Tally 5.4 error
I have Tally 5.4 .When open tally 5.4 dispaly error that exiting tally; file not found; attempting to open :C/tally/tallywindat.
Pl help me
In tally 5.4 my all data detected. now I have no records, only company name.when i try to open my company it is showing the commend "failed to open the company". please adivse me What I shall do?
Posted on Apr 28, 2013
My tally is 5.4 my tally error show
exsiting tally error your data date changed please your company restore and click on ok tally 5.4 shut down
Posted on Sep 15, 2009
  • kohilvyas Feb 11, 2011
    i am using tally eis 5.4.....when i give print order, saving window pops up, suggesting me to save the file in xps extension....i cant print directly....for printing i need to save each file dn i need to open that destination folder in which i have saved file then i need to give print order to each of the file...so if need to print 10pages i need to open 10 files...help...
  • RAM SINGH Apr 21, 2013
    my tally 5.4 is opening balalce enty
Try to configure your configuration setting. change the data source where you data saved.
Exp (from program files, configuration setting) :
;; Tally eis 5.4 workstation specific parameters file
[Tally]
; Specify location of Data files
Data = D:\data tally\Tally 2\DATA
;; Specify list of companies to preload
; ** TO STOP DEFAULT LOADING set the following line to NO
Default Companies = Yes
Load = 0001
;Load = 0002
; Specify list of TDL files for user defined reports and changes
; ** TO STOP LOADING TDL FILES, set the following line to NO
User TDL = Yes
;TDL = <TDL file 1>
; Specify location of TALLY.SAV (saved configuration of Tally)
Config = c:\TALLY
; Specify Color details of local monitor
Color = Yes
a bold letter is the source of data that you must change.
Posted on Jun 24, 2009
    I am using tally eis 5.4.....when i give print order, saving window pops up....and wants me to save file in xps extension....i cant print directly....plz help
  • 1,272 Answers
It seems that the TALLY software to which the shortcut was pointing is either been moved or does not exist.
Take backup of your data and reinstall TALLY
Posted on Jun 22, 2009
    New Friend:
  • 3 Answers
Sir my tally 5.4 is not open
Posted on Jan 09, 2014
I m using tally eis 5.4 ......some language problem
Posted on Jun 29, 2012
How to export in tally 7.2
This applies to Tally 7.2 and above.
1. You can export only registers and not masters
2. In any view register mode the export / import option becomes availble.
3. Click export.
4. Tally prompts you for a file name. The default name is always Tally.txt.
5. Pl rename the file to represent the ledger you are exporting else Tally will over write an existing file.
6. Tally will always save the file in the same drive / folder where Tally data resides. You cannot change this.
7. The file saved is the CSV file.
8. Open this file with Excel and map the fields.
Jan 20, 2015 | Tally Office Equipment & Supplies
EXITING TALLY!! Internal Error. Contact Tally
My tally 5.4 not open when to try open tally when see exiting tally! file not found. Please give the solution immediately
Apr 27, 2010 | Tally T2245 Matrix Printer
Tally Data Problem
EXITING TALLY!!
INCORRECT VERSION.
DATA OF INCORRECT VER.(10)
CAN ONLY RUN VERSION 9!
Jun 27, 2009 | Tally T2245 Matrix Printer
Tally 5.4 exiting tally error
i want to install tally 5.4 in my computer. I am using Window7. Does tally5.4 compatible with windows7? Plz give me solution for install tally5.4 in my computer with windows 7
Jun 22, 2009 | Microsoft Windows XP Professional
ERROR ! EXITING TALLY!
Error! Exiting Tally! File Name C:\tally\data\004\Tr01320.500 Size 196608 Position 196608 Chars 128 (Done 0).
Apr 21, 2009 | Computers & Internet
Software Exception c0000005
to solve this type of problem first of all take backup of your tally data then right click on ur tally icon on desktop go to properties then click on findtargate open ur tally configuration file see the line
load comony=yes (change yes into no) save the file & exit start ur tally pres ctr+alt+r selct the company which was giving error press enter tally will ask to rewrite the company press y to yes let the finish rewrite task then start working on tally
try this this works
RAKESH RANA
98682225794
Feb 02, 2009 | Computers & Internet
Have a problem in tally 7.2
Dear Archana,
If you are using tally legal. Please check whether the date & time are correct. If correct then check the data folder file permission (readonly, hidden, system attributes) are removed. If not while starting tally press Ctrl + Alt + R for and select company which one is getting error. It will rewrites the data of that particular company. Then close tally and open again check it. If this doesn't work u should contact tally support with u r licence key and product id.
Thanks & Regards
Nanda Kishore
Nov 13, 2008 | Computers & Internet
Tally exits on opening a company
by himesh
Respected sir,
as soon as i open a company in tally it gives an error by file name "Trnlots.500" & exits tally. Can you please help me out of this
Oct 29, 2008 | Computers & Internet
Corruption of tally 7.2file
Exiting Tally!
File Damaged
File:C':Tally7.2\Data\009\manager.500
Size 180180
Position: 180352
Charj : 128 (done128)
Jul 04, 2008 | Tally T2250 Matrix Printer
Recover tally data
Dear Sir/Madam,
I am getting the following error,
Existing TALLY file damaged File:C:/Tally/0001/Tr01298.500
Position:149760
Chars:128(done 128)
Please give me a solution to get my data and I am using Tally7.2 version...
Thanks & Regards,
S.Prasada Rao
Sep 10, 2007 | Tally T2250 Matrix Printer
Computers & Internet Logo
2,210 people viewed this question
Alun Cox
David Payne
David Payne
