Question about Canon PIXMA MP980 All-In-One InkJet Printer
The printer display: paper out MT CTM
He printer display: paper out MT CTM
  • Canon Master
  • 365 Answers
Which paper tray is out.
The top or bottom?
Posted on Jul 24, 2009
2000 ranger wipers dont work
Do you know what a wiring diagram is ? How to use a DVOM - digital volt ohm meter to test automotive electrical circuit's ? Do you know anything about automotive electrical ? Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. Year , make , model and engine size . Under system click on body & accessories , then under subsystem click on wiper/washer . Click the search button then the blue link . Looking at the diagram I see the wipers are controlled by an electronic module (GEM) . The switch is an input to the GEM which controls relays to turn on the wipers . Do you know what DTC'S - diagnostic trouble codes are ?
B1431 Wiper Brake/Run Relay - Circuit Failure GEM/CTM GO to Pinpoint Test A . B1432 Wiper Brake/Run Relay Short to Battery GEM/CTM GO to Pinpoint Test A . B1434 Wiper Hi/Lo Speed Relay Circuit Failure GEM/CTM GO to Symptom Chart. B1436 Wiper Hi/Lo Speed Relay Circuit Short to Battery GEM/CTM GO to Pinpoint Test C . B1438 Wiper Mode Select Switch Circuit Failure GEM/CTM GO to Symptom Chart. B1441 Wiper Mode Select Switch Input Short to Ground GEM/CTM GO to Symptom Chart. B1446 Wiper Park Sense Circuit Failure GEM/CTM GO to Pinpoint Test D . B1450 Wiper/Washer Interval Delay Switch Input Circuit Failure GEM/CTM GO to Symptom Chart. B1453 Wiper/Washer Interval Delay Switch Input Short to Ground GEM/CTM GO to Symptom Chart. B1458 Wiper/Washer Pump Motor Relay Circuit Failure GEM/CTM GO to Pinpoint Test E . B1460 Wiper/Washer Pump Motor Relay Coil Short to Battery GEM/CTM GO to Pinpoint Test E . B1462 Seat Belt Switch Circuit Failure GEM/CTM REFER to Section 413-09 . B1466 Wiper Speed Not Switching GEM/CTM GO to Pinpoint Test C . B1467 Wiper Hi/Low Speed Circuit Motor Short to Battery GEM/CTM GO to Symptom Chart. B1473 Wiper Low Speed Circuit Motor Failure GEM/CTM GO to Symptom Chart
Symptom Chart Condition Possible Sources Action
  • The Wipers Are Inoperative
  • Fuse(s).
  • Circuitry.
  • GEM/CTM.
  • Multi-function switch (13K359).
  • Wiper run/park relay.
  • Wiper HI/LO relay.
  • Wiper motor.
  • DTC B1431.
  • DTC B1432.
  • DTC B1438.
  • DTC B1450.
  • DTC B1840.
  • GO to Pinpoint Test A .
Your best bet , take it to a qualified repair shop.
Feb 23, 2018 | Cars & Trucks
How do I get a wiring diagram for CTM 850
Hi there is a PDF instruction download type in CTM850 mobility scooter schematic. INCLUDES HS-890 or U can get in touch with www.ctmhomecare.com.they might b able to help .good luck
Mar 04, 2016 | Ctm HS 890 4 Wheel Heavy Duty Power...
Limited. What is causing battery drain?
To find out what is draining the battery do a parasitic draw test . How To Perform Parasitic Draw Test EricTheCarGuy Test to be sure , before replacing GEM module .I would also have the GEM checked for DTC'S - diagnostic trouble codes . I would also check the battery saver relay .
