Question about Intel D845GVSR Motherboard
YELLOW DISPLAY - Intel D845GVSR Motherboard
  • Intel Master
  • 13,433 Answers
Vga- display cable is most likely broken, definitely if color changes when cable is moved or turned.
replace the cable between computer and display.
Posted on Jun 22, 2009
Yellow tint on display screen
hi
you must have a broken wire in the flat ribbon of the LCD (the one for the blue colour).
you have to replace it
cheers
mich
Feb 13, 2014 | Sony HDR Video Cameras
Yellow screen
There are a variety of problems that can happen to the display monitor of an Acer laptop.
The most common problem is the screen fading or becoming too hard to see.
This can be corrected by adjusting the brightness levels.
Another common problem involves incorrect color, which can be resolved by adjusting the display color settings.
Yet another big problem is the display freezing or appearing jumpy, which can be resolved by updating the display driver.
Hold down the "Fn" key.
Tap the right-arrow key to brighten the display screen.
Tap the left-arrow key to darken the display screen.
Release the "Fn" key to save your display settings.
Color
Right-click on the desktop and click "Graphic Properties."
Adjust the screen resolution by clicking "Display Settings" and choosing a resolution setting from the drop-down menu.
Click "Apply" to check the resolution of the display.
Click "OK" to save the resolution settings.
Adjust the color of the screen by clicking "Color Correction" and moving the brightness or contrast slider to the right or left.
Click "Apply" to check the color resolution of the display.
Click "OK" to save the color settings.
Click "OK" to exit the Graphic Properties application.
Update the Display Driver
Right-click on the desktop. Click "Personalize," "Display Settings" and "Advanced Settings."
Click the "Intel Graphics" tab and choose "Monitor Properties."
Click "Driver."
Click "Update Driver" and choose "Search Automatically."
Click "Install" to install the updated monitor driver. After the driver has been installed, click "OK" to restart the laptop when prompted.
Yellow screen
Yellow tinting in monitors can be caused by either a software calibration issue, bad cables or a worn out display and backlight.
Before you assume that the issue is a hardware one, determine if there are software settings that affect the color or if the cables are working correctly.
After checking these items, and if the yellow tint only occurs on one monitor and you cannot eliminate it, the problem is a display hardware issue and it is less expensive to replace the monitor.
Unplug the power cord from the monitor and replace it with another one.
This is a standard power cord used in printers, monitors and desktop PCs so you can trade it for a cable from another device.
Turn on the PC and monitor to see if the yellow is still there.
Turn off the computer and monitor.
Replace the video cable with another VGA cable from another monitor.
Use one from another computer before going out to buy one.
Restart the computer to see if the yellow tint is gone.
Right click any area on the desktop and click "Properties" from the list of options that appears.
Choose "Display Settings," then "Advanced Settings."
Select "Monitor" and click the "Calibrate Color" button.
Wait to see if the yellow tint goes away.
Locate the temperature color settings on the monitor.
Adjust these to see if there is a change in the color.
A warm color setting will give the screen images more of a yellowish tint.
Click on the "Start" icon, then click "Control Panel" and "System and Security" and choose "Device Driver."
Locate the video driver and click "Update."
Select the option allowing Windows to connect to the Internet to find an updated driver.
Wait for the update to complete in a few minutes.
Expect the yellowing issue to disappear.
Connect the PC to another monitor to see if the same problem occurs.
If the yellow tint does not appear on the newly connected monitor, the problem is a bad backlight or display and the monitor should be replaced with a new one.
http://www.adobe.com/education/pdf/cib/ps7_cib/ps7_cib17.pdf
Jul 21, 2013 | Acer Computers & Internet
Yellow stripes on imac (early 2009) display
Some of these links may help:
http://mac.bigresource.com/iMac-display-has-yellow-vertical-line--O9EU1eiuu.html
Dec 29, 2012 | Apple 20" iMac Desktop
The moniter won't display the light is yellow
Possible that the mother board/inverter section is faulty.
Jan 09, 2012 | Acer P191W 19" LCD Monitor
The parrot does not display the good bye message when i turn the ingition off the man at halfords said he does not know why but the book says it must display that does any one know why?
the ign wire and the positive wire need to be switched around. on the parrot loom there is a red wire and a yellow wire with in line fuse holders, switch them around, ie red to yellow and yellow to red
Jun 25, 2011 | Parrot GPS
Need directions on how to hook system up to tv
Check the back of the system, you will find Video out, then Audio out (left and right). Connect the yellow cord to video out, and the white & red to Audio out appropriately.
Then connect the other end of the yellow cord to "Video in" at the back of the TV, then the red and white to audio in at the back of the TV.
After connecting as directed above, turn on the TV, then turn on the system. On the TV remote control, press "AV" or "Source" depending on what is written on the remote and there should be a display. If there is no display, press the "AV" or "Source" on the remote once or twice more and there should be a display of the receiver's welcome screen on the TV. You might also need to press "Source" on the system's remote if there no display.
Let me know if you don't av display even after following the above steps. The above is the correct way of connecting so it should work.
Note; The White and Red cords stands for Audio left and right, while the yellow cord stands for Video. The yellow is suppose to allow your system display on the TV screen, while the Red and White is to bring out sound.
I hope the above helps.
Good luck.
Feb 01, 2011 | Audio Players & Recorders
Screen has vertical yellow bar on right side
If you get that yellow line on every screen,then the issue is due to display error.
Need to change the display and it will cost you more.
For this you need to contact Laptop chip level service engineer to replace the display.
It is better to bring your laptop to service engineer.
Nov 08, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Re-installing yellow cartridge in HP 2840
There is a gray button right of the LCD display that has a black arrow circling clockwise and four color dots (magenta/black/cyan/yellow). Push it until you see the "Rotating to Yellow" in the LCD display, then open up the top of the printer by pushing the big gray latch next to the picture card reader at the right front of the printer. You now have access to the cartridge. pull it out and examine it. If it is a new cartridge, check to see if you pulled the plastic dam strip out (which keeps the toner in place in shipment etc).
Sep 07, 2008 | HP LaserJet 2840 Printer
Flashing yellow light on Dell Monitor - what does it mean?
It means the display is in power save mode. This status occurs when the display is on but not receiving any signal.
Aug 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Yellow dispkay
the display turns to yellow when the blue colour is missed form cable. check the vga cable or may be it's from inside monitor. from the vga card. check the cable first then call or mail....
Feb 22, 2008 | Microtek C893 18.1" Flat Panel LCD Monitor
Intel D845GVSR Motherboard Logo
46 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
