Question about LG WM3431H Washer and Dryer
My LG WM3431H All-In-One Washer and Dryer won't dry
My LG WM3431H All-In-One Washer and Dryer, which I have had for a little over a year, has stopped drying the clothes. It goes through the whole drying cycle and the clothes sort of dry, but only a little. I went through all the troubleshooting suggestions in the manual--like emptying out the water thing and making sure the tubes were unobstructed---but still---we clothing! PLEASE HELP!
  • caroldryer Dec 30, 2008
    the only difference for me is: on all but "timed" drying the esitmated time will be displayed but it will only spin for 12-15mins. even on timed drying, the clothes will end up damp. the drain pump has been replaced already, but to no avail. its as if the moisture sensor is not working.
Alright - bumping an old thread but I think I have some helpful information to add. Firstly, here is a link to the service manual: http://www.espagle.org/doc/45928217/wm3431xx-service-manual-lg/ .
Second, I must warn you that I am doing this from memory (even through it was this morning).
General note: Take note of what screw goes where. There are 5-6 variations.
Steps:
1. Unplug the machine, unscrew the hot water, the colder water, and pull out the drain line from the wall (mine was just hanging into a waste water line, I assume some people have threaded connections).
2. Place the machine in a location that gives plenty of room to access the top as well as the back.
3. Remove the two screws which attach the top panel to the back. Slide the top panel towards the back of the machine, remove and place aside.
4. Remove the screws holding on the top cover/heat shield (this part should have a black tar like cover on top to protect from excessive heat). Lift the top cover and place aside.
5. Remove the screws holding on the back cover. Slide the back cover up slightly and pull the bottom of the cover out. This should free the bottom. Slide the panel downward to free the top. Place aside.
Take a look at the top of the machine, there is a large black duct that says something along the lines of "caution hot." Follow that heating duct towards the back of the machine to the circular cover (this is the fan). Now follow that downward to see the condenser duct (previously described as creamish white). This is part we are trying to detach from the rest of the machine and clean out.
In order to remove this duct from the machine we need to disconnect the heating duct/fan assembly, the small black sensor on the front of the condenser duct, the black tube connected to the condenser duct, and all of the screws holding on the duct itself.
6. Remove the screws holding the heating duct to the drum and the condenser duct. If I remember correctly, there are two at the front of the machine, three along the heating duct, and four by the condenser duct. Make sure you are removing the screws holding the entire duct to the drum/condenser and not the screws that split the duct itself.
7. Once the screws are all out, lift the heating duct/fan assembly slightly and tilt it away from the condenser duct. Place the heating duct/fan assembly on the machine with all of the remaining connections untouched.
8. On the top, front of the condenser tube there is a metal sensor attached to a rubber gromet. This needs to be removed from the condenser tube. It takes a bit of work, but it didn't seem like you could easily damage the gromet if you use a screw driver to pry it out.
9. Unattach the black tube at the top of the condenser tube by squeezing the metal clamp and pulling it away from the condenser tube. My washer had a bit of sealant/glue at the connection. I removed this with a set of pliers in order to disconnect the black tube.
10. Remove the screws holding the condenser tube to the drum. There is one on top and numerous on the back. There is one screw that is not accessible by a screw driver and requires a 5/16 socket and ratchet to remove (or some sort of angled screw driver...)
11. This should free the condenser tube. Remove it and clean out all of the lint. I used a coat hanger as well as the garden hose to get out all the lint. Also take this time to clean out any dirt you can access in the fan and the heating duct.
12. Follow these steps backwards to reattach everything, I hope you remember which screw goes where.
Its very likely I will not check back here, so good luck. I hope there arent too many mistakes in my write up!
Posted on Jun 26, 2011
  • R Starhawk
    R Starhawk Feb 14, 2014
    Great solution. Worked like a charm. One tweak I would add is that in step 9, you do not need to remove the black hose from the condenser tube. Instead, you can disconnect the opposite end of the same hose from a white connector that attaches it to other hoses. There is no glue on that connection, so it disconnects pretty easily after you squeeze and release the metal clamp.
  • Ryan W
    Ryan W Nov 07, 2015
    Excellent job describing the procedure! Every screw and connection was exactly as you said it would be and the job, while still quite a production, wasn't terribly difficult at all.
