Question about HP LaserJet M1522n MultiFunction Printer
Permanent storage init
What is this and how to clear
2 Suggested Answers
  • 223 Answers
SOURCE: hp printer model M1522nf displaying permanent
HI,
This a formatter failure, sounds like the formatter went out while trying to do a hard reset or after updating the firmware,
Try doing a nvram:
Turn the printer off and hold the down arrow and the cancel button
Turn the printer on while holding the two buttons down
Continue holding until you see the permanent storage message and wait for the ready message to display
If this doesn't work call hp and tell them that printer is frozen and will not initialize, this is due to a formatter failure. If it has been less than 2 years since the purchase date then you will apply for a service note and will be able to have the printer serviced for free, Contact hp's tech support at 1800-334-5144.
Al
Posted on Jul 16, 2010
How to factory reset the hp pro 300 laserjet printer
1. Power down the printer
2. Press and hold the lower left hand corner of the screen
a. This is normally where the progress bar starts loading on the screen
3. Power on the printer
4. Release the left hand corner once the "Permanent Storage Init" message appears.
or alterative way
2. Press and hold the right arrow button on the navigational bar
a. This button will flash for a moment when the printer boots up
Jul 14, 2016 | HP Office Equipment & Supplies
Hp leserjet printer error.
Service-mode functions NVRAM initialization
An NVRAM initialization will return the following device settings to the factory-set defaults:
All menu settings, including the fax header and company name
Fax numbers and names that are associated with one-touch keys and speed-dial codes
Additionally, all faxes stored in memory are cleared.
Perform an NVRAM initialization
1.
Turn off the product.
2.
Simultaneously press and hold the
the product.
3.
Wait until the message Permanent storage init. appears, and then release the
arrow buttons.
When the NVRAM initialization process has been completed, the device control panel shows the
Ready message.
Super NVRAM initialization
A Super NVRAM initialization will return all of the device settings to the factory-set defaults (generic
product mode).
NOTE:
When the product is turned on, you will be prompted to select the language and country/region
setting before the product will initialize.
1.
2.
the product.
3.
arrow buttons.
Service menu
NOTE:
An asterisk (*) symbol next to a service submenu option indicates that this is the current setting
for that option.
For more information about using the service menu, see
Access the service menu
1.
Press the
2.
Use the arrow buttons to select Main Menu Service, and then press OK.
3.
Use the arrow buttons to select the desired secondary-service option, and then press the
button.
4.
Use the arrow buttons to select the desired submenu option, and then press
ENWW
Setup
button.
Cancel
button and the right arrow button
Cancel
button and the left arrow button
Service menu on page
), and then turn on
Cancel
and right
), and then turn on
Cancel
and left
241.
OK
OK
directly from service manual
Sep 15, 2015 | HP LaserJet M1005 Printer
How to clear back to factory setting
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
When the NVRAM initialization process finishes, the product control panel shows the Ready message.
The super NVRAM initialization clears all settings affected by a regular NVRAM initialization, and also
clears the product language and country/region settings. Both settings must be reset after a super
NVRAM initialization.
When the process finishes, the product control panel shows the Ready message.
Apr 18, 2013 | HP LaserJet M1522nf Multifunction Printer...
79 error turn of and turn on
Try doing an NvRam on the printer (Hard Reset):
1. Turn the printer off
2. Press and hold the right arrow and the cancel button
3. Turn the printer on while still holding those buttons
4. Keep holding them until you see a message that say "permanent storage init"
This should clear that error message
Aug 05, 2010 | HP Laserjet M2727nf Multifunction Printer
Describe how to clear memory from HP LaserJet M1522nf
Jul 22, 2010 | HP LaserJet M1522nf Multifunction Printer...
On the HP2820 I'm trying to print color copies from my computer & it keeps giving me the message on the printer that the memory is full. Can this message be cleared so it can print?
Hi !
You can clear the memory on this printer with this instructions:
1. Turn OFF the power
2. With your right hand hold down the [ENTER] + the [*]
keys together and don't let go until you see the words
" permanent storage init "
3. let it do it's thing..lights will blink, bar wil scroll...
.... all normal and part of the process.
4. thats it.
Good Luck !
Bryan
Jul 21, 2010 | HP LaserJet 2820 Printer
Memory full?
This is a problem with the formatter board, try doing an nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years. Al
May 17, 2010 | HP LaserJet M1522nf Multifunction Printer...
How can I clear my fax memory hp laser jet 3055
Hello !
You can clear the memory by doing an NvRam or hard reset
a. Turn off the product.
b. Press and hold the Right arrow and Cancel buttons simultaneously.
c. Turn on the printer.
d. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
e. After a few minutes the printer should go back to the "ready mode"
May 14, 2010 | Canon L120 Fax Laser Printer
HP laserjet 3330 Permanent Storage Init.
Switch of the printer press and hold down menu and cancel button turn on the printer keep holding these two buttons and turn on the printer.
As soon as printer display shows permanent storage init. release both the button.
May 11, 2009 | HP LaserJet 3330 All-In-One Printer
Fax Memory full
please perform the following:
When a super NVRAM Init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM Init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM Init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
Sep 10, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet M1522n MultiFunction Printer Logo
298 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
