Sony VAIO FX220 Notebook Logo
Posted on Jun 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Windows vista restarts
Hi every time i shut down my computer it restarts i have to switch it off manually
Shafky Khan
Level 2:
  • Expert 85 Answers
  • Posted on Jun 22, 2009
Shafky Khan
Expert
Level 2:
Answers
85
Questions
Helped
44320
Points
242
Its prob with your vista version, which is not compatible with your pc, install another version of Vista using different disk. (please read the requirements of windown Vista)
good luck
shafky
How do I restart or reboot my whole system and start fresh.I have a Dell latitude D430
Dell not given facility to reboot. But command through you can reboot . To access the command prompt window from Vista or Windows 7:
  1. Go to the Start menu
  2. Type cmd in the Search field
  3. Press Enter
On a Windows XP computer:
  1. Click the Start menu
  2. Choose Run
  3. Type cmd
  4. Press Enter
From an open command prompt window, you can type shutdown, and then the option you wish to execute.
To shut down your computer type: shutdown /s
To restart your computer type: shutdown /r
To log off your computer type: shutdown /l
0r
press down window key with and two time press "U" key.
tip
How to Turn Off Safe Mode on Windows Vista
The Safe Mode is used to detect the technical and software problems in windows Vista. This is an effecting way to diagnosing the problem, that's why most of the technicians prefer this way to resolve the problem. But Safe Mode disables the most of the advance functionality of your computer. So use the Safe Mode only for diagnosing the problem and as you diagnose and repair the problem get back your windows to normal mode. <br /><br />For reverting back to normal mode at windows Vista, an option occurred which has to be select within limited time and if you select the Normal Mode option within this limited time, your windows will revert back successfully but if you waste the time, you have to restart your computer again for getting this option. You can select the Normal Mode option through arrow keys or by pressing the number at which the Normal Mode will appear.<br /><br />Sometime your computer does not display the Mode Selection Menu. This is not a problem you can get this menu and revert back your windows Vista into Normal Mode through the following instructions.<br /><br />Instructions<br />If you want to revert your Windows Vista into Normal Mode from the Safe mode but your system is not giving you option to select the mode, follow the given instructions: <br /><br />Restart Your Computer: To restart the computer you need to take the following step:<br />- Click on "Start" button at the left side of Task Bar. In Safe Mode of windows Vista the Start button appears at the same place where it appears in the Normal mode. Select "Turn Off Computer" from the Start Menu. Then, Select 'Restart" from the pop-up menu.<br />When your computer has been shut down place your finger at F8 key. As your computer starts to boot computer devices for restarting your computer, press F8 key again and again unless a menu appears on the screen. This menu is Mode Selection Menu.<br /><br />Note: If your computer won't give you Mode Selection Menu at the screen that's means you have lost the time of getting option. In this condition restart your computer again and again, and then press F8. <br /><br />When you get Mode Selection Menu on your computer screen, stop pressing F8 key. Now choose the Normal Mode from the list by the following method:<br />- You can select the Normal Mode by pressing the number on which Normal Mode appears in the list.<br />- You can select the Normal Mode manually through the Arrow Keys. Press the down key to reach at the Normal Mode option in the list and press Enter. <br /><br />Then wait for a while to reboot your Windows Vista in Normal Mode. <br />This is the method of changing Mode in windows Vista. You can follow these instructions at any time to revert your windows Mode.
on Jun 24, 2011 • Computers & Internet
Maxtor slave
EMachines is a brand of entry level, affordable computers now owned by Acer.
The computers come with the Windows operating system.
To keep your computer secure, it is a smart idea to continually reset and change your password. Changing the password will take only a moment.
Log in to your user account.
Press "Ctrl" plus "Alt" plus "Delete" simultaneously.
Click "Change Password" from the list of options.
Enter your old password.
Enter your new password twice to confirm.
Press "Enter" to save the changes.
Reset An eMachine
eMachines manufacturers a series of netbooks, desktops and laptop computers.
Certain applications and circumstances will require you to reset your computer.
Resetting your eMachine computer is a quick process that can be used to fix problems, complete program installations and access the BIOS or other Windows tools, such as Safe Mode.
Click "Start" in the Windows taskbar.
Click "Shut Down."
Click "Restart."
Normal Restart for Windows Vista/7
Click the "Start" orb in the Windows taskbar.
Click the arrow next to "Shut Down."
Click "Restart."
Change your Windows password
http://windows.microsoft.com/en-US/windows-vista/Change-your-Windows-password
5helpful
My Toshiba laptop is stuck in logging off mode. How can I fix this?
if you have a program running that is non responsive and try to shut down or restart, the computer will get stuck on the logging off screen. Often times if a computer takes a long time to do anything, it means you need to defrag your hard drive. Manually shut down the computer (you might have been pushing the Sleep button. If you can't figure it out, just unplug it and let the battery run down.) and when you restart it, go to the My Computer or Computer option, right click on your C drive, click on properties and a window should pop up. Click on the tab that says Tools and click on the Defragmentation option. The rest should be pretty self-explanatory. If nothing works. please try logging in as administrator in safe mode and doing a system restore.... please see Using Windows Vista System Restore :: the How-To Geek
2answers
Cannot start up vista keep getting message configuring updates then it shuts down
Hi friend,
You should run in safe some for start the window...you need to press F8..then computer will ask you for safe mode then you need to select the same mode...then computer will start in same mode then shut down and restart again...then it will work....if it is not working ..you need to install the window vista again...
How do I reboot vista laptop in order to remove radial point
a reboot is always a last resort!!! a better option to remove a program is to access control manager by pressing ctrl, atl, delete at the same time. when the prompt window is opened look through both processes and services tabs for anything related to the program hit stop process then just go to start>control panel>add/remove program. if that doesnt work restart your computer in safe-mode. if its a vista hit the power button let it rest for a sec then restart it. since the computer was improperly shut down it will ask if you want to start windows normally. don't instead choose start in safe-mode when it starts everything related to radial point will be shut down making it easy to remove the program through control panel. if you still whish to reboot shut down your computer by opening the start menu and in the lower right corner select restart. when the comp. restarts and the logo appears hit f8 quickly (you only have about 5 seconds before it restarts normally) choose boot with disk insert your start up disk and the computer will restart and all non-default programs will be lost. radial point will finally be defeated but at what cause? at what cause!!!??
Just bought a new Windows Vista HP and when I type a letter on yahoo the ''letters are missing in every other words?''
try shutting it down and restarting the computer shut it down for about 5-10 minutes then restart it when u shut it off unplug the keyboard and just before you restart the computer plug in the keyboard
Acer aspire 5003wlmi starts to boot then shuts down and restarts
Hi you must reinstall your operating system using windows xp cd or vista it depend what windows you using
2answers
I want to reactive my HIBERNATE action
Plz Check
http://www.howtogeek.com/howto/windows-vista
/re-enable-hibernate-option-in-windows-vista/
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