SECTION 417-02: Interior Lighting 2000 Explorer/Mountaineer Workshop Manual DESCRIPTION AND OPERATION Procedure revision date: 06/17/1999 Interior Lighting The interior lighting system consists of the following:
  • dome/map lamp
  • rear dome/cargo lamp
  • overhead console/map lamp
  • RH/LH vanity mirror
  • ash receptacle lamp
  • puddle lamps
  • interior lamp switches
  • interior lamp relay
  • dimmer module
  • battery saver relay
  • generic electronic module (GEM)
Generic Electronic Module (GEM)/Central Timer Module (CTM) Controlled Functions
The generic electronic module (GEM) is equipped on four-wheel drive vehicles with power windows. The central timer module (CTM) is equipped only on two-wheel drive vehicles without power windows.
NOTE: GEM/CTM diagnostics are compatible with the scan tool.
The GEM/CTM incorporates the functions of several different modules into one, and offers diagnostics to easily locate and repair concerns affecting the subsystems that it controls.
The GEM/CTM constantly monitors the systems it controls and reports a concern in the form of a diagnostic trouble code (DTC). A DTC can be retrieved with the scan tool through the communication link.
The scan tool is a menu-driven tester that allows the user to run specific tests. The scan tool can isolate faults in the GEM/CTM subsystems through a symptom-driven diagnostic procedure. Connecting the scan tool to the GEM/CTM communication link will not alert the GEM/CTM. If the GEM/CTM is "asleep" when the diagnostic connector is plugged in, the GEM/CTM must be "awakened". If the communication link cannot be established, turn the ignition to RUN.
NOTE: The GEM/CTM has a sleep function to minimize battery consumption. During the sleep mode, the GEM/CTM turns off all outputs and monitors only the following:
  • door ajar (driver door, passenger door, liftgate, LH rear and RH rear doors).
  • key-in-ignition.
  • key in RUN or ACC.
  • two-step unlock switch (unarm switch).
  • digital TR sensor.
  • illuminated entry request (remote anti-theft personality [RAP] module).
If a change of status occurs at one of these inputs while the GEM/CTM is "asleep", the GEM/CTM will "wake up." When the GEM/CTM awakens, it carries out an internal self-test, and begins normal operation. At this point, the GEM/CTM will have all of its functions operational.
The GEM/CTM will go into the sleep mode immediately after both of the following conditions have been met:
  • key in OFF or key not in ignition.
  • after 45 minutes with no change in any wake-up input.
The GEM/CTM control system has two modes of operation; the normal operating mode and the tester-dependent diagnostics mode.
Normal operation of the GEM/CTM can detect errors. An integral part of normal GEM/CTM operation is continuous diagnostic capability. Continuous diagnostics detects errors and changes the GEM/CTM control strategy. There is no warning lamp for the GEM/CTM; therefore, a DTC concern will direct you to the GEM/CTM. Examples of faults that may be detected during normal operation include:
NOTE: The GEM/CTM can only detect open circuit/short to GRD faults when the GEM/CTM is not energizing a load, and short to battery faults when the GEM/CTM is attempting to energize a load.
  • GEM/CTM continuous self-test (RAM, ROM, EEPROM, A/D checking).
  • output driver monitoring (open circuit/short to ground [GRD], short to power).
  • illogical combinations of input signals.
Dec 01, 2015 | 2002 Ford Explorer
Minolta DI450 error code C-0920
1st paper draw lift motor is jammed or burn out or the control board is bad. Check for paper behind the draw, also remove any paper from left side of draw.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 26, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
Mt HP Photosmart C6380 keeps wadding up the paper and gets jammed. It then says out of paper and when I clear it and press OK, it crinkles the paper to death. Please tell me how to fix this. There is...
Hp printer paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 09, 2010 | HP Photosmart C6380 All-In-One InkJet...
Service call error 125 Pulls paper to print then jams and stops Also multipurpose tray won't go into the down position.
125: Error
Error detected in MT home position.
1) is an Error Message displayed? Yes
Turn ON power again.
2)Does the Error take place again? yes
Replace MT
Oct 27, 2010 | Xante Ilumina Digital Color Press Printer
I have a ctm scooter the battries are charged fully when i switch on the scooter will not work switch off and on again it then will travel a few feet before stopping
The joystick will display a sequence of flash codes. Count them and find the count here: This could be several issues, But the flash code will tell you for sure.
