Question about Microsoft Excel for PC
MS Excel-Values in the formula in place of cell reference
MS Excel-I want to view values in place of cell references in the formula. I have typed cell reference but I want to view values of the cells and not the cell reference (as such) in the formula.
    President:
  • 2,049 Answers
Copy the cell(s) and then right click on the cell(s). Choose Paste Special and then choose Value. That will convert it.
Posted on Aug 10, 2009
What are the formulas in grading the grades uisng microsoft excel
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
  1. All formulas begin with an equals sign (=).
  2. Some formulas use operands such as +,-, *,/ for addition, subtraction, multiplication or division.
    For example, the formula =A1+A2+A3 would add the contents of cells A1, A2 and A3.
  3. Other formulas refer to different functions such as SUM, AVERAGE and others.
    For example, the formula =SUM(A1:A3) would add the contents for the range A1 through A3.
  4. Formulas can be combined with operands.
    For example, the formula =10*SUM(A1:A3) would add the contents cells A1 through A3 and multiply them by 10.
  5. Functions can be nested within each other.
    For example, the formula =SQRT(10*SUM(A1:A3)) would take the square root of ten times the sum of cells A1 through A3. When functions are nested, it is important that the number of left parentheses match the number of right parentheses.
Aug 19, 2011 | Microsoft EXCEL 2004 for Mac
My MS Excel vlookup function ASCII type table contains both upper case and lower case letters, characters like ( and % or *, and numbers. It seems to return the numerical equivalent of upper case letters...
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Oct 31, 2008 | Computers & Internet
Not able to scroll on my excel sheet
It's only in Excel you can't scroll? Can you scroll from side to side? If you have Excel 2003, try to press the "window" tab on the top and if the freeze pane is checked, uncheck it. Or if it says unfreeze pane, press that one. Hope this helps :)
Jul 20, 2009 | IBM ThinkPad T42 Notebook
Ms-office
Subtraction can be done in two ways in Office using the following formulas in the formula (fx) bar:
  1. =A1-A2
  2. =SUM(A1,-A2)
The above formulas refer to cell reference A2 subtracted from A1. As usual, you can use number values instead of cell references.
The SUM formula subtracts by changing the sign of the reference. Remember the sign rules, and thus - -x is in effect +x.
Jul 08, 2009 | Microsoft Office Excel 2003 for PC
FORMULA PROBLEM IN MS EXCEL
The cells you are trying to sum are probably text and not numeric values. Format them as number or convert them to numbers.
Apr 18, 2009 | Microsoft Office Excel 2003 for PC
Circular reference working how to open excel file
Clicking cancel will invalidate the formulae, circular references refer to the dependant and precedent cells using each other.
Track/ Audit depending on your Excel version to show which formulae is incorrect - or options view, tick show formaulae and remove them.
Nov 20, 2008 | Microsoft Excel for PC
Regarding Excel formulas
Yes, its possible by designing a formula in excel.
Aug 03, 2008 | Microsoft Windows XP Professional
More than 256 characters in a cell in Excel
If a RANGES
\r\n
Named Ranges. SheetLevel Named Range, Named Constants, Named Formulas ,Relative Named Ranges ,Dynamic Named Ranges ,Advanced Dynamic Named Ranges .
\r\nWorking With Ranges. FindLast cell/row/column etc.
\r\nFormula Reference Changer. Absolute to Relative etc.
\r\nSpecialCells Method
\r\nExcel Named Range Manager $
\r\nOFFSET RANGES VBA
\r\nReturns a Range object that represents a range that?s offset from the specified range. Read-only.
\r\nexpression.Offset(RowOffset, ColumnOffset)
\r\n\\"expression\\" is required and should be a Range object.
\r\n
\r\nRowOffset: Optional Variant. The number of rows (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset downward, and negative values are offset upward. The default value is 0.
\r\n
\r\nColumnOffset: Optional Variant. The number of columns (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset to the right, and negative values are offset to the left. The default value is 0.
\r\n
\r\nExample
\r\nSub OffsetMe()
\r\n MsgBox Range(\\"B2\\").Offset(RowOffset:=-1, ColumnOffset:=2).Address
\r\nEnd Sub
\r\nIs the SAME as;
\r\nSub OffsetMe()
\r\n MsgBox Range(\\"B2\\").Offset(-1,2).Address
\r\nEnd Sub
\r\nOFFSET FORMULA
\r\nReturns a reference to a range that is a specified number of rows and columns from a cell or range of cells. The reference that is returned can be a single cell or a range of cells. You can specify the number of rows and the number of columns to be returned.Syntax = OFFSET(reference,rows,cols,height,width)
\r\n
\r\nExamples
\r\n=OFFSET(C3,2,3,1,1) Displays the value in cell F5.
\r\n=OFFSET(C3:E5,0,-3,3,3) Returns an error, because the reference is not valid.\", \"style=\\"background: #FFFFFF;padding: 2px;font-size: 10px;width: 550px;\\"\");" style="FONT-STYLE: italic" onmouseout="GAL_hidepopup();" href="http://www.ozgrid.com/forum/autolink.php?id=5&script=showthread&forumid=8">cell is formatted as Text, then it will display the #### when the text is over the limit. Reformat the cell to General and the text should again show.
Right click on the cell, click Format Cells, under the number tab, choose General.
Also, this ####, will occur is the cell width is to small.
May 16, 2008 | Microsoft Excel for PC
Exel 2003
You can refer to cells that are on other worksheets by perpending the name of the worksheet followed by an exclamation point (!) to the cell reference. In the following example, the AVERAGE worksheet function calculates the average value for the range C1:C10 on the worksheet named Marketing in the same workbook.
default.aspx?assetid=za010939481033 Refers to the worksheet named Marketing default.aspx?assetid=za010939491033 Refers to the range of cells between C1 and C10, inclusively
  1. Click the cell in which you want to enter the formula.
  2. In the formula bar (formula bar: A bar at the top of the Excel window that you use to enter or edit values or formulas in cells or charts. Displays the constant value or formula stored in the active cell.) default.aspx?assetid=za060515351033, type = (equal sign).
  3. Click the tab for the worksheet to be referenced.
  4. Select the cell or range of cells to be referenced.
Jan 01, 2008 | Microsoft Office Standard for PC
Percentage formula
Since you are asking for the formula, it depends where your values are (cell). Please refer to the example below.
Good luck and kind regards.
Dec 09, 2007 | Computers & Internet
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
159 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
