Home | Microsoft | Visual Basic 6.0 (361-00686) for PC | Getting permission den...
Microsoft Visual Basic 6.0  for PC
Problem for Microsoft Visual Basic 6.0 (361-00686) for PC
Getting permission denied error with Kill
By tejashree_lo on Jun 22, 2009
Hi ,
I am writing a log file handling program. I am using the ''Kernal32'' function lopen and lclose for calculating the size of file .
I am zipping file and want to delete a old log file but when i am deleting the file with
Kill ''C:demo_logfilelog estlog.log'' I am getting permission denied error.
Please Help me !!!!
Comments:
Jun 22, 2009
- Yes I did..
Public Function GetLogFileSize(FilePath As String) As Double
Dim Pointer As Long
Dim sizeofFile As Long
Pointer = lOpen(FilePath, OF_READ) 'size of the file
sizeofFile = GetFileSize(Pointer, lpFSHigh)
GetLogFileSize = sizeofFile '& " bytes" 'lclose Pointer
End Function
this is the function which I am using to calaulate the size of file...
Jun 22, 2009
- Yes i did...
Jun 22, 2009
- it is read only..
but when I clear the check box of read only, next time its again becoming read only(without running program also)
its not allowing me to remove the read-only permission.
I have system administrator rights
Jun 22, 2009
- Its not allowing me to remove read-only permission
Jun 22, 2009
- "Use simple file sharing" was already unchecked ....
Jun 22, 2009
- I am using VB 6.0
I have to write script for deleting the file , I cant delete it manually ....
Is there any other way to delete a file except Kill..
Jun 23, 2009
Jun 23, 2009
- Hiiii,
I have another problem..
I want to create a folder in registry and read and write from the registry using VB 60
Please Help!!!!!!!!!
Jun 23, 2009
- Hiiii,
Jun 23, 2009
- Thanx a lot :)
Actually i hav to pass source file path and destination file path to registry(In some folder) and want to read those paths from the registry...
Jun 24, 2009
- Hiii
What is mnuMRU?
I want to create a folder in registry and save source and destination file path..
I have tried below but its not working
SaveSetting App.Title, "HKEY_CURRENT_USER\MyTestKey", "Testlog", "C:\demo_logfile\Testlog"
GetSetting App.Title, "HKEY_CURRENT_USER\MyTestKey", "Testlog", "C:\demo_logfile\Testlog"
I have to write a script so I am not using Dialog box, i have to directly get the source and destination file path from registry..
PLs Pls Help me ..its being long time I am doing this ....
Pls provide solution ....
Jun 24, 2009
- Thanks a lot :):)
I will try this.
Jun 29, 2009
- Hiii Again ,
How can I have the VB 6.0 program wait until a shell command is finished????
I am writing a function to zip a file and just below that I have written KILL command to delete the originol file. but its not waiting for the zip to finish and it is deleting the log file which i have to zip .
Plzzzzz provide the solution
Jun 29, 2009
- Can i use some API to know wether Zip file is created or not ???
PLzzzzzz help me its very URGENT
Jun 30, 2009
- Hii..
My PM told me to find some WinZip API and want me to get something return when the file is zipped..I searched but i didnt find any API related to WinZip which perform the Zip..
Plz reply.
how can i directly mail u ??
Jun 30, 2009
- Thanks a lot :)
It was really helpful .
instead of replying to the same mail how can i ask something directly to u ?
Best Solution
posted on Jun 22, 2009
Helpful)
LASITHA-VEGA
Rank: Wiz  Microsoft Expert
Rating: 83%, 100 votes
did u close the opened handle? after calculation?
Comments:
Jun 22, 2009
- check whether the file is accessed by some part of ur program. if not go to the file and check properties to verify whether its read only or go to security tab and check whether u hv permission
Jun 22, 2009
- welll that's fine. Its an obvious thing :) have you tried to delete the file manually? Do it and see.
If you don't have security tab in properties, get my computer and then go to Tools->Folder Options->view->Remove the tick for "Use simple file sharing(the very last option)"
Then go to that tab and check whether your account is there with full permissions
Jun 22, 2009
- Open the file with full permission and then do your work. (if the handles are closed using Cose() on the stream objects...Don't open the file as read only.
