Question about Dell Dimension 8300 PC Desktop
Dell Demenision 8300 PC
Can not boot from CD ROM, hers what I've what I've done so far.
1. F2 to get to bios
2. Scrolled to Boot
3. Scrolled down till arrow is on CD ROM
Other than that, can not get CD ROM to move to boot priority, can someone help, please
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 102 Answers
Do your bios update
Posted on Jun 22, 2009
My little sisters dell inspiron mini just got the Unmountable boot volume message. I've looked online but most of the options require a cd which is of course not helpful when the mini doesn't have...
The best option is, look around for external cd-rom with usb connection, and reformat the laptop.You need to go into the bios and change the boot order to make your usb cd-rom to first in the boot list. Once the usb cd-rom is plugged into used port, with operation system cd in it, on your laptop..press F2..go into the bios, to the boot order make your usb cd-rom on top boot list,,then save changes to exit the bios. Once again the system reboots..with message PRESS ANY KEY TO BOOT FROM CD ROM.. so just simple steps to follow..its not going to be expensive..good luck
Sep 17, 2011 | Dell Inspiron Mini 10 Notebook
How to make CD Rom run as BOOT? please key in
Go into the BIOS and change the boot startup device order. Make the CD the first boot device and the hard disk the second boot device.
If you do not wish to change the BIOS you may select the CD drive as an alternate boot device by pressing F10 or F!2 as the laptop boots up to bring up a list of devices to want to boot from, select the CD drive and the follow the screen prompt.
Aug 29, 2011 | Dell Inspiron 1525 Notebook
I tried to install windows 7 on my HP Pavillion DV9, but it's not booting from CD-ROM, i tried using a USB CD-ROM, but it's still not booting. pls I need assistance.
Try to check if the windows 7 disc that you are using is not just an upgrade disc. Make sure that it is a bootable disc. Try to use other bootable disc to test. Also make sure that the boot device priority is set CD/DVD drive.
Hope this helps.
Jun 06, 2011 | Computers & Internet
Dell Dimension 8200 PC Desktop Cd rom not reading disk
optical drive troubleshooting is pretty straight forward, fist see if you can boot to the drive using a bootable CD like the Windows CD or your Dell Resource CD, use the F12 1 time boot menu test it.
Also see if the drive is detected by model in the BIOS (F2 at boot) if not seen, reseat both power and data cables, boot to BIOS F2, turn on CAP LOCK SCROLL LOCK, NUMLOCK, then press ALT+E then ALT+F then ALT+B, this resets bios defaults and forces hardware re-detection. If you have no floppy diskette drive, you'll need to turn that back off in the BIOS before the ALT+B
If all that is done and the drive isn't seen/cannot boot to with bootable media, swap the data cable with the HDD and try a different power connection.
If Drive still not connected, replaced the drive.
If drive is detected and IDd then try this
http://www.fixya.com/support/r6169039-cd_dvd_drive_disappears_in_windows
Jan 28, 2011 | Dell Dimension 8200 PC Desktop
Stop c00002la fatal system error, when I hit F8 and try to start with last known good configuration, still get error, can't fix it?
Run The Recovery Console
1.Boot from CD or DVD (change boot order from BIOS F1,F2, or Delete key/ save changes on BIOS ) then Reboot to BOOT fron CD
2.Choose R to Run Recovery Console
3.Enter 1
4. Enter your Admin Password
5.Type: chkdsk -r
6. Done
Nov 16, 2010 | Dell Dimension 2400 PC Desktop
I have a dell dimension 3000 desktop. I removed a cd rom drive and replaced it with a audigy sound blaster front panel drive. when I boot my PC it says primary drive not found, press F1 to continue, Press...
Your computer is configured to recognize specific devices in your computer. If you removed the CDROM drive, you need to tell your computer that it's gone, and that you're aware of it. That message is kind of like a "Hey, there's something missing from your computer... did you know about this?"
You should boot your computer up and get into the BIOS. When your computer turns on, you'll see a message in the corner that says something like "Press F2 for BIOS" or something like that. Get into the BIOS menu using this option. When you get into the BIOS, you'll need to find the sub-menu called "IDE Devices" or something referring to IDE drives. You should see two IDE channels, with two possible devices per channel. You should see the entry where your CDROM drive used to be - change this option to "Disabled" and then save your settings and reboot the computer. The message should go away. Good luck!
Mar 08, 2010 | Dell Dimension 3000 PC Desktop
DELL Demension 8300 PC, cannot boot from cd rom
try ubuntu which is a good version of linux,search on google..Now if you really want to install another o/s then you need to change BIOS setting to boot from cd first on start up screen.For most pcs it;s normally a delete or F2 button but hace a look at boot up it will say something like press del or F2 to change...
Jun 22, 2009 | Computers & Internet
Dell demension 8300 pc
make sure boot sequence is cd-rom first and possibly disable hd
Jun 22, 2009 | Dell Dimension 8300 PC Desktop
Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
May 28, 2009 | Dell Dimension 8300 PC Desktop
Dell Dimension 8300 PC Desktop Logo
134 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