Thanks to CoolTech for pointing me in the right direction, I just finished a full clean out and diagnostics test and my dryer works once again.
This repair isn't rocket science nor is it a good idea for the mechanically timid. I managed to get the critical parts out for cleaning and back in properly with just a phillips head screwdriver and a pair of pliers for the spring type hose clamps so it's not a matter of custom tools.
You have dig pretty deep and remove an awful lot of cabinet parts, fans, heater assemblies and something like 30 or 40 various screws to get to the condensor duct and bellows to clean them. Sure enough my condensor duct was jam packed with lint. Once removed I was able to clean it with a creatively bent coat hanger, but a semi flexible bottle brush/pipe cleaner about 18 inches long and an inch or so brush diameter would be a better tool.
If you want to tackle this job, and again it sounds daunting but isn't to someone with reasonable mechanical skills you should do yourself a favor and buy a copy of the factory service manual. I got mine on line from these guys: http://www.manualuniverse.com/ but there are probably other sources including LG if you search by the model number.
In addition to some less than obvious disassembly instructions the manual tells you how to trigger the self test mode and how to interpret the results, gives you good information on cold state resistance tests you can do on relays, heater elements, sensors, etc. and provides a good troubleshooting guide for a variety of problems.
All in all the job took me about an hour and a half and was pretty straightforward except for the last mounting screw for the condensor duct which is hard to get to and requires some effort to remove and replace but again I did the whole job with a standard medium sized screwdriver so it's not impossible.
Good luck and if you're having this problem and like me you don't have any local repair folks who'll touch it (not many of these all in ones in Wyoming) then I'd get your hands on the manual and dig into it. It's not fun, but not too hard either.
-Dave
Posted on Jan 15, 2009
  • 489 Answers
You may have a problem with a clogged condensing tube and condensing bellows filled with lint.  That will require disassembly of the unit to get to them and cleaned them out.
Posted on Apr 28, 2008
Hi and thanks. after the drain pump was replaced, the areas mentioned but it is still not drying fully -better but not correctly. looks the manual will be my next step and try the diag. on the relays, elements and sensors etc.
again thank you.
Posted on Jan 18, 2009
LG WM3431H during dry cycle condensation builds on inside of machine and then underneath, cleaned all lint out already
usually do to condensation which is a result of bad venting in the blower, the tubes, the glides, and the door, and even a bad moister sensor check it with a meter for continuity and for amount of ohms but at a high temperature not room temperature
Feb 21, 2013 | LG WM3431H Washer and Dryer
LG WM3431HW is flooding the room
take the lid off
check your inlet valves are they ok
take the back panel off and check all your hoses
find out what is leaking and then i can help you to take apart further
make sure that you unplug it first though.
Feb 12, 2010 | LG WM3431H Washer and Dryer
LG Dryer not Drying clothes
well there must be some problem with the motor engine you should get it checked.
Jul 23, 2009 | LG WM3431H Washer and Dryer
I have an LG Washer and Dryer Combo #WM3431HS. It takes forever to dry. Is this a common problem?
hello. I can help you. Typically this problem is related to a partially clogged dryer vent pipe. pull the dryer out from the wall and remove the vent pipe. check every thing and remove any lint or other blockage in the rear of the dryer and in the vent. Dont forget to go outdoors and check the place where the pipe dumps the dryer air outdoors as it may be clogged there also.
Jun 15, 2009 | LG WM3431H Washer and Dryer
LG WM3431H Washer/Dryer won't start
If you are sure the unit is receiving power you can check for proper operation the door switch on unit which will kill power to unit if it is open. If it is ok, using a voltmeter you will need to trace the voltage at the control switch, etc.
Sep 01, 2017 | LG WM3431H Washer and Dryer
LG WM 3431 does not dry
Dryer / drying troubles - DIY repairs WD-12320RD / WM3431H. It was difficult to find suitable solutions so I shall share my experiences here. I live in Malaysia and purchased the LG washer-dryer model WD-12320RD TROMM (240V) in January 2006. WD-12320RD should be similar to WM3431H, just compare and verity features available at LG's Singapore website http://sg.lge.com. However, WD-12320RD model is no longer available locally. Both model's features are essentially the same since I relied on the WM3431H service manual downloaded from http://136.166.4.200/SubPages/DA_Laundry.htm for my repairs.
