Question about Vizio P2 42 in. HD-Ready Plasma Television
42" Vizio,red stripe down side,and now cutting out!!!
Red stripe down the side.about 2 " wide....Sound familiar? I also have this issue.Been there for a couple of months,and today it started cutting out every couple of min.
Sounds like were TV shopping.It could be worse,I paid almost $2000 for this one,and they are a lot cheaper now.I can look for a better brand.These things don't last forever like they used to.My Fisher TV before this lasted a solid 10 years.I hear the Vizio cutting out behind me as I type.This one doesn't have an HDMI plug on it,so I can't wait for the upgrade.I still think plasma TV's look better.Am I wrong?
Bad lcd panel
Posted on Jun 24, 2009
Can't get Shifter out of park on a 2005 F150 ford Truck.
If this is a new body style 2004 ( not a heritage or lightning ) did you check fuse #16 ? This is the fuse for the shift interlock switch on the brake pedal.
IF this fuse is good, check the shift interlock section of the brake pedal position ( BPP ) switch ( on the side of the brake pedal lever, usually has a yellow c-clip cover on it ).
The wires for the shift interlock circuit
Fuse #16 to Tan w/ REd stripe wire
Pink w/ light green stripe to the shift interlock solenoid.
If there is power on the Tan w/ REd stripe wire, press the brake pedal down, and check the pink w/ light greens stripe wire for power ( switch is closed when brake pedal is pressed.
If you do not have power on the pink w/ light greens stripe wire, you need a new BPP switch.
If you have power on the pink w/ light greens stripe wire, you need a new shift interlock solenoid.
Jan 25, 2010 | 2004 Ford F150
I have a 3 year old Akai 42" plasma TV, model PDP4216M. It has developed a bright red, 2" wide line down the righthand side of the screen. What does this mean, and can it be repaired? The TV has not been...
I had one red line at the beginning, then another one the same red, then couple months and green one. I fixed it by replacing one of the board inside (140$) and the problem is gone. The same model PDP4216M. Any questions e-mail me at kogut26@hotmail.com
Feb 26, 2009 | Akai PDP42Z5TA 42 in. Plasma Television
2" wide Red stripe on right side of LG 42" plasma TV screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size..
Jun 09, 2017 | LG DU-42PY10 42 in. Plasma HDTV
Dark vertical stripe on monitor
You screen "LCD" is broken , need new lcd panel. Very expensive
Feb 01, 2009 | Samsung T220HD LCD Monitor
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
2" vert. red stripe
I have worked on many Vizio televisions under warranty and what you are descriping is often a result of the X boards going bad. If the telelvision is under warranty, contact Vizio at 1-877-MYVIZIO, if it's no longer under warranty, the cost of repair is probably going to be more than the cost of a new tv unfortunatly. I always recommend buying the extended warranty's with these televisions.
Oct 04, 2008 | Vizio P4 46 in. HD-Ready Plasma Television
Hi. i have an LG 42inch plasma, approx 18 months old. about 2 months ago, a green stripe developed down the right hand side of the screen, approx 1.5 inches wide. last week a 2nd stripe the same width...
Sadly, the plasma screen is failing. The green strip is no longer functioning properly and the failures will continue to progress.
If still under warranty, get it exchanged.
Jun 12, 2008 | Computers & Internet
Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Philips 300wn5 green stripe on screen
I have a similar problem, what is the fix?
Mar 23, 2008 | Televison & Video
Vizio P2 42 in. HD-Ready Plasma Television Logo
329 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
