Question about Lands Phones
Trying to increase the volume on a Telstra F5050 handset. I think it needs to be programmed- there is a prog button and 'vol' written above button 4 but I cannot workout how to make the volume louder
- Press Telephone symbol to get ring tone
- Press and hold "Prog" until a 'P' appears on the display
- Press "4" then press "1" - "5" to select the volume you want
- Press "Prog" to confirm
Posted on Jun 22, 2009
Turn ringer on
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
Sep 07, 2013 | Vtech T2326 Cordless Phone
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
Where is the volume control on the stupid phone, it is nowhere in the menu and no buttons or slider control
While on a call, press down/CID to decrease or up/DIR to increase the volume. (page 11)
To change the answering machine volume, use the VOL- and VOL+ buttons. (page 31)
To change the ringer style, press PROG, use up/down to select "RINGER". Use up/down to select the desired style and press SELECT. (page 9)
The above page numbers are from the manual at
http://vt.vtp-media.com/ecp/documents/product_Product/606/UserManual/1644/ia5864_manual_bkm.pdf
Jun 21, 2011 | Vtech ia5864 Cordless Phone
How do I reset ringer to "on" if it is set on "off"
Hello
Press "Prog" on the handset.
Press the arrow button beneath the phone's display until you reach "Ringer," then press "Select."
Press the arrow button until you reach "Ringer On," then press "OK." The phone should beep to confirm your selection.
Method Two
Press the down arrow key until you reach "Ringer Vol," then press "Select."
Press the up arrow key until to increase the ringer volume you want then press "Select."
Apr 11, 2011 | Vtech 5.8 Ghz Handset Cordless Phone...
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
Dec 15, 2010 | Kenwood DNX7120 Car GPS Receiver
I want to change the nombers of the rings to get start the answering machin
These are the instructions from the manual, which I found here:
http://safemanuals.com/user-guide-instructions-owner-manual/GE/21028GE3-A-_E
RING SELECT (FOR ANSWERING MACHINE)
This feature lets you select the number of times you want to phone to ring
before the answering system answers a call.
1. Make sure your phone is OFF (not in talk mode).
2. Press the MUTE/PROG button to go to the main menu.
3. Press CID/VOL (up or down) button to scroll to HANDSET SETUP.
4. Press MUTE/PROG button to confirm.
5. Press the CID/VOL (up or down) button to scroll to the RING SELECT menu.
6. Press MUTE/PROG button to enter the menu. RING SELECT 3 4 5 6 TS shows in the display.
7. Use the CID/VOL (up or down) button to scroll to the your selection. The default setting is 5.
8. Press the MUTE/PROG button to confirm. You will hear a confirmation tone and the new setting shows in the display.
NOTE: If you select Toll Saver (TS) the unit answers after the 3rd ring if there
are NEW messages, OR the unit answers after the 5th ring if there are NO new
messages. This allows user to access their answerer from another location and
then hang up after 4 rings to save long distance charges.
Oct 13, 2010 | GE 21028GE3 Cordless Phone
How to increase volume
To change the ringer volume: while the phone is on the hook press the Vol + or Vol - button. The phone rings according to the current setting. Tap the Vol + or Vol - button to adjust the volume one setting at a time. The phone stores the setting after the last button press.
To change the speakerphone, handset, and headset volume: while the phone is in use in the desired mode, press the Vol + or Vol - button. The phone stores the setting after the last button press.
The above is from pages 14-15 of the manual at
http://www.rca4business.com/products/pc/pdf/instruction-book/25424RE1.pdf
Jun 11, 2010 | General Electric RCA-25424RE1 4-Line...
Very low volume on 'handsfree' option; whereas the vol. for the line button can be quite loud
Hi.
The Volume function of that phone is controlled by the up down vol button on the phone. the only time it does anything is when that function is being used. ie. when you have the handset in hand the vol buttons control the handset volume, while the phone is ringing the buttons control the ringer volume etc.
Dan
Oct 09, 2009 | NorStar M5316 Phone, NT4X42 (Refurbished,...
I dont know how to adjust the ringer volume
The manual is available for free download from www.manualslib.com
A Google search on "vtech t2326 manual" will take you right there .... follow their site instructions,
enter the "spam protect" numbers and choose "download the .pdf file" Be careful of clicking on the
advertising that might take you into strange areas for other purposes.
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: 1" ( or "RINGER: 2 or : 3 or : 4 or : OFF" )
10. ...and so on, cycling through the four choices: when you decide to select one, press the "SELECT" end
11. The display light will go out, the phone will chirp in acceptance, and be ready to use the chosen ringer. --
To preload names & numbers into the DIRECTORY is a bit more arduous but not difficult; there is
a limit of 10 entries after which attempting to add another will result in a "MEMORY FULL" alert
being shown. Hint: during name entry, the "VOL -/CID" button will backspace/erase letters and the
"VOL +/DIR" button will enter blank spaces. Letter selection is familiar to text messaging ie, the letter B
is a result of "22" being keyed, the letter R is "777" etc.
Good luck !
Jun 08, 2009 | Vtech T2326 Cordless Phone
How is ringer volume adjusted?
VOLUME
While talking, press the VOLUME buttons (left and right
arrows) to control the volume of the handset's earpiece.
There are four volume levels. Press the right arrow (+)
button to increase the volume level, and press the left
arrow (-) button to decrease. VOL 1 is the lowest level and
VOL 4 is the loudest.
Jan 02, 2008 | GE Cordless Phone 900 MHz
Lands Phones Logo
297 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
