E00002-0000 error code
ont. Panel, press the following, one after the other, * (additional
functions), 2, 8, * (additional functions). You are now in Service
Mode. Touch the Function Tab, touch the Clear button, touch the ERR
button, when it is highlighted, press the OK button at the botton of
screen. Power Cylce unit. If it comes back up, may have been a fluke.
However, if it comes back, check your Fixing Assy for jammed paper, or
damage to the Fixing Film (Upper Roller). Replacing the Film is not
hard. After you remove the Fixing Assy., its a couple cables and
springs. Rather on the easy side for Film replacements. Remebmer, on
these models, the Film is also the Heater and Upper Fixing Roller. The
Film is most likely on the pricey side for new, believe you can find
rebuilds. Just keep in mind that the Film is still a lil' bit cheaper
then the whole assy., and 8 out 10 times, its the Film that fails in
the asssy