1. Stall Timeout, Joystic out of neutral
2. Battery Voltage too over 32VDC hi or too low under 17VDC
3. Left motor Fault
4. Right Motor Fault
5. Left Brake Motor fault
6. Right Brak Motor fault
7. Shark Control Module Faul
8. Power Module Faul
9.Shark Module Faul
Contact me Direct 909-590-1388 x115 CTM HOMECARE OFFICE
Mar 07, 2010 | Ctm HS-2800 Power Wheelchair
Time delay relay for interior lights
I would suspect you have a bad door switch on one of the doors or liftgate. They are usually plunger switches. Try pusing them in one at a time and see f the lights go out. Hold it in long enough to account for the time delay.
please rate if this helps you.
  • The Courtesy Lamps Stay On Continuously
  • Circuitry.
  • GEM/CTM.
  • Ignition switch.
  • Interior lamp relay.
  • Dimmer module.
  • Door ajar switch.
  • DTC B1322.
  • DTC B1330.
  • DTC B1334.
  • DTC B1338.
  • DTC B1371.
  • DTC B1574.
  • DTC B1610.
NOTE: GEM/CTM diagnostics are compatible with New Generation STAR (NGS) Tester.
The GEM/CTM constantly monitors the systems under its control and reports a concern in the form of a diagnostic trouble code (DTC). A DTC can be retrieved with NGS Tester through the communication link.
NGS Tester is a menu-driven tester that allows the user to run specific tests. NGS Tester can isolate faults in the GEM/CTM subsystems through a symptom-driven diagnostic procedure. Connecting NGS Tester to the GEM/CTM communication link will not alert the GEM/CTM. If the GEM/CTM is "asleep" when the diagnostic connector is plugged in, the GEM/CTM must be "awakened". If the communication link cannot be established, it is advised to turn the ignition to RUN.
  • Door ajar (driver door, passenger door, liftgate, LH rear and RH rear doors).
  • Key-in-ignition.
  • Key in RUN or ACC.
  • Two-step unlock switch (unarm switch).
  • Digital TR sensor.
  • Illuminated entry request (remote anti-theft personality [RAP] module).
If a change of status occurs at one of these inputs while the GEM/CTM is asleep, the GEM/CTM will "wake up." When the GEM/CTM awakens, it performs an internal self-test, and begins normal operation. At this point, the GEM/CTM will have all of its functions operational.
  • Key in OFF or key not in ignition.
  • After 45 minutes with no change in any wake-up input.
The normal operation of the GEM/CTM can detect errors. An integral part of the normal GEM/CTM operation is the continuous diagnostic capability. Continuous diagnostics detects errors and changes the GEM/CTM control strategy. There is no warning lamp for the GEM/CTM; therefore, a DTC concern will direct you to the GEM/CTM. Examples of faults that may be detected during normal operation include:
NOTE: The GEM/CTM can only detect open circuit/short to GRD faults when the GEM/CTM in not energizing a load, and short to battery faults when the GEM/CTM is attempting to energize a load.
  • Output driver monitoring (open circuit/short to ground [GRD], short to power).
  • Illogical combinations of input signals.
Apr 28, 2009 | 1998 Ford Explorer
Printer error reads 'Paper Out MP CTM'
Sounds like the document that is being sent to the printer, or the one if pending prints are present, has a page size set to other than what the printer has its set to for the tray feed (or tray feed is set wrong), so it is defaulting to the Manual Feed for insertion of correct medium CTM (not sure if int. but thats maybe a country thing we use A4, ENV and B5 mainly
Dec 01, 2008 | Epson AcuLaser C3000 Printer
Load paper
Hello Maria,
There must be something obstructing the Auto Sheet Feed Assembly, you need to clean the paper path, use a vacuum cleaner or look deep into it if you can find something there if the problem persists you should take your printer to the service center and get it serviced.
Warm Regards,
Manoj Joseph
+91 9352008418
Jun 17, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP980 All-In-One InkJet Printer Logo
75 people viewed this question
old marine
old marine
