Question about D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
D-Link DES-1016D make the network failure
I plug a Cat 6 on the D-Link DES-1016D switch port cause whole network LAN fail. Is there any solution for this problem. Thanks for reply.
  • tkk_pg Jul 01, 2009
    This is not a new switch. There is 10 computers was connected to the switch over 3 years and another one link was connected from the switch to main LAN network. We call this link as uplink. We found this uplink with cat5 cable is not enough bandwidth to handled network traffic created from the 10 computers.
    We had decided upgrade the exist cat5 to cat6. Problem is coming. This new cat6 cable will cause the whole network LAN fail. After exchange back the new cat6 cable to old cat5 cable. The whole network LAN comes to stable.
    Is it the old switch can not plug with cat 6 cable? thanks for reply.
Is this a brand new switch? Or did it come from somewhere else? It might have an IP address assigned to it that is interfering with the rest of your network.
Try plugging in a laptop only to the switch and give the laptop a static IP, see if you can access the configuration of the switch.
Posted on Jun 25, 2009
Dlink DES-1016D switch will support CAT6 cable or not
Yes. Cat 6 is for 1000Mbps / 1Gbps, and is backwards compatible. It will simply default to port speed on unit.
Nov 19, 2012 | D-Link DES 1016D (DES-1016D) 16x10/100...
Dgs-2014
I dont think , buying power supply will be expensive then buying anotehr d lnk switch
Nov 26, 2011 | D-Link DES 1016D (DES-1016D) 16x10/100...
Does the D-Link DES 1016D 16x10/100 Mbps Networking Switch accept either of strait-through or crossover cat 5e cable configuration to NICs?
Auto MDI/MDIX Crossover
All ports support auto-negotiating MDI/MDIX detection, which eliminates the need for crossover cables or uplink ports. The DES-1016D is the perfect choice for Plug-&-Play support for 10BASE-T and 100BASE-T networks.
See -->> http://www.d-link.co.za/des-1016d.php for further specs.
Hope this helps.
Feb 08, 2011 | D-Link DES 1016D (DES-1016D) 16x10/100...
How do i connect 2 d-link switches
i found that there is a MDI uplink port for cascading
Dlink DES-1016D 16-port 10/100 Switch
Product Features
  • 16 10/100Mbps ports
  • Full/half duplex support for each port
  • MDI uplink port for easy expansion Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
  • Auto-learning of network configuration
  • Flow control in full duplex mode for protection against data loss
  • Back pressure in half duplex mode
  • RAM buffer dynamically allocated for each port
What's Included?
  • DES-1016D Network Switch
  • Quick Installation Guide
  • CD ROM
Aug 27, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
Does d link des 1016d provides dynamis addresses to network printers?
DLink DES 1016D is seems to be an Layer 2 unmanaged switch which can not provide IP addresses.
If this switch is connected with a router or a DHCP server then it can pass the IP address to any connected device.
Regards,
Rashish
Aug 06, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
How to connect a lan
Just connect your router into port 1 and rest of your devices on the other ports. Its just plug and play. Im assuming your router is a DHCP server. If not, configure all your devices to static IP
Aug 01, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
All 16 ports are not working
How are they not working?
Check to make sure it is plugged in. Also, try using a different Ethernet cable if you are using the same one to test all ports. If the problem is you are not getting a connection to the internet or something, make sure the router is plugged into the switch and that you have properly set up your network.
Mar 31, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
Internet and LAN connectivity is disconnecting rapidly
check and make sure that all cable are straight through and that the connectors are good.
Dec 16, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
D-link des-1016d driver
This is a simple network switch and it doesn't require any drivers. You just connect all the computers & other network devices to it using twisted pair LAN cables and that's it.
Dec 13, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch Logo
1,098 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
