First of all check its connect properly If you are using windows xp Go to device manager and check usb drivers properly installed if there showing unknown device uninstall it and unplug and plug again then scan for new hard ware if you have USB drivers install them.....
the first thing that pops up in my mind is a power problem. check if the hard disk starts making a 'spinning' noise when you plug in the power chord and turn the disk on. when you hear a ticking noise instead, it means the disk is broken. be sure it only makes the spinning noise. if it does, connect the usb-cable between the disk and the computer. if the disk is not recognised, replace the cable. if still not ok, post what you did as a comment, and please be as accurate as possible, because this problem may have several causes.
Was this helpful?
Yes
No
Popular Solutions for Buffalo Technology 250 GB Hard
I have the Samsung Toco phone which is now diplaying the message demsbl boot loader for msm6288...
(More)
I have the Samsung Toco phone which is now diplaying the message demsbl boot loader for msm6288 downloader ver 5.32, I don't seem to be able to turn the phone on, would appreciate any help.
my hdd has stopped connecting properly with my laptop, it shows up in my computer but you are unable...
(More)
my hdd has stopped connecting properly with my laptop, it shows up in my computer but you are unable to access it, chkdsk does not run either. Are there any other solutions for scanning it and working out exactly whats wrong with the drive?
I have used my Buffalo HD-HC250 external hard drive for a year with no problems. Now when I turn it...
(More)
I have used my Buffalo HD-HC250 external hard drive for a year with no problems. Now when I turn it on my computer system freezes. It wont do anything until I disconnect the hard drive or turn it off. When I turn it off my system immediately starts to work again. I downloaded a driver detective that says the driver is up to date. Any suggestions?
I have a Buffalo HD-HB250U2-WR drive and when I connect it to power and my desktop, the red and...
(More)
I have a Buffalo HD-HB250U2-WR drive and when I connect it to power and my desktop, the red and green LEDs turn on, but after 30 seconds or so the Green LED turns off and I am not able to see the drive (no error messages of any sort). Any help will be appreciate it. Jay