Fixing the machine would require relevant skills and plenty of common sense. Do this at your own risk and I am not responsible for your screw-ups.
Trouble date: January 2006
Symptoms: Damp clothes. Steam present when the door was opened and the door was also wet.
Solutions attempted: New washer-dryer drying under “Very” (More) didn’t worked. Machine was still under warranty and LG repairman was quick to respond and helpful. Diagnosed the problem to be a faulty PWB Assembly (main). Replaced PWB Assembly with a new version i.e. without “Cd” (cool down) feature. Machine worked as it should and clothes were dry even under “Cupboard” (Normal) mode.
Trouble date: March 2008
Symptoms: Similar to January 2006. Problem persisted, even after running drying cycle twice.
Solutions attempted: Dryer under “Very” (More) didn’t worked. First diagnosis, faulty Heater Assembly and Motor Assembly (Fan) located in dryer Duct (Inlet). Replaced the Thermostat Assembly, the Fan and also thoroughly cleaned the Duct Assembly (condensing). It was full of lint but no hairs, etc. Problem persisted.
Tried “Time” drying setting at 2h 30m and the drying worked a little better but the clothes were still slightly damp.
Tried Cupboard again and this time I observed the display was reduced to 10m or 6m after only ½h passed. Ran the cycle again but also used a separate kitchen timer as a reference control by setting both timers at 2h 30m. Confirmed the drying cycle ended abruptly in about 45m while the kitchen timer was still running.
Tried “Low Temp” mode and the drying cycle lasted between 3½h and 4h. During the drying cycle, time display would stay frozen at 6m when the actual time passed was more than 1h. Once completed, the clothes were dry but some steam was still present. The door was dry too.
Replaced the PWB Assembly and dryer worked again. Clothes were dry as toast.
Lessons learnt:
Symptoms: Immediately after drying cycle, damp clothes, door is wet and steam present.
Recommended action: Try all drying modes, observe behaviour compare with the above. Use a separate timer as reference to confirm drying cycle ended abruptly. During cycle also observe whirring sound to be sure that the dryer fan motor was running and the top right hand side of the machine felt warm because of the heater. Thoroughly clean the Duct Assembly (condensing).
Tips on cleaning Duct Assembly: Unplug power cord and ensure machine is cool.
Step 1 - (note: for this step, very little guidance was found in manual) remove back panel to access the rubber bellows connecting the Duct Assembly to the tub. It should be located at the lower left side. Before removing the bellows, line the base with some towels in case Duct was flooded. Wash bellows thoroughly. Remove any other lint or visible obstructions from the Duct and tub openings. Re-attach and secure bellows.
Step 2 - remove the Heater Assembly and Fan covers to expose the heating element. Scrub the entire inside walls with moist toothbrush. Extend the handle if required. Don't use sharp objects to clean the Duct. It would be easier to remove lint if the inside walls were moisten with water using a manual spray pump. Exercise extreme care and do not wet other parts of the machine. Remove the loose lint and rinse entire area carefully using cups of water and all the remaining lint would flow down the Duct into the tub and later, exit through the drain hose. If the Duct is blocked, the water may fill up the Duct. Not to worry, try removing the obstruction (likely to be lint or hair) with a suitable tool, probably a stiff rod with a blunt, L-shaped end. Finally, clean by rinsing with water and dry the covers and Fan before re-assembling all the parts. Repeat Step 1 if necessary.
Recommended solution: If symptoms persist, most likely the PWB Assembly has conked out, even if it was a new machine as in my case and it appears to be so for many users as well.
User tips for best performance: Maximum load by volume, clothes should not exceed 70% of tub. When drying efficiency is affected, cleaning maintenance is required.
extracted from http://www99.epinions.com/content_427670867588?alert_type=0&submit=Submit
please visit and leave a positive comment if your trouble was solved. tq.
Jan 29, 2008 | LG WM3431 Front Load Washer / Dryer
Washer/dryer has stop
There is no reset button but it could be that a wire has come loose from all that thumping.  Check the connectors to the control board and to the display board to make sure that they're connected properly.
Jul 01, 2006 | LG WM3431H Washer and Dryer
Open Questions:
See all LG WM3431H Washer and Dryer Questions
Washing Machines Logo
3,810 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
