Question about Panasonic KX-TA30850, 12 Programmable Keys, Monitor Speaker Phone (ASONICKXTA30850)
Helppppppppppppppppppppppppppppp how i set programing in kxt-30820
  • Panasonic Master
  • 2,460 Answers
The 30820 is probalby plugged into a 30810 with a 30830 phone plugged into extension 11. It depends on WHAT programming you're trying to do and what version software you have in the 30810. If you're programming extensions in the phone, it's easy, just flip the switch on the back to PROGRAM, press a button and dial the 2 digit extension and STORE. The 12 PF buttons IIRC can call outside if you insert "9" or 81-83 as an access code, again following your input with a STORE.
When you finish, move the programming switch to SET.
Anything beyond that requires a manual or station user's guide. The user's guide is here: http://www.microtelcommunications.com/tva/panasonic_kx-t308xx_kx-t61610_user_guide.pdf
The system manual requires information from the tag on the KSU.
It's been awhile, but look on the bottom of the KSU cabinet and read the data on the silver tag with black lettering. Look for a number in a circle. It will probably be no circle, 2 or 3 near the upper right of the model number. If you don't have a system manual and need it, find the tag info and post back.
Carl
Posted on Jun 22, 2009
RETRIEVE VOICEMAIL FROM PANASONIC KXT-7731
In the settings menu there will probably be a menu for voicemail somewhere. There should be a number for connecting to the voicemail delivery service. If you are with O2 it is 901 in UK.
Aug 22, 2014 | Panasonic Kx-ta7731 Kxta7731 Kxt 7731 7731...
I am using Panasonic kx t7730 and all my phones are ringing while getting calls from outside which i dont want.I want to ring only the reception.please help me...
My 773x phone is attached to a TAW-848 Key Service Unit and it has a set of programming instructions. So does the TA series or the KXT series KSU's.
Ringing is programmed in those units.
Carl
Jun 06, 2012 | Panasonic KX-T7730 Corded Phone
I just bought my panasonic units and i cant change the date model number of the phones kxt-7730 hybrid system tes-824 i want to change the date i have tried program 0 but it doesn't work i get the 3 beeps...
Since that's done from SYSTEM program 000, it seems likely that you 1. Aren't using extension 101 and 2. Didn't log into the system for programming
Try it again.
Carl
Apr 20, 2011 | Panasonic KX-T7730 Corded Phone
How do i program the time for my pansonic esa phone
First you find the SET PROGRAM switch on the cabinet and put it into PROGRAM. Now, from a display phone connected to ext 11, you dial 00 and use the keypad, FWD button the AUTO ANSWER buttton and the STORE button to step through the various settings. The CONF button goes back.
Return the switch to SET when you're finished.
Carl
Nov 17, 2010 | Panasonic KXT 61610 R3 Key Service Unit...
I use Panasonic Kx-T7730 as a propitiatory telephone. When someone calls from outside, All phones on the network ring. It had to ring only on the proprietary telephone.
The 7730 plugs into a Panasonic phone system. That system (KXTA, KXTD, KXT-something) has programming. Each system has a manual or set of manuals to program system ringing. Comment back or search the internet or your files for that manual and it can be reprogrammed.
Carl
Jul 14, 2010 | Panasonic KX-T7730 Corded Phone
Have Onkyo remote trying to program by Samsung
The Samsung DVD codes for Onkyo remotes are: 30490, 30573, 30820, 31075, 31635, 32329, 32489, & 33001.
You can download Onkyo remote codes here.
I hope that helps.
Mar 27, 2010 | Samsung DVD-HD870 DVD Player
How to change the time for daylight saving on kxt7730
If this is an analog system (ie TA-308/TA-624/TA-824-KXT-61610/etc) or a TD digital system, then you have to log into the System by a program switch on the cabinet or PROGRAM *#1234 at the first extension (usually 101 or 11) and change the time via program 00 or 000.
If the system is a TAW, TDA, or NCP, you can set the automatic daylight savings clock times for the next 20 years in programming.
For the short time, the programming instructions will change it until April.
If you have CID, the CID source will normally set the clock at the first call past 2:00 AM.
Carl
Oct 28, 2009 | Panasonic KX-T7730 Corded Phone
In my firm i have panasonic kx-t7030x. for outside calls i must press 9 to get signal. but now when i press 9 there is a message "CO Not Assigned''. How to solve this problem? thanks
A couple of ways. The system is probably a TA-624/824 box. In programming, you may have unassigned the lines on the set. That's checked by putting the switch in the back of the phone to PROGRAM, pressing the line buttons and reading the display. It will say CO 1, 2 3 etc. One of them will be missing, and it can be reprogrammed by dialing 0 + the missing number. Finish by pressing STORE and put the switch back to SET.
If that doesn't work, then you need to look in the Programming PM Manual and look at how to program the system. Program 400 sets the lines in use in a TA.
Of course you may have one of the other systems like a KXT-308 or 616 and this stuff may not apply :-)
Carl
Sep 03, 2009 | Panasonic Lands Phones
Lost panasonic KXT-7730 password
If you lost the password the only way to get into programming mode is to reset the telephone system to factory default. If you are not accustomed to all programming features this is not recomended because resetting will whipe out all programming including ringer settings, extension names, speeddials, routing and class of service. If you still want to reset let me know.
Dec 10, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic kxtd816 with caller id card kxtd-193 problem kxt-7431
All Panasonic display phones, both analog and digital 7xxx series phones support CID. It requires 5 or 6 program adjustments as outlined in the manual. With luck, you may be able to just turn it on in 406, but your area code needs to be set if you have 7 digit local dialing, you need to tell the system if you want CID to adjust the clock daily, SMDR display, etc.
The 1232_PG lists all the steps. If you don't have a manual, you really need to get one. Post back and we'll see what we can do.
Carl
Dec 05, 2008 | Panasonic KX-T7431 Corded Phone
Lands Phones Logo
73 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
