Question about Mitsubishi VS-45607 45" Rear Projection Television
Tv turn on audiobut no picture
My tv willturn on has volume no picture ever once in a while get a flash of color/picture
My 65inch Mitsubishi started humming through the volume now the picture gets snowy
follow this steps and fix it. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Jul 31, 2013 | Mitsubishi WS-65807 65" Rear Projection...
My 65inch Mitsubishi tv started humming and buzzing with the volume now picture is getting snowy at time
Have a 50 inch hlp506w model samsung projector tv. it had wavy lines through it, and then turned off. it is continuing to try and turn on with the standby/temp and lamp lights flashing. replaced lamp...
Change the tv Ballast board too.This board only job are to help it to ignite the tv projection lamp. This tv also have a colors wheel design into it too.If tv have colors pictures flashes or Black& White flashes within it pictures or tv have grinding noises or humming sounds,than the tv colors wheel it is warp and dead.This tv colors wheel must be replaced,because the colors dis wheel is warn out.
Jul 05, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
There is no picture when TV is turned on and all you hear is a faint chirping sound. Sounds like something is trying to restart. There was an issue with our cable, once it came back on later in the day the...
The problems ur tv having is also parts of the tv Convergence board are dead,but it is totally dead to causes this problems,if convergence board it still have some functions left.Tv will only have colors R,G,B will mis alignments,have colors shadows pictures and 3D pictures look alike,but convergence board are not getting any voltages at all that why u just hearing faint chirping noises that it.The tv convergence board,must require to changes 2 STK convergence ICS and some or all of it resistors too.For the covergence board have fully functions again to solved this problems.The shop will cost u like $300-350 for parts and labors.
Jan 31, 2011 | Philips 60PP9202 60" Rear Projection...
My TV turns on, has a blue screen but won't recognize anything - my DVD player or X box. For cable I can get volume but no picture after completing TV set up from menu but once I turn it off the TV loses...
Now tv turn on,tv get a picture only flashes few sec.than died have sound left only?Yes,than the tv long board call the LCD inverter board is dead.This long LCD inverter board help the LCD screen panel to have a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a long refurbish LCD inverter board for the replacement.
Nov 20, 2010 | Polaroid FLM-1514B LCD TV
My HLN5065WX will turn on, play for about 1 minute, flash funky colors then go black. Once this happens you can not shut down the TV. You must unplug to turn off.
Bad Color Wheel, its located behind the Lamp Pull Lamp out and use a Flash Light You should be able to see it.
Encompass Parts Distribution 1-800-638-3328
Samsung Parts.com 1-800-627-4368
You can also go to Encompass website and look up your Model#
Oct 27, 2010 | Samsung HLN5065W 50" Rear Projection...
Panasonic PT50LC14 No Sound or Picture
unplug it, and let it set for a minute or 2, then try it again...if it does it again hit the power button again to turn it back on...also once the the tv turns on make sure you reset the counter for the bulb..that will also cause problems...to reset the counter press the (-) volume on the tv while holding down the (-) press spilt,pip on the reomte...the lamp will reset and the indicator will go out
Jan 20, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Modified Picture Settings Reset Each Time TV Is Turned Off/On
Your TV may have been put into shop mode or demo mode. How to get out of "Shop Mode"
1. Press [Source] to get to the Air or Cable input on the TV or TV remote
2. Press [Volume +] once on the TV itself (not the remote)
Next step must be completed while the volume bar is still on screen
3. Press and hold [Menu] on the TV itself (not the remote) for about 7 seconds
If the screen flashes "Dynamic Mode", the process worked
4. Finally check whether the Picture Mode is "Shop Mode" or not after passing "INFO" on Remote Control. If picture mode is still in “Shop Mode” try the alternative way below
Alternative Method
Press [Source] on TV remote to get to the AIR or CABLE input
Press [Menu]
Press [Down Arrow] to highlight SETUP and press [Enter]
Press [Enter] again on PLUG AND PLAY
Wait 10 seconds
Press [Enter] to select ENGLISH (or choose an alternative language
Press [Right Arrow] to highlight HOME and press [Enter]
Press [Menu] repeatedly until you see the message ENJOY YOUR WATCHING
Confirm you are out of shop mode by pressing [Info] on the TV remote
Nov 09, 2008 | Samsung HL-T5687S Television
Picture is all different flashing colors
Maybe you put magnet near to your TV or something that can produce magnetism.... if not the deguassing system is not functioning anymore. .. bring your unit to near service in your place.
Apr 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My TV will not turn on!
I have a tie dye of rainbow colors on the whole screen. Is the screen shot?
Dec 08, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Mitsubishi VS-45607 45" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
