Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
Can't get my lawn boy started
I have a lawn boy mower with electric mower to start. I have replace the spark plug and the stop cable. The battery is fine and I checked the ignition module and works as it should.
  • earnhardt821 Jun 23, 2009
    All the mower wants to do is crank over. I don't know where the fuel filter might be on this mower. I'm thinking it might be a fuel issue.
    Sergeant:
    Champion:
  • 208 Answers
Check for a faulty wire to the engine kill switch it may be contacting the ground
Posted on Jun 22, 2009
  • jrnbudd Jun 23, 2009
    good luck
Lawn boy lawn mower no spark
If your spark plug is good, check the safety switch connected to the cable leading from the safety lever. Most of these operate with simple principle where the handle is moved into the safe or running position ...thereby moving the cable to cause a separation of the contacts and a resulting " breaking of the electrical ground". These switches are cheaply made and often wear out or can become mis-adjusted due to wear from constant use and vibration. You may have to remove the top cover on the engine to access it.
Sep 07, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
How to test a Lawn Boy ignition coil
you will need a spark test about 10 to 15 dollars hook the tester to it on the plug try to start it watch to see if it sparks the other way is to do without spark tester is to pull the plug out and lay it on engine block try to start it and watch to see if plug sparks
Aug 07, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Why will Ariens lawn mower starter engine not turn over?
These machines have carb and coil issues. Check for fire. Nice when new, but once a little age creeps in, the engines just aren't that sturdy. Sorry, but as a small equipment mechanic, I don't recommend Lawn Boy. Next time, buy another brand.
May 30, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
Have Lawnboy Kohler 149cc smart choke 6.5ft lbs engine bought last year won't start doesn't seem to be firing?
REMOVE THE SPARK PLUG, RECONNECT THE CABLE AND WHILE THE SPARK PLUG IS RESTING ON THE BLOC OPERATE THE STARTING PROCEDURE AND SEE IF THE PLUG IS SPARKING.
May 09, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
I changed oil, blade, spark plug,air filter on tecumseh lawn boy 10685 mower...now it will not start!!! gas tank was emptied, per instructions. before changes, it started right up on first pull before...
Hi
Make sure the blade and shaft can easily be moved by hand. First, remove the spark plug wire from the plug. Reach under the mower and see if the blade will turn or if something is stuck between the blade and the mower. Also remember that you have to hold the safety bar when you are starting the mower or the engine won't turn. It is possible that the cable from the safety bar to the engine brake has come loose. Follow the cable from the safety bar to the engine and make sure it is working.Also check whether the line from the gas tank to the engine is crimped?
Also check this link to troubleshoot your problem:-
http://www.ehow.com/how_7363405_troubleshooting-push-mowers.html
Aug 04, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
2 cycle lawn-boy self propelled 6.5 hp Gold Pro Won't start
If you replaced the plug and still dont have any spark you probably need a new coil. If you do it yourself and find the coil on Ebay or a good onliine parts seller you could do it for a reasonable price.
Jul 14, 2010 | Garden
Lawn boy 2 cycle mower won't start
Replace the spark plug and retry.
If a new plug does not work push the spring button on the bottom of the carburetor to make sure fresh fuel is in the fuel bowl.
if this does not work remove the spark plug and squirt some light oil (like wd 40) right into the spark plug hole; roll the engine over slowly a couple times using the starter rope. put the plug back in and snap the plug wire in place. If the mower now starts after a couple pulls it means the rings are worn, replace the rings.
May 29, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
What is the spark plug gap setting for a LAWN BOY DURA FORCE engine 2-cycle 6.5HP?
from what I have seen so far the gap is .30 for all manual start 2 cycle and 4 cycle and .35 for electric start
Mar 11, 2010 | RTO Lawn Boy 6.75hp Mower
Engine will not start, no spark
Try taking of the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs that are really close to the fly wheel. Use fine sand paper or emery cloth. Then check the spark plug wire for rust (clean if any). Try replacing the spark plug if it is old.
Let me know if this helps.
roundo4
Aug 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Stalling
I have same mower and just fixed what seems like a similar problem description. I had gone down the fuel system route and the symptoms just didn't add up. Stopped abruptly w/o sputtering once I reached warm-up temp. Replaced the solid state ignition (34443C now part number 3444D). Problem corrected and just mowed my 1/3rd acre w/ no issues.
May 11, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
759 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
