Question about Code-Alarm Code Alarm Transponder
Alarm keeps going off
Very random, but alarm goes off at least once a week, when it does, it goes off and off and off, then it will settle for a few days, very confusing
  • steve106 Mar 06, 2010
    yes its a factory alarm, its a 55 plate, 06 feb registered
    mondeao 2.0 tdci
    New Friend:
I have a 2009 kia rio with the same problem.. the dealer said its a factory alarm & they cant disarm it. is there anything i can do?? i cant have the alarm going off all night & keeping my neighbors up!!
Posted on Nov 27, 2013
  • 344 Answers
Is it a factory alarm, what is the year make and model please
Posted on Mar 06, 2010
I have a 57 civic hatchback and for no reason the alarm keeps going off randomly mainly at night. Some nights is fine but once it goes of I can set the alarm watch it from inside for a few minutes and it...
Does it do it with internal sensors disabled? Not familiar with your car, but handbook should say how to do it, either by button inside, or certain key fob press technique etc.
if not, the issue is with the internal sensors.
if it does, then Check boot and bonnet and door switches for poor contact, movement, bad connection and power supply.
Jan 19, 2018 | Cars & Trucks
Disable factory alarm
The alarm tripping is often caused by a bad door or hood switch. Since the hood switch is always exposed to water and corrosion, that one usually goes bad first. Check that out. And no, you can't disable it.
Nov 22, 2017 | Kia Spectra Cars & Trucks
2007 Sonata car alarm(security alarm) randomly goes off--it's happened when it's locked and unlocked and all times of the day. The Keyfob stopped working about 3 weeks ago and then randomly worked now and...
over sensitive sensor in the car could set it off randomly... bonnet boot, door handles.. one of the motion sensor thingiis, if fitted. the beeper issue could be the position of the incoming sensor of the alarm it self.. if it is an imboliser as well then there is whole other range of issue.. turn it off or at least disconnect the siren.. or you could just pay some one way too money to fix the problem for ya... good luck
Sep 02, 2010 | 2007 Hyundai Sonata Limited Sedan
My car alarm randomly goes off on my 06 Charger.
I had an issue with an Aveo that would do the same thing... what I did to correct that problem was to diagnose all the alarm switch's.
I took all door switch off inspected them they looked fine I then check the hood switch and when I took it off I noticed it was corroded inside since I changed it the alarm never came on again.
I would check your hood switch it maybe the same.
Good luck
Oct 09, 2009 | 2006 Dodge Charger
Car horn and lights sound alarm @ random times while parked
Alarm Disarm LIGHT GREEN (-) DRIVER'S KICK PANEL
Jun 10, 2009 | Aiwa CDC-X504MP CD Player
The alarm on my 2000 Chevrolet Silverado keeps going off for no apparent reason.I check the doors and unlock it with the remote and after relocking it, the alarm goes off again after 5 or 10 minutes. The...
each door latch has a sensor one of those could be bad ( the ajar switch) Needs to be hooked up to a scanner at a dealership or a local mechanic may have a scanner that could help
Mar 23, 2009 | 2001 Chevrolet Silverado 1500
98 mustang gt factory alarm
I had this problem with an aftermarket alarm on my accent once.  Check your battery cables and terminals, if there is a bad connection or any corrosion this will cause the alarm to act up.  if that is not the problem, try the fuse box, see if there is a fuse labeled alarm or something like that, if nothing else important is on the same fuse just pull it out.  Or you could just locate the horn for the alarm and cut and cap the wires on it.  That would disable the alarm from making any sound, all other functions would remain intact.  good luck.
Jan 22, 2009 | 1998 Ford Mustang
Alarm goes off randomly
Sir, first check that the status of automaic updates of date & time on your handset. If that is off please turn it ON as is ur handset gets resetted from time to time it will take the service providers date & time which is almost accurate. If this doesnt help then try replacing the battery.IF that doesnt help then only one thing can be done A software Reflash. Take your handset to a repair workshop & have the firmware flashed. Thats the final solution.
Thank u
Oct 15, 2008 | Nokia 1600 Cellular Phone
Code-Alarm Code Alarm  Transponder Logo
736 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
