Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
I have a Hitachi 57 inch tv and it periodically goes to black and white. I can move the tv, hit the sides or pull on the AV connectors and then the tv goes back to normal color. Is there something loose inside? Is this something that I can fix on my own?
  • eslick_s Jun 22, 2009
    I thought that too. I have tried several different cables. right now i am trying my dvd cable in the component 2 slots. This happens not only while watching cable tv but also dvds and with my wii.
  • 341 Answers
Sounds to me like you have a bad video cable or loose video cable. Try swapping it out with a good known cable
Posted on Jun 22, 2009
  • judy hutchins
    judy hutchins Sep 05, 2014
    i took the back panel off, and the VHF/UHF piece on the back of the set, has no connection to anything on the inside of the set. looks as if something was ripped off of the VHF/UHF, on the inside. i cant find a wire or panel inside where it may lead to.
I'm only getting white screen with black,
You'll need to check all the connectors that you unplugged, make sure they are plugged in to the correct place, plugged in well and no pins bent over etc, Probably should also check any connectors that you did not have to unplug just to make sure they didn't get pulled while you were getting to the color wheel.
Nov 25, 2014 | Mitsubishi WD-57833 57" HDTV
I need to know how to hook my DVD player to ,y Samsung TV. I have it hooked up and have a picture but its in black and white.
look on the back of the television and the DVD player, there should be a SCART socket and/or red, white and yellow AV sockets, either use a SCART lead and connect it to the SCART on the DVD player and the TV.Or use an AV lead with 3 auxiliary shape connectors and match the colour of each connector with the female sockets on both the TV and the DVD player instead of using the other component connections.
Nov 29, 2011 | Hitachi Televison & Video
Setting up tv sound to come thru stereo speakers
Offhand, your Philips 32PFL7422/98 do not have regular Audio Output RCA jacks (white and red), sorry. However, right before the antenna connector is an S/PDIF output connector. This should allow transfer of digital audio signals from the Philips 32PFL7422/98 to a S/PDIF capable receiver or amplifier. If you would look at the rear of your stereo and determine if it has such an input, then it would be a matter of getting the right cable/connector.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Philips Televison & Video
How to connect loptop pc to Hitachi 42 inch LCD
Sounds to me like an audio 3.5mm jack to L-R phono leads. The single jack connector would need to go into your pc's line-out port on the soundcard and the red and white phono connections on the other end go to either your television or home theatre system.
Mar 14, 2008 | Televison & Video
Hi how are you going im
Try new/different cable, if still have problem? You have a loose connection in the unit on the connector.
Feb 23, 2008 | Televison & Video
Hitachi 50 inch Rear Projection Color problem
Which sounds like a loose connection in the video or chroma section. you can carefully tap around affected area with a rubber screwdriver handle(not metal part) and see if it does come and go and look in that area for loose connections that needs soldering back. Hope this helps
Jul 30, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
232 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
