Question about Toshiba Satellite A135-S2276 Notebook
Toshiba Sattelite a135-s2276 turn on fan working but no display
Previous: Get very hot on mouse pan then stuck, later it started to unrecognise usb devices and say they malfunctioned then get hot and stuck.
Now: When turned on power light is on, charging is ok, hard disc light flash once then off, i hear the grrrrrrrr grrrrrrr sound twice on cd rom, fan working well but no display.
Tried: changed ram nothing happened, tried external monitor nothing happened, checked hard disc it works properly.
what may be a solution??? Anyone solved this problem before, let me know how.
  • 34 Answers
I think some cooling devices on your laptop stopped working which might have lead to Motherboard problem due to heating.
Posted on Jun 22, 2009
I have the same problem and after checking the computer I realized that what gets hot is not the mouse pad, but the wireless card. When I turn off the wireless card the computer works OK.
Posted on Mar 07, 2010
  • 3,940 Answers
From your description of events and the current state of the system, it appears that the motherboard has failed. Replacement motherboards are available on EBay
http://shop.ebay.com/items/?_nkw=toshiba+a135+motherboard&_sacat=0&_trksid=p3286.m270.l1311&_odkw=a135-s2276+motherboard&_osacat=0
Toshiba laptop a135 s2276 has started to run hot and extremely slow operating. What could be the problems? Drives outdated,cooling fan dirty etc. Henry
the problem might be
1)you might have placed the laptop on bed or any other soft material,which block the air gaps at the cooling fan of the frame.So always place your laptop on a rigid and flat material and check there is an air gap between your laptop bottom surface and the laptop resting surface.
2)you might be using the laptop for long time.you can provide additional fans outside your laptop(NOT ATTACHED to your laptop BOARD)
Sep 15, 2013 | Toshiba Satellite A135-S2276 Notebook
My usb ports stopped recognizing my plug in's. They work for power but my wireless mouse and iPhone when plugged in won't work now.
I have a similar problem with my A135-S2286. I noted that the mouse pad area got hot, but I found it was the Wifi card. After getting hot, the computer stops recognizing USB devices and finally the computer gets stuck.
Try turning off your Wifi and please let me know if it works.
Mar 04, 2010 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 just suddenly stopped
first to do is check your charger... remove the battery then connect the charger.. if still not working.. you need to open the system check the dc connector if its okay.. now time to check the motherboard. maybe some chips bluwn or burn... shortage... this is always happens epecially those over heating the cpu fan is slow not enougth to give out the coold..
Sep 09, 2009 | Toshiba Satellite A135-S2276 Notebook
USB Device not recognized
the software driver for version 2.0 is not installed. go to microsoft updates search for 2.0 driver or just download sp3.
Aug 18, 2009 | Toshiba Satellite A135-S2276 Notebook
A135-s2276 wont switch on
Try contacting Toshiba, as it may be some sort of a harware issue with the touch pad or currupted driver, as you said it worked for two years running XP.
Good Luck.
Mar 24, 2009 | Toshiba Satellite A135-S2276 Notebook
External mouse not recognized
Go in device manager and uninstall the usb root hub one by one and then restart the machine twice then check wether it is working or not.
Jan 18, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshibba laptop a135-s2276 ,my mother bords smd chip does not work so display of screen does not appear
The problem is well known witht this model Toshiba - the problem is the fan stops working and then hence shuts down to prevent overheating - it does not take long once the laptop is hot. Without replacing the fan just reboot the laptop until you hear the fan start again on reboot.
Oct 15, 2008 | Intel Motherboard
USB PORTS DO NOT WORK
Turn off computer and try connecting an older mouse to the mouse port. If it works:
Right click Computer>click properties>click hardware>click Device Manager> click USB adapters. Then check to see if some of them are marked. Also you can click on each one to see if each is OK. Make sure that USB is enabled in the BIOS.
Jun 01, 2008 | Toshiba Satellite A135-S2276 Notebook
Touchpad
Have you tried FN+F9? on my toshiba to reactivate glide pad I have to use FN+F9
Apr 13, 2008 | Toshiba Satellite A135-S2276 Notebook
My toshiba satellite a135-s2276 won't turn on
A coworker used to work for Toshiba and said that this is common for the Satellite A135 models and under warranty the fix was a motherboard swap for a newer/updated motherboard. Otherwise the unit is unusable.
Dana
Jan 24, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
613 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
