Restart button in the cpu is not working - Computers & Internet
    Scholar:
  • 155 Answers
I suggest that you will open the cpu and look for wire that will connect from the restart button to the motherboard. If you have set up manual of the mother board, just follow color code of the wire that will be plugged in to motherboard. ASUS and other motherboards have connection of the wires located below the circuit board just in line with the tiny colored wires entwined by pairs.
Posted on Jun 22, 2009
  • 674 Answers
Check the connection,
Power on no display, light flash on shortcut button
check the monitor power adaptor i fits properly connects or not.
if its connects properly
(or)
if cpu led indicator is on but no display, then just press the restart button it works
Oct 20, 2013 | Fujitsu Computers & Internet
A6119h power button doesn't turn on
if your want cpu run then open ur cpu change restart switch to power switch ...its work...
your power switch not be work
Jul 30, 2012 | HP Computers & Internet
My computer turns off and on again for a few seconds. (this time it will bootup) when i pressed the power button. i already change the ram to 1gb but the problem still occurs. What can i do to fix this...
It may be owe to software problem 1, the virus "shock" virus attack will prompt system will automatically start in few seconds. From the remote control you Trojan program all the activities of the computer, including let your computer restarts. Remove viruses, trojans, or reshipment system. 2, the system files damage system files destroyed, as the KERNEL32. Win2K DLL Win98 features, the font list below such basic execution system files destroyed at startup, system will therefore cannot finish initializing and forced the restart. Solution: cover installation or reinstall it. Hardware problem: 1.Chassis power is not enough, dc output is pure, the dynamic response sluggish. Users often ignored or assembling businessman, using cheap price of power supply, so is the largest system of automatic restart suspicion. (1) the power output power shortage, when run large 3D gaming occupy CPU resource of software, the CPU needs power supply, power is not caused by overload protection, stop the power output. After the output power to stop, load, reduce power restart. Due to the protection of the recovery/time is short, so we are hosting automatic restart. (2) power dc output is pure, pure dc power supply of digital circuit requirements, when the power output of too direct, the harmonic content will result in digital circuits, performance is often work to crash or restart. (3) working load of the CPU is dynamic, on the current requirement is dynamic, and the dynamic response speed quickly. Request Some of the poor quality power dynamic response for a long time, could also lead to crash or frequent restart. (4) high-end graphics update equipment (large disk/video card/equipment (increased), after the hard disk) / burners, power supply of original beyond rated output power will cause the regular crash or restart. Solution: now in high quality high-power computer power. 2.The memory chip thermal stability, incorrect or damage to restart the system memory problems to restart the system of risk. (1) the poor thermal stability of memory, boot can work normally, when the memory to a certain temperature, temperature is can not work normally, which leads to crash or restart. (2) memory chips, slightly damaged, also can pass on self into the system, when the operation can be some big software throughput will restart or crash. Solution: replace memory. (3) memory of CAS value too small can also lead to instability caused by system memory, automatic restart. General had better use the default Settings, don't roll change yourself. 4.The CPU temperature exorbitant or the cache damage (1) the CPU temperature exorbitant often causes protective automatic restart. The basic reason of high temperature is due to poor cooling chassis, CPU, the CPU is undesirable reasons: the heat radiator thermal conductivity low, radiator material with a foreign body between CPU interface (1) for quality assurance, fan speed is low, the fan and radiator dust too much, etc. And P2, P3 motherboard CPU temperature probe damaged under the mp4 or within the CPU temperature detection circuit on the mainboard damage, the BIOS BUG in a special conditions of temperature, the CPU CMOS setup to protect low temperature, etc. Can also cause protective restart. (2) of an internal CPU, level 2 cache damage is CPU common fault. The extent of damage, or can start, when running into the system, the software (some throughput big media player, games, 3D graphic) will restart or crash. Solution: in the CMOS setup of shield (L2) or level 2 cache cache (L1), 1 or replace the CPU. 4.AGP display, PCI CARDS (nics), cat restart automatically (1) the external card or poor quality work not standard, AGP/PCI bus signal misoperation cause system RESET to restart. (2) and graphics, loose network system may cause restart. 5.Parallel, USB access is serial, fault or the incompatibility of external devices restart automatically (1) the fault or not compatible with the parallel damage, such as printer, a foot of short-circuit, USB equipment damage of short circuit, signal level sutural definition, opaque, etc. (2) hot swaps external devices, shaking, cause signals or power instant short-circuit. 6.Mainboard failure In case of automatic restart motherboard is rare. Generally RESET circuit are associated with a fault, Socket weld is empty, slots, contact undesirable, Individual chip, capacitance elements such as damage.
Jun 23, 2010 | Acer Aspire 4315 Notebook
Im using ASUS VW193T LCD monitor for my pc...the problem i encounter now is that it turns off automatically but my cpu still on then it turns on again...sometimes it turn off then when it turn on again my...
im quick guess would be nyou have a Bios MotherBoard Video Card Problem. If you are using an on board video card then that doubles your chances or it being *********** boards fault. Also do a google search for ways to reset *********** boards bios that can sometime do glory to unresolved problems. What happens if you hold you off button down for a long time (40seconds)
Feb 01, 2010 | ASUS Computers & Internet
Sony vgn-nr120e stops working
Uninstall unnecessary softwares from add/remove programs. Did you noticed that cpu fan is working? If not then clean the cpu exhaust system with blower and also check the cpu fan function in BIOS. When using laptop always use flat surface to place it, mattress or sofa create problem with cooling and exhaust system of the cpu fan.
Hope this will help you.
Regards;
Hasan
Dec 30, 2009 | Sony VAIO VGN-NR120E/S Notebook
When turn on BIOS wouldn't load until i press restart
you are having problem with the connector i;e power button try at some good repairing shop
May 26, 2009 | Intel D945GNT Motherboard
My pc get hang and not working
If there is a excessive heatup or a short circuit in cpu or if there is a surge in power, The systems protection mechanism kicks in and stops all the processing. The reasons might have fried up some cpu components which is why its not restarting. Try some more restarts and If the cpu is not working at all, then there must be a problem with the power supply
Feb 01, 2009 | Computers & Internet
ASUS k8N motherboard major error
try to go to Bios setup and select the default settings and restart your unit. after you restart tell me what happen.
Mar 30, 2008 | ASUS K8N Motherboard
Computers & Internet Logo
63 people viewed this question
Alun Cox
David Payne
David Payne
