Question about Kitchen Ranges
Tin foil baked onto bottom of gas range oven
New gas range 7/2007. Tin foil placed on bottom of oven while heating. Now baked on and unable to remove. Any ideas as to how to remedy this big 'oops'?
Re: tin foil baked onto bottom of gas range oven - Kitchen Ranges
Rape it
Posted on Oct 09, 2008
0 characters
3 Points
I had foil in the bottom of my lg stove and the foil is now baked into the bottom of the pan, will vinger and baking soda get the foil off.
You may have had some sugary spill that has caused this to happen. If this is a self-cleaning oven, I would not put any chemicals of any kind on it and it is unlikely to free the foil. Try this: remove the oven racks, heat the oven to ~250F (120C) and keeping fingers away from the oven's interior, grasp the edge of the foil and lift it carefully. If it is glued from some sugary deposits, this should be hot enough to flow the deposit and allow you to remove it in part or completely. Good luck-
Mar 29, 2011 | Kitchen Ranges
Oven door will not remain fully closed
Noiselab is not correct for all cases. As Buzz says, if the springs are strong then the foil fix works and works really well. Refer to attached photo for guidance in conjunction with instructions below. Note my possibly simpler answer at bottom.
I cut some short narrow strips (about 4mm x 20 mm) from a tin can and folded them over into a flattened "U". You can back off the large Phillips head screw on the frame of the oven where the door hinges are inserted and sit the tin over the little plate that is held by these screws and then tighten so that one end of the "U" sits between the oven chassis and the adjustment plate. If it still doesn't quite close add more tin as required. Refer photo for terminology.
Now the simpler solution which I didn't try but which would probably work after I contemplated the problem in retrospect is this. The reason I didn't think of this was that I thought the hinge went into a tube or slot. Later I realised it is just a simple cantilever design which is why the tin foil solution works (ie lifting the middle support of the cantilever produces a corresponding closure of the door). When I inspected the large Phillips head screws to insert the tin foil these were completely loose. Try this first then. Slide the adjustment plate up as high as the tolerance of the Phillips screw allows and then tighten it off hard. This will raise the bottom edge of the plate just as the tin foil method does. If not enough then proceed to the tin foil method.
Jul 09, 2010 | AGA ILVE M-90F-MP Dual Fuel Range
Things bake unevenly. Cakes get brown on edges
first make sure you are not blocking a rack.air needs to circulate from the bottom to the top.never cover a rack with tin foil or a large pan. if alls good you may have a temperature problem.check temp if its off raise oven temp as high as it goes hold bake button untill it beeps it will display 0 go up to raise temp up down to lower you can only adjust 35 deg.Good luck!
Jan 21, 2010 | Kitchen Ranges
Does putting tin foil on the bottom of the oven reduce the life of the element
No. That must be an old wives tale. Never heard of it. The problem with foil on the oven bottom is it gets covered with grease and may fire-up. Now on the other hand if your oven catches fire from grease build-up on the foil, well that will shorten the elements life and maybe yours.
Oct 17, 2009 | Force 10 Galley Range
Kenmore 911-4658811 will not set or heat up above 170 degrees
pull the range out, unplug it, remove the small tin door, ohm out your bake element,
if its gas well then thats your ignitor
Oct 03, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
How do I remove tin foil baked on brand new oven bottom?
Unfortunately you can't remove that foil, you will end up doing more damage to the liner. the only thing you can do is replace the liner. And it's a big job, if the manufacture makes a replacement part for your unit, and if they do it will be costly. Your warranty will not cover it.
Jan 09, 2009 | Kitchen Ranges
How do I remove tin foil baked on brand new oven?
Unfortunately you can't remove that foil, you will end up doing more damage to the liner. the only thing you can do is replace the liner. And it's a big job, if the manufacture makes a replacment part for your unit, and if they do it will be costly.
Good luck....
Tin foil stuck to bottom of new ge monogram oven
I had the same thing just occur. GE is now telling me the only fix is to buy a new range. Great. $10K for a range that I use once.
Jan 04, 2009 | GE Monogram ZDP48L4GHSS Dual Fuel...
Yes, we were a couple of dummys when we received our brand new LG stove, with convection oven,glass top and very fancy, and we put tin foil to cover the bottom of the stove and of course yesterday when I...
I really don't know what to tell you. During the clean cycyle the metal probably melted and is permantly sealed to the bottom. You are lucky the oven still works. Sometimes using foil will destroy sensors or other things. NEVER use foil in ANY oven!!!!! The only exception is to partially cover the shelf underneath something you know is going to make a mess. Even then don't cover more than about 60% of the rack.(Never do this in a convection oven as the fan will blow the foil ) Also NEVER!!! allow foil to come in contact with a hot burner. It will melt to the smooth top or coil.
Jul 07, 2008 | LG Kitchen Ranges
Kitchen Ranges Logo
899 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
