Question about Viper Vehicle Parts & Accessories
Will alarm enable my car from starting?
My car will not start due to alarm. If I hit the cut off switch will it start up again
Probly
Posted on Jun 23, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I have a 95 Chrysler Lebaron that's alarm is messed up. It randomly activates itself (I don't hit the lock switch or anything.) When I first got the car, I was quickly able to disable the alarm by...
You can try the passenger side of the door to enable it, and disable it, that all you can do. Or if you know someone who know how to disable the alarm an auto electrician are the only one who know how, the only thing i will do is speak it and not give details first they cut the door alarm. they dont have too but sometimes autodoor lock get in the way. they jump the starter relay permanetly and its done I do this for customer left and right It faster and cheaper alarm are headache and the market to remove is big yours is easy its OBD1 . find a person who know his skill.
Apr 30, 2011 | 1995 Chrysler LeBaron
Car
Your keys are prob. worn. My car did the same thing until i got very expensive new keys made.
May 14, 2009 | 1990 Lexus LS 400
Dash reads start disabled;due to theft sysytems;wait three minut
did you replace the fuse.if so try to get the alarm reset location,it could be in the stupidist place like my pathfinder you have to put the key in the tailgate and turn it to glass side and hold it for 20 seconds.and then hit the hidden reset switch under the rear carpet.
Feb 26, 2009 | 1995 Cadillac Eldorado
Ford Fiesta Quartz 1995 - alarm
If you have a remote, use it to cancel the alarm after battery is connected. Also look for a valet switch that overrides the alarm. Have to turn the Key on then hit the valet switch. If car will start but has alarm sounding find the speaker and cut the wire.
Jan 18, 2009 | Vehicle Parts & Accessories
My car alarm is blinking but the remote doesn't work. I already replaced the battery to the remote so I know that's not the problem. If I open the car the alarm goes off and doesn't allow me to start the...
You need to first look under the drivers side dash area near the hood release/fuse panel area and see if there is a valet switch. The switch will look like a little toggle or a push switch. After you locate it, turn the ignition switch to the on position(dont start it) and flick the valet to the opposite position it is in now. If done correctly in most cases the red system light will stay a constant instead of off or blinking indicating you are in valet mode. Next try to start the engine. If this doesnt work you need to remove the alarm system and repair the ignition switch wiring or replace the electrical portion of the ignition switch. The aftermarket alarm cuts into the ignition switch wires and bypasses the start circuit through the alarm module. When disarmed the alarm completes the circuit and allows the car to start. Good luck hope this helps and please rate this.
Nov 05, 2008 | 1997 Nissan.5 Altima
you can try switching the key to the "on" position then open the hood and disconnect the negative terminal of the battery and reconnect after 2minutes. this will allow the alarm to be '"reset" and will recognize that you have the key for the vehicle.
Aug 15, 2008 | 2003 Toyota Corolla
Bought car and wont start due to alarm. don't know how to override?
say i have a problem were my car alarms is activated and my car wont start unless i push it...i need to disconnect the alarm...HElP
Jul 24, 2008 | 1996 Volkswagen Jetta
Electrical
Go inside the vehicle,dont put key in ignition, leave driver's door open, press the auto lock button on the driver's door, now close door while you are inside and watch on the dash the alarm enable itself, once it stops flashing open the door, this will set off the alarm, lights flashing horn blowing. Now take the key and put it in the drivers door and turn the key to stop the alarm. Now start you vehicle. If you want you can take the glove box apart to get to the vehicle security module to remove it. Dont unplug it unless the vehicle is running (must be running due to back up on computer) unplug the module and you will never have another problem with the security again and it does not effect your powerlocks.
Jul 09, 2008 | 1995 Jeep Cherokee
Vehicle Parts & Accessories Logo
96 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
