Go to this link thanks please rate the answer
Here is the link
u need to download .net framework 2.0 here is the link
Then install it. It is required that to work after installation. Means its programmed in .net
Here is the link. This will do it. Please rate the answer if its working for you. Thanks
Cheers!!!
mmm I think that .net framework problem is solved. Now its a new problem. U can't see anything and it gives the card is not plugged in errors. I think you would better try to check your card(adapter) since it says not plugged in. Go to my computer icon and right click and get the device manager. Check whether the drives are properly installed. If not we have to remove drivers for the adapter and re installation has to be performed. Better to check from any other machine(its the easiset thing).
And also try cleaning the connectors(machine side). Don't make any scratches pls.
*Go to my computer icon and right click and get the device manager by selecting "Management"
Download the drivers from the link below:
http://drivers.softpedia.com/get/NETWORK-CARD/OTHER-NETWORK-CARDS/D-Link-DWL-G630-Driver-110.shtml
Hope it helps
SOURCE: no installation CD for D-link dwl G630
Dlink drivers can be found here
http://support.dlink.com/downloads/
SOURCE: having used a restore disc on my laptop (xp)
Thank you for posting your question.
After you have restored your Windows Operating System, the drivers for this device may not be installed.
To install the device drivers for this device do the following:
Step 1. Go to the product page for this device here http://www.dlink.com/products/?pid=DWL-G630
Step 2. Click on the Support Resources tab
Step 3. Select the version of the adapter you have (the version is located on the card, usually on the bottom)
Step 4. You will be brought to a page that lists many resources, click on the Driver button
Step 5. You will be presented with multiple download options, read each item carefully and select the driver download for your product.
be sure to rate/vote
I download that trough my desktop PC which have internet connection, but when I put the wireless adapter into my laptop to download the copy of driver that I get fromhttp://www.restoredrivers.com/?gclid=CN3... (my laptop do not have internet connection), but it said status: pending requirement .NET framework 2.0 (x86) which i have no idea what is that mean, any other suggestions maybe, I already desperated
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
I followed your instruction, but I have no idea where i get
this screen b4 :status: pending requirement .NET framework 2.0 (x86) ,so silly yea....as
u guided me, I already install it, but when I click d-link airplus G
configuration utility, it said I have no card (in fact the card in plug in),
and no other screen to clicking on, so what should I do????no tab or screen I
can follow up the next step. Plz ....give me an idea how to tackle this
