Question about Brother Office Equipment & Supplies
My printer is a Brother HL5250DN mono laser.The Duplex mode appears to be malfunctioning. Even though the main paper tray is full whenever I try to print in duplex mode the printer indicates 'no paper'. There appears to be no blockage or traces of paer in the system anywhere. It prints normally and picks up the paper from the main tray when I print in normal single face mode. Duplex mode does however function when I place paper in the single feeder tray at the front of the printer.
  • 3,230 Answers
Sometimes if that happens it means that the rollers could not pick up the paper. Try lightly rubbing a bar of soap on the rollers. Just don't overdue it.
Good Luck!!
Thanks
Posted on Jun 22, 2009
    Sergeant:
  • 326 Answers
Checked the whole printer, and couldn't find a paper jam, yet the red printer light wouldn't shut off. I finally followed the instructions on Brother's website for removing a paper jam, and the solution for all 4 printers was paper stuck in the fuser cover. See below on how to open the fuser cover.
  • SABARI ANAND
    SABARI ANAND Jun 22, 2009
    open the back and pushed
    the little levers in to release a flipper unit near the drum. Voila,
    next to the drum was a crinkled sheet of paper. The green light is back
    on and duplex print will be working
5890cn manuals part and assembly
Go on free manuals sites , I have a few of them, and you can download manuals for virtually everything you have even things you get at goodwill.
Oct 04, 2014 | Brother Lower Paper Tray Feeder / Tray for...
FS-4020DN "Paper Jam Deplexer"
check for jamed paper above the paper tray in the duplex unit.
=remove tray
=move green lever and open duplex unit
=remove jam
Jun 27, 2014 | Kyocera FS4020DN (A4) Workgroup Mono Laser...
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
original?v=mpbl-1&px=-1
Dec 09, 2013 | Brother HL 5250DN Laser Printer
Paper tray doesn't raise on my brothers hl5250dn printer. Says papertray empty
I have had the same exact problem; make absolutely sure that the exit chute is seating properly. With the exit chute open (as if to clear a paper jam) actuate the white spring loaded clips that hold the exit chute, mine were not traveling to their full extension and by moving them a few times this resolved and the exit chute was held more firmly and the rollers spin the right direction.
Jan 30, 2011 | Brother Lower Paper Tray Feeder / Tray for...
Hello, I just bought a brother hl-5370DW and am trying to use it to print out manuals for a class of mine using the duplex print but after a few papers print the paper going back in jams and it tells me i...
I just returned my HL-5370DW printer to Staples. I only had it for 3 days and found it running hot, warping card stock and envelopes, and jamming regular size paper constantly. It appears to be OK for very small print jobs but not very robust. I did like the duplex printing and the price. I do not believe there is a solution other than replacing this printer.
Xelzbear
Aug 06, 2010 | Brother Hl5370dw High Speed Wireless Mono...
How do I have printer switch from empty paper tray 1 to the full 550 paper tray 2
Make sure the paper type and size in both trays are the same. If you are using letter size for both trays, make sure the settings in tray 1 and 2 are the same. If the settings are the same and it still fails to grab from the full tray change the engine settings in diag mode. Hope this helps but if you need more assistance, leave a comment and I'll get back to it. Thanks.
May 10, 2010 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
Hi. You need to do tray linking. When one linked tray is empty, paper feeds from the next linked tray. The size and type settings for all trays must be set from the Paper Menu. To set the paper type or size:
1. On the home screen, touch Menu button
2. Touch Paper Menu
3. Touch Paper Size/Type.
Note: To link the multipurpose feeder, Configure MP must be set to Cassette in order for MP Feeder Size or MP
Feeder Type to appear as a menu item.
4. Touch the right or left arrows to select the same size paper from all paper sources to be linked.
5. Touch the right or left arrows to select the same type paper from all paper sources to be linked.
Note: When the Size and Type settings are the same for any trays, the trays are automatically linked.
6. Touch Submit.
Submitting changes appears.
7. Touch Home to return to the home screen.
Hope this helps.
Mar 16, 2010 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
Duplex Registration
Entering the Service Mode
There are two ways to enter the service mode.
Method 1: Turn the machine on while pressing the “On Line” key and “Escape” key
together until the above message in the illustration appears on the display.
NOTE: If you switch the machine off, any jobs stored on the hard disk using the
sample print and locked print features will be deleted.
Check first with the user tools to see if there are any jobs stored with these
features
(Menu key - Sample Print, or Protected Print).
SP1-XXX (Feed)
1 Mode No.
(Class 1, 2, and 3) Function / [ Setting ]
1-002
[S-to-S Reg.]
Side-to-Side Registration
1 By-pass Table *
2 Paper Tray 1 *
3 Paper Tray 2 *
Adjusts the side-to-side registration by changing
the laser main scan start position for each mode.
[ -10.0 to 10.0 / 0.0 / 0.1 mm/step ] FA
4 Paper Tray 3 *
5 Paper Tray 4 *
6 Duplex *
Feb 06, 2008 | Ricoh Aficio AP3800C Laser Printer
82 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
