sink where the drain goes in if its run to a disposer there is a knockout plug that should be removed just stick your finger in there to see if it was removed get you installation instructions and read the part about not removing the drain loop but just about all the time installers will lol if you cant find the instructions go to www.frigidaire.com under customer support can down load them there let me know what you find
Posted on Jan 17, 2008
SOURCE: NEFF S5456 DISHWASHER
Have you tried it on a different program? I have nearly always used the AUTO program - however i have used the 50 degree program 3 times now and it completes the (much longer) wash without sticking on one minute. Will try it on auto again to see what happens. I found it useful to turn the end-of-wash buzzer on (to loud) to remind me when (if) it completes the program.
Posted on Feb 29, 2008
mosesclive
  • 191 Answers
SOURCE: Indesit DI620UK Dishwasher fault
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Posted on Jul 19, 2008
WON'T END WASH CYCLE/KEEPS ON RUNNUNG..IS THERE A CODE FOR THIS
If you cannot cancel the cycle then turn power off and back on.
Then try to program a short cycle from panel and see if it works.
I am assuming when you say that it keeps running you mean the water keeps churning and does not drain out.
If short cycle works ok then the dishwasher is not heating water to the correct temperature. Need to check thermostat or heater.
Apr 22, 2014 | Kenmore Dishwashers
Stays in wash cycle
The timer circuit on the panel needs to be replaced. It is not going through all of the cycles!
Jan 22, 2013 | Washing Machines
My wmd 1050 front loader won't continue with its cycle. It fills, does a few turns, empties and finishes., all in a few minutes. It doesn't seem to wash but will spin dry when manually put on a spin dry...
Are you sure the machine is not overfilling? next step after filling would be water heating - sounds like a water heating problem if machine spins and drains ok. Maybe a coin in the wash has punctured the element? water heater can be test for insulation / continuity if you have a high voltage tester, or remove it and examine if not by releasing the nut and pulling firmly. If it is scaled, holed or black replacement will be needed. Sometimes socks or clothing stuck on the heater cause localised overheating that will make it fail.
Dec 16, 2017 | Electrolux Washing Machines
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E33
switch 1
--- Cycle blocked
(door open) 8.32
(door open) 8.33
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Whirpool 1100TXP Dishwasher.
is your water temp set at 120 degrees
Apr 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Dryer heats but no condensing of steam
The cold water feeds for condenser cooling and for wash cycle drum fill are controlled by separate solenoid valves (manifolded together at the cold water inlet hose union). When the solenoid on my condenser coolant valve failed a couple of years back, I got symptoms like yours. A new pair of valves isn't expensive to buy and is a trivial job to fit. If this is what has been happening, suggest you also inspect the insides of your dryer fan and of the pump - neither of mine took really kindly to having been cooked for hours on end. Alastair.
Oct 16, 2006 | Candy DQW150 Front Load Washer / Dryer
Neff 24 in. S5456 Built-in Dishwasher Logo
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
