Question about Sony VAIO PCG-K23 Notebook
Sony Vaio will not turn on
All of a sudden my computer shuts down, I waited for a few minutes than it was able to come back on but only for a few minutes than it shut it self down and now will not even turn on
  • kksouza18 Jun 22, 2009
    I checked everything from taking out the battery and only use the cord but their is absolutely no power. I'm not sure if my laptop just died and have to get a new mother board or ???
    Genius:
  • 2,785 Answers
Plz check the powersupply unit , ram
Posted on Jun 22, 2009
  • Rajkumar Bordoloi
    Rajkumar Bordoloi Jun 23, 2009
    plz check the power supply unit if it is ok then your motherboard have to be replaced. it will be better if you ask help your local service center
Comcast.net e-mail sign-in on Sony Vaio laptop is not working. will keep on bouncing back to 'log inpage'. my password and account work on any other computer. thanks
Go into system, find the wi-fi adapter and open it up. Choose uninstall and click on it. If windows asks you if you want to remove the software from the hard drive say no. Wait for uninstall to complete than shut down the computer, shut down, not reboot. Wait a couple of minutes than turn it back on, sign in and let windows find and reinstall the driver. It now should work. 9 times out of 10 this corrects this issue.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_c087e4b7d13c0163
Dec 22, 2013 | Computers & Internet
My Sony VGN-CR590 shuts down after 5-10 minutes. How can this be fixed? I'm not sure the fans are running.
A way to check to see if the machine is overheating is when you turn on the computer, there should be an option to hit F10 or F2 for the bios. In there, there should be a few temperature readings. Let the machine idle and in the bios if the tempature rises in there there could be an issue with the cooling for the CPU.
Jul 11, 2012 | Sony VAIO VGN-CR590E PC Notebook
It shut down automatically and won't turn on after that.
The computer/laptop is heated up too much on the same place. You have to wait about 5-10 minutes if it automatically closes, so it it gets cold.
Dec 29, 2011 | Sony VAIO Y Series Notebook VPCY118GXBI
Sony Vaio netbook will not connect to internet - says limited connection
That's usually your router, not the computer. Sounds like your computer is connected to your router, but IT is not connected to the internet.
I would suggest shutting down the computer, shutting down router, then the modem, plug the modem back in, waiit for lights to finish blinking (should be within a few minutes) then your router, once that's finished blinking, then turn on your computer.
Jan 15, 2011 | Sony VAIO VGN-NR160ET Notebook
My sony viao vgn-cs215j suddenly turn off by itself and it takes 20 minutes before i can re-start and use it again and after 15-20 minutes would shut off by itself again without any warning. what could be...
Sorry i nay be a month late on this thread... but better late than never. My Girlfriends sony vaio VGN-CS215J seems to be doing the exact same thing. After buying one of those computer fans that you rest the computer oneverything seems to be running normal. i would also recommend cleaning your fans inside the computer because dirt dust and grime can hold the fans back from cooling down the laptop efficiently and will cause the safety overheat shutdown to activate and shutdown your computer... that way it does catch on fire or fry any of your hardware inside of your computer.
If that does not work... your fans maybe malfunctioning or not functioning at all. this model of vaio has a grinding fan issue that can be very damaging to your cpu if not fixed.
hope this helps,
Mike Huffstutler
Apr 06, 2010 | Sony VAIO VGN-CS215J/W Notebook
Turning off
Perform power drain ( remove all accesories including the battery and the power adapter) press the power button for 1 minute.
Connect the power adapter only then turn on the computer - try using for more than 1 hour. If the computer does not shut down then the issue is the battery.
Run anti virus software.
If problem still persist it is a posible hardware issue. If you are still in warranty you can call sony and they can help you fix the issue for free.
Mar 27, 2010 | Sony VAIO Notebook
Sony Vaio PCG-6h4l laptop turns off for no reason. While using laptop on batteries it works fine and does not power off while using. But while using with electricity the laptop turns off for no reason,...
It could be that the laptop disables it's battery when you connect it with the power supply. When the power supply then fails it won't have enough time to switch back to battery. You'd best first try another power supply, and post back here if that doesn't help.
Jun 07, 2009 | Sony Computers & Internet
Sony VAIO RB30C (VGCRB30) PC Desktop Won't Turn On After reinstalling ram
Unplug the tower
Remove the ram and turn the tower on wait till it give you fast beeps. (telling you no RAM)
once that happens shut the system down by unplugging it again
Re-install your RAM and try to boot again
May 26, 2009 | Sony VAIO RB30C (VGCRB30) PC Desktop
Sony VAIO PCG-K23 Notebook Logo
226 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
