Question about Nikon D60 Digital Camera with 18-55mm + 55-200mm lens
Nikon D60 is suddenly taking very dark pictures
Hi-my Nikon D60 is suddenly taking very dark pictures, even with the flash. If I put it on manual and push the exposure all the way to the left, pictures will have some light - If I put the shutter speed onto about a 1sec, it'll take a half decent photo. I've used both my lenses and it's happening with both of them.
I have had "dark pictures" from each of my Nikon DSLR (D70, D80, D200, D300) cameras usually when taking pictures from a tripod and/or the self timer. Situations where you take your eye away from the viewfinder which allows stray light to enter thru the viewfinder and throw the auto exposure way off. Not sure if this is what is happening to you.
Posted on Jun 28, 2009
Nikon D60. When viewing pics I get a section of the display that flashes on and off. I have no idea what's happened and I can't get back to viewing pics without the annoying flashing, it flashes black and...
You're seeing blown-out highlights. These are the portions of your picture that have been overexposed so much that they've gone pure white and lost all detail. This is generally considered a bad thing, and the camera is warning you so. Of course, the camera doesn't know what effect you're trying for.
In general, the proper fix is to reduce the exposure by using exposure compensation to bring back the details. This risks losing details in the shadows as they go pure black, but that's generally considered not as bad. After all, we don't really expect to see things in the dark.
That was the long answer. The short answer is: press up/down on the multiselector to cycle through the different views of your picture.
Nov 12, 2010 | Nikon D60 Digital Camera
Nikon d60 camera keeps taking dark pictures... what can i do to reset this?
Check your "exposure compensation" setting. It should be at "0". You can set it higher for brighter pictures.
Oct 10, 2010 | Nikon D60 Digital Camera
My nikon D60 is taking dark photos.
The only reason the camera will be taking dark photos is when it is under exposing the image taken. This can be due to the exposure compensation set to under expose the metered exposure. Make sure the expsosure compensation is set to '0' or increase it to compensate for the dark photos.
Also inaccurately metering a scene (such as a high contrast scene) can easily fool the meter into under exposing, especially outdoors.
Jan 03, 2010 | Nikon D60 Digital Camera with 18-55mm +...
Light facial detail in my Nikon D60
Are you using the flash? If so, dial in some negative flash exposure compensation. Otherwise simply dial in some negative exposure compensation.
However, you will have to leave behind the Auto and the other point&shoot modes.
Dec 28, 2009 | Nikon D60 Digital Camera
I have a nikon d60 and my basketball pictures are blurred. I am using the 55-200 mm kit lens and am wondering if I need a faster lens. What do you recommend?
Turn on the sport program or manually use faster than 1/250s exposure. Your 55-200 lense has the f-value of 4-5.6 which is quite enough for the indoors photograhy. Better to use a flash though if you're gonna take some less blurred pictures of the hectic actions of the game.
Dec 02, 2009 | Nikon D60 Digital Camera with 18-55mm +...
Photos are dark despite settings saying they're ok
Hi
It is possible that the EV control has been switched on. This will look like this +/- and is usally set to 0. Try that perhaps.
I am uncertain what you mean by MANUAL since if it is true manual control of exposure the whole point is that you can select the level of brightness you want.
Best of luck
marti
Sep 19, 2009 | Nikon D60 Digital Camera
Nikon D60 is taking very dark pictures!!
elis - did you ever solve this problem? the same thing is happening with my d60 and i don't know what to do!
Aug 14, 2009 | Nikon D60 Digital Camera with 18-55mm +...
Flash buttom cannot be pressed to take a picture....turning the camera off and then back on helps...so does pointing downward and pushing button 1/2 down, and then snapping picture.
the mode that the camera is in, probably auto, is saying that there is enough light. when you point it down it reduces the light and when you press the shutter down half way it sees the light deficit and pops out the flash. i would say to play with the modes and preset modes.
Jun 16, 2009 | Nikon D60 Digital Camera
When I take pictures with my D60 on Manual the optimal exposure seems to be lying to me. In both situations dark and light everything is much much darker than it should be at optimal exposure. I want to...
Check the white balance. Set it to the corresponding lighting conditions and try the white card setting. It should be the last option on the white balance menu. To use it, snap a picture of a white piece of paper and save it. Just experiment with different settings till you get good results. Best of luck!
Jun 15, 2009 | Nikon D60 Digital Camera with 18-55mm +...
Nikon D60 (Auto Mode)
Read up on exposure and take the camera out of Auto mode.
Mar 22, 2009 | Nikon D60 Digital Camera
Nikon D60 Digital Camera with 18-55mm + 55-200mm lens Logo
1,550 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
