SOURCE: How do I add a dell external monitor to a dell inspiron 9400
Simply use the external video port. It may require an adapter depending on the monitor you plan to use.
SOURCE: Relacing a Dell Inspiron 2200 laptop monitor
http://www.fonerbooks.com/laptop_6.htm click on this link for step by step instructions.
SOURCE: Monitor comes on very dim, I can't see
click your "fn" key and then press the brightness key on the keyboard (it will be a blue or green "sun")
If this does not work, plug an external monitor to the laptop, if the screen is good on the monitor, your LCD display panel is shot.
SOURCE: I have Dell Inspiron 2200 laptop. My laptop's
The lines indicate a slow failure of the LCD and it is progressive. The system can be connected to a VGA monitor and you can select the External display using Fn + F8 key combination.
LCDs are about $100 on EBay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+2200+LCD&_sacat=See-All-Categories
SOURCE: My Dell inspiron 1545 laptop
The GPU may be bad take it to a shop the motherboard may have to be replaced to fix your issue...
