Question about Panasonic Viera TH-42PX80U Plasma TV
TV will not switch on after sudden power loss
2 year old Panasonic plasma TH42PX600B currently being used in rental accomodation and running off single mains plug with sky, DVD player + VCR. Sudden power loss and blank screen.
Would not switch on with no power light. Tried to change 5amp fuse in plug for 13 amp and red power light flashes on + off but TV will not switch on. Any solutions please?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
PSU FAULT BAD CAPS
Posted on Sep 28, 2017
james klgr
  • 362 Answers
SOURCE: Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Posted on Dec 24, 2007
micromaster
  • 3614 Answers
SOURCE: panasonic TH-42PX60B
have you already service the main unit, or you an initial check on the parts of the TV..
kindly post back the TV model/maker..
Thank you
Posted on May 18, 2008
jerryg50
  • 1689 Answers
SOURCE: Panasonic Plasma TV blank screen
One of the circuit boards, possibly including the power supply has a critical failure. The power supply is in the protect mode. This type of set is serviced by board swapping, and then doing the necessary adjustments to match the new boards as required.
It would be best to call the factory authorized service for a quotation.
If the set is out of warranty you may find it fairly expensvie to service.
Jerry G.
Posted on Jun 30, 2009
  • 108 Answers
SOURCE: I have the same problem Panasonic Plasma TV wont come.
Alot of times capacitors on the power supply circuit board will go bad. They will bulge/dome or dry up which will cause this problem. Bad caps dont hold a charge, which is needed to maintain a voltage. The circuit board is two sided which makes replacing the caps difficult, and the board can be damaged and have to be replaced. Taking it to a repair shop may be cheeper and safer then doing it yourself. Having two-six caps replaced is a lot cheeper then a new board.
Posted on Aug 15, 2009
  • 100 Answers
SOURCE: i have a 46 inc panasonic plasma tv. when i try to
turn tv on and leave it on for a while. A light will flash for a couple seconds count the blinks and let me know they use a blink code to narrow down which board may be faulty.
Posted on Apr 26, 2010
How do I fix the problem with my TV? Details are below.
Normally on the Panasonic tv this will call for a service call. The key to getting it repaired correctly is to check for a certified Samsung repair shop because most of the parts come from Samsung. Now if you want to do your own research call to 800 number for Panasonic Tv see if there are any problems with that model that the manufacturer has extended but does not post. I had one repaired that the red light on also so I understand and it went out approximately 4 3/4 years. If your in the Atlanta area use Norman electronics they have repaired hundreds on tvs for me due to my work.
Mar 05, 2016 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
I have a 1 1/2 year old Panasonic TC-P42U1 plasma tv. While watching a show, it suddenly shut off and won't come back on. What do you think caused this and how can i fix it? Thanks.
Try unplugging it completely for 30 seconds to 1 minute. Plug it back in. If it still won't come on, it's likely taken a power surge and popped a fuse or power supply, which means a trip to the service center.
Jun 18, 2011 | Panasonic TC-P42U1 42 in. Plasma HDTV
We Have a plasma 42 in panasonic tv that is less than 2 years old. It suddenly popped and now longer works Do you have any advice on how to troubleshoot?
i would contact panasonic and complain that you bought an expensive electric device that should have lasted longer than two years. You might be suprised at how accomodating they can be. Just quote consumer rights to them and dont take no for an answer
Mar 31, 2011 | Televison & Video
I have a 2 year old Samsung 50 Plasma HD TV with sound but no picture???
Please check the power supply, Z-SUSTAIN board, Y-SUSTAIN board for blown fuses, bad caps first. You can download the PLASMA TV training manual to learn about PLASMA TV by the link below.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Please post back what you find.
Jan 11, 2011 | Samsung SPN4235 42 in. Plasma HDTV
Panasonic plasma TV power indicator light keeps blinking, no picture. Does not respond to power on/off switch.
How many blinks is the LED showing? The number of blinks correspond to a service code so that technicians can better diagnose the faulty component inside.
I'm doing factual research for a potential class action lawsuit regarding these "blinking lights of death" problems that the Panasonic plasmas are showing. I'd like to hear more about your experience. It's been a while since you've posted here. Have you contacted Panasonic? If you're willing to share your story with me, please email me at kiaeger@levjen.com.
Oct 04, 2010 | Panasonic Viera TH-50PZ800U Plasma TV
Panasonic viera plasma widescreen th42px600b. Had the TV for approx 2 and half years, now a vertical line is appearing down the middle of the screen. What can I do?
you try reading voltage in b+ used multy tester.if u get votage the power supply is oky.nex reading in flyback pins you get 24 or 34 volt dc.if you get some voltage the vertical supply is good.change vertical ic.bicouse ic is weak.i hope im helping u too solb your problem.im elizer technician expert
Jul 09, 2008 | Televison & Video
No picture no sound nothing
We had a TV repairman look at our 3 year old (Oct 2004) Panasonic CT-32HXC14J FLAT SCREEN TV. It suddenly stopped working and appeared to have no power getting to it. It was a high voltage supply or transformer that was bad and has to be replaced - estimated cost is around $400. In a year we will also need to spend around $125 for a digital converter box. We went for the repair since that is still cheaper than a $1,000 plus equivalent size LCD or plasma.
Our old tube tv was still working after 15+ years. They aren't making them like they used to. Way to go Panasonic.
Nov 09, 2007 | Panasonic CT-32HXC14 32" TV
Panasonic Viera TH-42PX80U Plasma TV Logo
193 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
