Question about HP Compaq d530 SFF PC Desktop
Pin connection for front pannel for compaq desktop board2001-2002 series.espescially for powerSW,HDD LED,RESET SW,RESET LED
Motherboard User Manual For SiS965L?
SiS965L is a chipset designation, not a motherboard model number. That said, most motherboards do label the header pins for the front panel connections on the motherboard, though they are a bit small and sometimes are not adjacent to the pins themselves. The Power Switch and Reset Switch pins are not polarized, and when you determine which they are, the connector plug can be installed on them either way. The Power LED and HDD LEDs ARE polarized. The positive pin is marked with a "+" sign and the Green wore of the Power LED and the Red wire of the HDD LED must be on the "+" terminal.
Nov 09, 2015 | Computers & Internet
FX58M powerSW
thank to answer.
@Jorico no threr is nothing wrote on the mobo (expt fp1)
Aug 19, 2012 | Computers & Internet
How to connect the wires to the panel P4M80M4 JPANEL1 wire list: 1) power led 2) speaker 3) power sw 4) reset sw 5) hdd led 6) usb 1 + g if you can send a diagram. if possible, in Russian....
The front pannel for the mother board veris with model no in all the mother board you will see the details printed in the in the motherboard as you said look in the motherboard for details named jp1 the detailed pin instructions will be given
Jul 03, 2011 | Computers & Internet
I cant find the case wireing connections on the motherboard led hhd rw led power and sound were do they go ...and can u send me a pic of how the wires look and were they go thanks
from the Compaq case / cabinet front pannel a single connector will connect to the board.
there will be set of pins / connector with mark" pannel SW / " on the board
It may not mention each seperatly.
May 19, 2011 | Compaq (277500-001) Motherboard
I have asrock agp8x p4i65g and don`t know how connect fron power/reset buttons and fron lights. There`re 5 lines power sw, reset sw, H.D.D. led and 2 ampty
yea there are 5 lines one is power switch other is reset the power led then hdd led then in older motherboard there is provision for speaker The power switch is in the front pannel of the motherboard if you have multitester the power which will indicate 5v the power switch is to be conected to the 5v and the ground normally the front pannels details will be given in the motherboard
Mar 28, 2011 | Computers & Internet
Configuring motherboard powerswitch leds reset
u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
Jan 06, 2010 | Dell Dimension 2350 PC Desktop
T6410 EMACHINE TRYING TO CONNECT START BUTTON
The motherboard in your computer is an MSI MS-7145, which is also called RS480M. You can download a copy of the manual here. The front panel connections are on page 2-20.
Looking at the header JFP1, pins 1 through 9 (odd numbers) are the front row, pins 2 through 10 are the back. Pin 10 is the missing pin. The power switch connects to pins 6 and 8. The power LED connects to pins 2 and 4. The HDD LED connects to pins 1 and 3. The reset button, if used, connects to pins 5 and 7.
May 13, 2009 | E-Machines eMachines Desktop PC
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
How to connect Power LED, Power SW, Power Reset and HDD LED
it is written in the motherboard..
re-reset botton
pw- power botton
hdd led- hard disk led
pw LED- power led
the code is pin 1....
Jan 28, 2009 | Zerus Intel Desktop Board D815EEA...
Motherboard manual To connect main wires
Usually indications are printed beside proper connection Pins . Find your model number and posta comment to look for your motherboard data sheet on web.
Sep 17, 2008 | Intel Motherboard
HP Compaq d530 SFF PC Desktop Logo
122 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