Try to delete the log file manually. Where did u create the file? Read only attribute is sometimes set to protect files. Its a normal thing. Specially for log files. You can create the file without the attribute using FileAttributes.Normal. But its fine to make it as read only coz its a log file.
. I think you are using this namespace already
System.IO.FileAttributes
I still think that there is a process which still locks your file.
Jun 22, 2009
- u need a script
ok
Go to this link
Thanks
I m in a hurry that's y I got late to reply you
Please rate the answer
Jun 23, 2009
- ah that's easy I ll post it
Jun 23, 2009
- Saving Values In The Windows Registry
SaveSetting appname, section, key, setting
Here are the arguments for SaveSetting:
• appname—String containing the name of the application to which the setting
applies.
• section—String containing the name of the section where the key setting
should be saved.
• key—String containing the name of the key setting being saved.
• setting—Expression containing the value to set the key to.
Getting Values From The Windows Registry
GetSetting( appname, section, key[, default])
Here are the arguments passed to this function:
• appname—String containing the name of the application or project whose key
setting is requested.
• section—String containing the name of the section where the key setting is
found.
• key—String containing the name of the key setting to return.
• default—Expression containing the value to return if no value is
Getting All Registry Settings
You can use the GetAllSettings to get a list of key settings and their values from a section
in the Windows Registry. Here’s how you use GetAllSettings:
GetAllSettings( appname, section)
Here are the arguments for GetAllSettings:
• appname—String containing the name of the application whose key settings you
want.
• section—String containing the name of the section whose key settings you want.
Deleting A Registry Setting
You can delete Registry settings with the DeleteSetting statement:
DeleteSetting appname, section[, key]
Sample
Private Sub mnuOpen_Click()
With dlgCommonDialog
.DialogTitle = "Open"
.CancelError = False
.Filter = "All Files (*.*)[vbar]*.*"
.ShowOpen
If Len(.FileName) = 0 Then
Exit Sub
End If
If GetSetting(App.Title, "Settings", "Doc1") = "" Then
Load mnuMRU(1)
End If
mnuMRU(1).Caption = .FileName
mnuMRU(1).Visible = True
SaveSetting App.Title, "Settings", "Doc1", .FileName
End With
End Sub
Jun 24, 2009
- Go here and see this will helpful to u
Good Luck
Jun 24, 2009
- You are most welcome
Its a pleasure to help you
Jun 29, 2009
- i see. ok I ll post
Jun 30, 2009
- I haven't used Winzip with VB projects but go here and have a look. There is working code at the bottom. I have used ZLIB once, go and check here also. Its easy to use. You can easily integrate those .dll s.
If you want to wait until the Compression ends, you have to use a different function implementation which returns a value, to check whether the is finished.
Hope this would help.
Jun 30, 2009
- I have found some very important API functions. You can do anything from these. I mean you can't write to here and there in the registry as u wish in vb without calling APIs. So here we go.
Go here and check.
And from here.
Enjoy.
Jun 30, 2009
- :) I can't publicly give you the connection details, coz its prohibited na? For service providers its not allowed. Aap ko perm hain. Hum ko nahin :D . I know some hindi;)
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Microsoft Visual Basic 6.0
Questions and Unsolved Problems for Microsoft Visual Basic 6.0
Do you recommend Microsoft Visual Basic 6.0 (361-00686) for PC?
Answer
Answer
purchased new lap top with windows 7 and came free trial of microsoft office, as prev purchased this... (More)
Answer
I have purchased a Dell desk top computer at a auction and there is an administrative password on... (More)
Answer
can i get a copy of MYSQL..my e-mail is kelvinngabo@yahoo.com.. am 16yrs and have created sites but... (More)
Answer
I have an hp 2840 Laserjet and when scanned it scans 5-6 pages and stops every time ? Can you help... (More)
Answer
Geforce 6100/m2 v2.0 -cant find the video card instaler,i refornated the pc,the video card is... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Visual Basic 6.0 ...:
Top Programming Tool Experts
Rank: Guru Guru
Solutions: 482
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Programming Tool Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
