Canon PIXMA MX310 All-In-One Printer Logo
Posted on Jun 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I got a message: received in memory - recommend new b-crt
HI,
somebody sent me a fax. I got the following message: receive in memory - recommend new b-crt. what does it mean? what should I do?
Thank you
Anonymous
Level 3:
President:
  • Master 2,306 Answers
  • Posted on Jun 22, 2009
Anonymous
Master
Level 3:
President:
Answers
2306
Questions
Helped
1130561
Points
8732
The b-crt is the black ink cartridge, when you put in a new one, it will print the fax for you.
1helpful
Memory info retrieving from lexmark x5630 fax machine
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing at the instance of receiving the fax. When this happens, try to replace the cartridge(s), *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink or empty cartridge(s). After the new cartridge is installed, close the printer cover and press the OK button. Your printer should then print the fax stored in the memory.
*Make sure not to navigate away from the "fax sent to memory" message, otherwise, data will be lost.
4helpful
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
1helpful
I would like to have the device print a Fax Confirmation for all fax sent and received. HP Officejet J4680 All-In-One
Follow the steps below to enable the Fax confirmation on Sent and recieved.
On the printer :
  1. Press Setup (c01461502.gif ).
  2. Press the right arrow button (c01185072.jpg ) to select Print Report , and then press OK .
  3. Press the right arrow button (c01185072.jpg ) to select one of the following options:
    • On Fax Send: Print a confirmation page every time you send a fax.
    • On Fax Receive: Print a confirmation page every time you receive a fax.
    • Send & Receive: Print a confirmation page every time you send or receive a fax.
  4. Press OK .
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
4helpful
New B CRT Recommend
B CRT is the Black cartridge and can allmost be bought anywhere!Ask Your local canon Dealer perhaps!Good Luck!
3helpful
What does "received in memory recommend new b-crt" mean?
It Means-All the faxes you received now will be placed in memory,The black ink cartridge needs to be replaced.Then the faxes in memory will be printed out.
Thanks for your support
3helpful
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after
each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Erased files
the problem is the fax that are stored in memory you will lose anyway.
you will need to do the following to get rid of your error:
DATA REGISTRATION button,
and # button, on the operation panel
go down to number 8
then scroll round to ALL
and then restart the machine and the fault should go.
Hope this helps
34helpful
11answers
Received in Memory issue
=) SOLUTION!!! To print from memory, simply press the "FAX button on the front panel.
Then, press the "MENU" button. "1. Fax Settings" will appear in the display. Press the
"right" arrow key once so that you get "Memory Reference" to appear on the screen.
Press the "OK" button once. It will display "Print List", but you want to "Print Document",
so press the "right" arrow key until you get to "Print Document" and press "OK."
Once you are there, press "OK" again and the message "Print 1st page only?" It displays a YES and NO, so hit the left or right arrow key to choose. If you want to print the entire document,
choose NO and press "OK" Your document will print out!!! =)
1helpful
Lexmark X342n MFC cannot print faxes
Contact Lexmark and get updated firmware - had this problem on an X342n unit yesterday and applying an update (now shows firmware LC.MD.P114 ), faxes started receiving properly.
old marine
old marine
ZJ Limited
ZJ Limited
