Question about Sharp AR-5316 Advanced Digital Imager Copier
Out off paper - Sharp AR-5316 Advanced Digital Imager Copier
  • 1,555 Answers
Remove the power cable and printer cable for few minutes and then connect again. If this does not solves your problem open the cartridge container remove cartridge clean the container and the cartridge plus check for any bits of paper. If this is not solving the problem then your paper sensor is faulty call the technician for replacement.
Thankyou for using free fixya utility - rating from your side would be appriciated
Posted on Jun 22, 2009
My HP Laserjet 4L has started jamming paper when I try to print more than one page.
Here is some tips to avoid paper jam..
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams, reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what paper you should use with your printer your printer documentation will list the paper compatible with your printer.
  • Do not mix the paper you're feeding into the printer at one time. If you need to change the paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • If your printer uses a slot or tray for the paper make sure to not push the paper too far into the slot or tray.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
**If you need any kind of technical assistance you can contact support cell at here
Feb 26, 2013 | HP LaserJet 4L Printer
Button next to the button on/of flashes 3 times - still - 3 times etc
The light is the indication of a Paper feed problem,
Either the printer is out of paper:
a Load paper.
OR
b Press the Paper Feed button.
If the paper is jammed Then
Do not load too much paper in the sheet feeder. Depending on the thickness of
your paper, the sheet feeder can hold up to 100 sheets of paper or 10 mm (0.39 in.).
You do not force the paper down into the printer when you load it. For example, A4
size paper should extend above the top of the paper support. (Letter size paper
should align with the top of the paper support.) Make sure the paper support is fully
extended.
The paper guide is against the left side of the paper.
The paper guide does not cause the paper to bow in the sheet feeder.
May 02, 2011 | Lexmark JetPrinter Color Z33 InkJet
The printer prints the paper out to the side and then causes a paper jam
As the following paper may cause problems in the printer, do not use them:
- Thick paper: Paper heavier than 105 gm2 (28 lb) (corrugated paper, etc.)
- Thin paper: Paper lighter than 64 gm2 (17 lb) (tracing paper, thin letter paper, etc.)
- Paper with no rigidity
- Folded, wrinkled, or torn paper
- Wet or soiled paper
- Paper smaller than 54 mm (W) x 86 mm (H) (2.13" x 3.39") (sheet feeder)
- Paper smaller than 89 mm (W) x 127 mm (H) (3.50" x 5.00") (cassette)
- Non-rectangular paper
- Paper with adhesives
- Paper with holes (However, loose leaf can be used in the sheet feeder only.)
- Paper in bound form (such as a notebook)
- Photo postcards or postcard with image seals
- Non-empty envelopes
- Envelopes with double flaps or flaps with adhesive
- Embossed or coated paper, post cards, and envelopes
- Newspaper, flyers, tissue paper, etc.
- Media other than paper, such as cloth and plastic
- Folded reply post cards
Oct 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
IBM 1332 printer error #241 Paper jam
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
  • Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
Oct 04, 2010 | IBM Infoprint 1332 Laser Printer
How do i fix a paper jam on my printer?
One of the more common problems with printers as it relates to paper jams, is that the paper stacked in the tray hasn't been fanned. What I mean is, it's like holding a paper-back book in your hand and skimming quickly through the pages with your thumb as your other hand holds it at the spine. Try this as a remedy if your printer jams often.
Hope this helps. :)
Oct 02, 2010 | Office Equipment & Supplies
MY DELL 968 ALL IN ONE PRINTER JAMS PAPER. WHAT TO DO ? TRIED FLUFFING PAPER, CHANGE SETTINGS, UNPLUG-REPLUG. NOTHING WORKS
Please post your feedback and Vote if the poblem resolved as per your satisfaction.
Aug 15, 2010 | Dell 962 Photo All-In-One InkJet Printer
Help i have a paper jam!
Jul 20, 2010 | Epson Stylus NX300 All-In-One InkJet...
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
How do I load paper to print?
Hi mattside92
1) If the paper support flap is open, close it, and then pull the paper tray completely out of the machine. Lift the output paper tray cover.
2) Press and slide the paper side guides (1) and paper length guide (2) to fit the paper size.
3) Fan the stack of paper well to avoid paper jams and misfeeds.
4) Gently put the paper into the paper tray print side down and top edge first. Check that the paper is flat in the tray.
5) Gently adjust the paper side guides with both hands to the paper.
Make sure the paper side guides touch the sides of the paper.
Note
When you use Legal size paper, press
and hold the universal guide release
button as you slide out the front of the
paper tray.
Note
Be careful that you do not push the paper
in too far; it may lift at the back of the tray
and cause feed problems.
6) Close the output paper tray cover.
7) Slowly push the paper tray completely into the machine.
8) While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap
Good Luck, and don't forget to leave a rating
Thanks
Mark
Sep 29, 2009 | Brother MFC-440CN InkJet Printer
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
