Wireless connection works but internet page does not open
While on the internet, my laptop rebooted itself, gave screen that said restart windows normally (recommended). Once I did that, I could not open and internet pages. I am connected to the wireless connection, Skype works, but I cannot open an internet page
Re: Wireless connection works but internet page does not...
Diable firewalls on the computer and check if that helps. Also, reset the Explorer to default settings. If the issue persists then please install another browser and check if that helps.
First, do you have a wireless router button that enables or disables wireless internet? If so than it might have got accidently turned off. push it and see what pops up on screen. If it says enabled than it was turned of try connecting to internet again. If it says disabled than push again until it says enabled clearly that wasn't the problem. Next try going down to the two computers (right hand bottom corner) then double click them. This will bring up a wireless networks available, try refreshing this page. After refreshed if no networks are available than it may have to do with your internet provider. Try calling them to get a better detailed explanation.
You may use the System restore utility on windows by going to all programs then Accessories... Open system Tools and then System Restore. You may resotre your system to an earlier time, time when you are still able to connect to your router wirelessly.
make sure the web site address is correct try to open some other website .if still it is not opening then check the dns server setting in wireless router or simply you can reboot the wireless router just switch of and switch on. Hope this helps. Please rate my response. Thanks. Have a good day.
RESTART YOUR COMPUTER, ON REBOOT, CLICK F10 WHEN YOUR CHANGE BOOT OPTIONS SCREEN COMES UP. YOU MUST PRESS F10 QUICKLY OR IT WILL LOAD WINDOWS AND YOU WILL HAVE TO RESTART AGAIN. ONCE YOU GET INTO THE BIOS SETUP UTILITY GO TO SYSTEM CONFIGURATION, SCROLL DOWN TO BOOT OPTIONS CLICK ENTER. GO DOWN TO INTERNAL NETWORK ADAPTER BOOT AND ENABLE IT. GO TO SAVE AND EXIT. IT SHOULD BE WORKING WHEN YOU RESTART YOUR COMPUTER.
RESTART YOUR COMPUTER, ON REBOOT, CLICK F10 WHEN YOUR CHANGE BOOT OPTIONS SCREEN COMES UP. YOU MUST PRESS F10 QUICKLY OR IT WILL LOAD WINDOWS AND YOU WILL HAVE TO RESTART AGAIN. ONCE YOU GET INTO THE BIOS SETUP UTILITY GO TO SYSTEM CONFIGURATION, SCROLL DOWN TO BOOT OPTIONS CLICK ENTER. GO DOWN TO INTERNAL NETWORK ADAPTER BOOT AND ENABLE IT. GO TO EXIT AND SAVE. AFTER YOU RESTART YOUR COMPUTER IT SHOULD WORK.
First put in the cd that came with the wireless USB adapter. Close the auto setup page(we will use windows wireless network manager which works better with windows firewall . Plug in the wireless adapter and the laptop will automatically install the driver. If for some strange reason it asks you to install new found hardware, follow the promts and install manually and select cd and the directory the WG1111 drivers are located. Press ok and wait for install. Restart the computer.
After restart the computer will come up with a caption New Wireless Networks found. Double click on the wireless Icon in the bottom left hand corner. It will open a seperate screen with all wireless connections avaliable to you. Might be 1 or more networks, depending on whether your neighbours have wireless networks. Anyway find your specific wireless network could be for example NetGear, Dlink, or my home network. Click on connect your wireless connection. Another smaller screen will appear with Key in your password twice( WEP key or WPA key) Key in your key or password twice and apply or ok. It will connect and close screen. Restart computer! After restart the computer will pick up your connection automatically and your ready to go on line. If you move your mouse down to the icon with wireless network in bottom left hand corner it will show your wireless connection in a caption stating the connection name and how strogn signal is. Connection complete. NOTE: YOU MUST HAVE A WIRELESS MODEM OR WIRELESS HUB CONNECTED TO YOU MODEM TO USE THE WIRELESS WG1111. THANKS!
k once u log in to router u need to click on w/l settings and
Wireless Settings
Wireless Network
Name (SSID):
Region:
--- Select Region ---
Africa
Asia
Australia
Canada
Europe
France
Israel
Japan
Mexico
South America
United States
Channel:
01
02
03
04
05
06
07
08
09
10
11
Wireless Access Point
Enable Wireless Access Point
Allow Broadcast of Name (SSID)
Wireless Card Access ListSecurity Encryption (WEP)
Authentication Type:
Automatic
Open System
Shared Key
Encryption Strength:
Disable
64bit
128bit
Security Encryption (WEP) Key
Passphrase:
Key 1:
Key 2:
Key 3:
Key 4:
and if u want security password type any 10 digit no which u can easily remember one>and click apply do not hit generate>rate me solved if its helps
