Question about Samsung Televison & Video
I have a Samsung Tantus SP48T5HP rear proj. The green had been out of place for a few weeks, and i was just living with it...however now it wont even turn on! If i put it on standby the light comes on, then hit power on the remote and it makes a dull high pitched squeal. Anyone got any ideas or do i push it out onto the trash pile?! Thanks, Dave
  • 1694 Answers
SOURCE: rear projection problem. samsung sp48t5hp
The board sits up high above the larger boards....one screw &
four plugs sounds right. Bad part is STK392-040. If you decide
to repair----replace both IC's for reliability. I use Panasonic brand
to eliminate re-calls. Re-set alignment....done....T.
Posted on Oct 31, 2007
SOURCE: TV Won't Turn On
hi there i have the exact same tv and the exact same problem, i was just wondering if it was the hv splitter if so can you please let me know thank you
Posted on Jan 24, 2008
  • 317 Answers
SOURCE: HD52W56 RCA Powers up with Sound But has No Picture High pitch squeal
try reset.
Posted on Aug 03, 2008
SOURCE: Phillips Pronto Remote high-pitched squeal from remote
www.servicewidetech.com
Posted on Oct 30, 2008
SOURCE: when tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Posted on Jan 04, 2009
Won't start
The symptoms are indicative of a power supply problem. The age of your TV can influece your repair/discard decision.
Jan 21, 2014 | Samsung TSK3092WF 30" TV
Where is the bulb located in a Samsung Tantus model SP42W5HP?
If this model even uses one-(check owner manual which will have instructions if it does) it will be behind a door on rear of the unit in most cases--this unit is so flat up front I doubt it is there but could be.
GOOGLE is a good place to search based on the model number "manual" or "lamp replacement" etc.
Mar 31, 2012 | Samsung SP42P2S Television
I have a 60 in. mitsubishi hdtv. i just got it and the tv wont turn on and the green timer light kept blinking. now the green light wont even blink. thank you
Send an email to Paul on this Hi Def forum and he will send you detailed instructions for repairing your set inexpensively. Hope this helps
http://www.highdefforum.com/rear-projection-tvs/58189-blinking-green-light-death-frequent-prob-w-mitsubishi-rear-proj-widescreens-5.html
Jun 01, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Samsung Tantus (SP-43J8PF) Has Green Tinge - Easy fix?
You may try to get into the service menu and adjust screens/drives level(procedure below). But first turn the color off completely and adjust you brightness to mid-range, what you`ll want to do is a grey raster or bring it as black and white as you can while adjusting the red/green /blue guns or tubes. Also get a piece of paper and pen because you`ll want to record the original values of the items you may change. You want to go into the adjustment menu. Hope this will help Good luck
In quick sequence on the remote press:
MUTE - 1 - 8 - 2 - POWER buttons.
The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
Select the function and use the VOL+ button to enter.
Save settings and exit by pushing MUTE twice then POWER .
Nov 19, 2009 | Samsung PLH403W 40" Rear Projection...
Samsung Tantus Picture Problem. Green Yellow Black Hue
it seems that your unit got loosed contact.i mean it needs resoldering.call a technician to do further troubleshooting.
May 11, 2009 | Televison & Video
Samsung Tantus 119cm 100Hz Rear Projection Problem
i have a samsung hdtv and direct tv is attached to it. and i can't get a better picture than 480 i when the tv is capable of 1080i. ? when i change the cable box higher its just blurry. what do i do?
Oct 14, 2008 | Zenith E44W46LCD 44" Rear Projection...
Samsung Tantus problem
your main power supply is gone out
Aug 30, 2008 | Samsung PCH521R 52" Rear Projection...
Samsung 52" tantus pch521r convergence panel
I found a this SITE that carries that convergence assembly for your TV.
Good Luck.
Mar 10, 2008 | Samsung PCH521R 52" Rear Projection...
Rear projection problem. samsung sp48t5hp
Oct 30, 2007 | Televison & Video
Televison & Video Logo
152 people viewed this question
Jerry Greenberg
Jerry Greenberg
