Question about Nikon Coolpix 5700 Digital Camera
Faulty coolpix 5700 flash (& SB red dot)
My CoolPix 5700 is a few years old. Never had much need for the flash, sometimes I'd get the flashing SB red circle, but usually just changed to another user profile and forgot about it.
After being given the responsibility of taking a friends wedding shots, an indoor flash would be useful I thought. After buying a SB-50DX speedlight, I found that taking pics with the flash wouldn't work no matter what was tried.
The flash unit could be fired itself with the test button so I knew that worked, but it would not work with the camera at all.
In this thread Nikon's response was"It is unfortunate to hear of so many incidents involving this similar fault, however, as I stated previously, this is not a know fault and at this time Nikon is not performing repairs free of charge." Well it's unfortunate that I will be probably taking my business elsewhere, maybe to Canon. I have just over a week to sort something out for the wedding.
My flash isn't working on my Coolpix 5700. I'm
Hi.
From what I have heard Nikon has recalled the Coolpix 5700 because of the SB error. It has something to do with a connector coming away from the printed circuit board. I recommend that you get in touch with Nikon and see if they will repair the flash for you. Click on the link below to contact them.
http://www.nikonusa.com/Service-And-Support/index.page
Good luck.
Jun 09, 2011 | Nikon Coolpix 5700 Digital Camera
Flashing SB warning light when trying to take picture
Does the flash pop up? If not, try to pull it up manually. Look at your settings in the menu, maybe reset them.
Jun 27, 2009 | Nikon Coolpix 5700 Digital Camera
Nikon coolpix 5700 flash isn't working...can a bulb be bought and replaced or do I have to send the camera to nikon for repair?
I can help, I just need a few more details...
  1. Is there a blinking red dot on our screen when you try to take a picture with the flash?
  2. Is the flash poping up?
  3. Has it worked before?
Dec 06, 2008 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5700
your flash doesnt work to use the camera turn off the flash also you can get an external flash for less than it takes for them to fix it good luck
Sep 24, 2008 | Nikon Coolpix 5700 Digital Camera
Re: nikon 5700 faulty flash
It appears that you have a ccd problem.
That particular model had a ccd problem, whether or not the flash is part of it, I do not know.
Here is the link to FREE REPAIR if the problem is the ccd.
http://www.nikonusa.com/email_images/nikonusa/service_advisory/coolpix.html
I have sent some Nikons in for repair, and they have been fixed free. The shipping will cost you to send in.
Aug 24, 2008 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5700 Digital Camera - SB flashing and cannot take picture
Not to buy a Nikon Coolpix anymore.
This is a very bad camera. I had this same error last year. The camera was sent to Japan once, returned to me and worked for six months.
Now is the same problem: SB light in red doesn't let me take pictures in light conditions when flash is needed.
So, you'd better think in buying a camera, not Nikon, please.
JAMP
Havana, Cuba
Nov 09, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5700 Autofocus
you need to fix the flash or get an external flash
Oct 19, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon coolpix 5700
The red dot beside SB means that the flash is not ready. If the flash does not pop-up, I would say something is jamming it -- and not allowing the flash to pop-up. If the flash does pop-up, but the red dot stays on, there is a problem with the flash. The simplest might be a battery that is almost dead. The flash has to "charge" before it will fire. I have to admit, you would notice this rather quickly as the camera would power down within a few shots -- even if the flash didn't fire.
Check the pop-up flash position and get back to me. I hope this helps! Please post rating, if it does.
Regards,
Char1ieJ
Sep 16, 2007 | Nikon Coolpix 5700 Digital Camera
Camera picture problem
I think it is time fot you contact the Tech Support site. If it is more than a year old it may be time to replace it download this to see if is of any help http://www.fixya.com/support/p423-nikon_coolpix_5600_digital_camera/manual-10378
May 21, 2007 | Nikon Coolpix 5600 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
317 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
