Question about Kenmore Kitchen Ranges
Oven door is jambed about 4 inches open and won't go either way
My son fell towards the stove and grabed the oven door handle. It opened a bit and he landed on it. Now it won't close or open!!!!
    Sergeant:
    Champion:
  • 208 Answers
The hinges need realigned at the bottom of the door. they may be dislocated hope your boy's ok good luck
Posted on Jun 22, 2009
How do I replace the handle on a neff oven?
1. Fully open the oven door.
2. Move the catch levers on the right and left-hand sides to the fully open position.
3. Placing the door at an upward angle toward you, grasp the door with both hands and lift it out of the hinges toward you.
4. undo the screws in each Connor & lift out the glass.
5. do the same with the handle screws, then put new handle on.
6.repeat above steps backwards.
Aug 30, 2014 | Neff Ovens
I did a self clean on my tappan electric oven; cant get the door to open.... what can i do?
MaryAnn, If you try to push the locking lever/handle towards the "lock" position first, then pull it back towards the open position, it should unlock for you.
However if that doesn't work, you can turn off the breaker for the electric range, in most electric panels, it is marked as "Range" or "Stove" but is typically a double pole 50 Amp Breaker (It takes up 2 spaces). If you look at the handles of the breakers, you should be able to see the numbers "50" on the handle.
Once you turn off the power, you should be able to unlock the oven. Some ranges require that the power be on in order to unlock it, but first try to open it with the power turned off, and it that doesn't work, turn the breaker back on and the door should be able to be unlocked.
Remember that it will take a little bit of effort to get the door to unlock in some cases, so give it a good tug.
Hope you find this Very Helpful and best regards!
Oct 25, 2009 | Tappan Ovens
The oven and controls dont work but the stove is?
usually it is the element that blows or burns out turn off power to range at circuit breaker, open oven and check element for holes, power still turned off!! unscrew element from back of stove wall, this is easier if the oven door is removed, open door to first detente (stays open by itself a few inches in open position) grab door on either side (not by the handle it will break off) and lift upward, check if wire connections are good, if not repair the connection(s), do you have a volt meter, if not borrow one or buy a cheap one and check the voltage at the connections, make contact with the meters probes and isolate them from the oven's walls (use some electrical tape) turn on oven and then turn on power at circuit breaker if 220v is available then the element is bad, if you do not have 220v then the switch is bad or wire feeding the switch is bad
Sep 16, 2009 | Whirlpool Accubake RF362LXTS Electric...
Lock for self cleaning cycle in the on position
unplug the stove, then force the mechanism back with a screwdriver
Jul 22, 2009 | Ovens
Handles fell off of the top oven door on maytag gemini glass top
Open the door a few inches, to the first hold-open stage. Lift the door upward & off the mounting bars. There will be screws along the bottom edge.
Mar 08, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Bake element split and oven will not heat.
thats an eazy one by a new element from one off our links at fixya and install it with the power off and no theres no reason why this happened it just wore out God bless,tom
Jan 01, 2009 | GE Spectra JBP78 Electric Kitchen Range
Oven door staying open about 1 inch
You need to post the model number for the stove
Regards
Nov 19, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
OVEN DOOR LIGHT SWITCH
These instructions apply to my GE Profile JBP90 but other brands and models are similar.
1. DISCONNECT THE UNIT FROM ITS ELECTRICAL POWER SOURCE!
CONFIRM POWER IS DISCONNECTED BY OBSERVING DISPLAY GOING DARK
In your case this may mean turning off the 220V double circuit breaker or unplugging the unit cord from its power outlet.
2. Open the oven door
3. Remove the two screws under the front edge of the stove cooktop on the far left and right
4. Gently raise the cooktop 4 or 5 inches and prop it open with a small cardboard box
5. Find the door switch wire and gently pull the switch connector off
6. Remove the switch by squeezing the two metal spring tabs toward the switch and pushing the switch out toward the front
7. Inspect the switch. If its like mine, it may look a little melted and smell burnt.
8. Find a new switch online or at your nearest parts distributer
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=212235
9. Installation is the reverse of above steps.
Good Luck!
Jun 25, 2008 | GE JBP90 Electric Kitchen Range
Convection oven fan continues to run even with door open and there is an electrical odor.
My JBP90 GE Profile convection oven had the same problem. The problem, in my case was caused by the door switch that controls the interior oven light. It also controls the convection fan and possibly the convection heating element.
Good Luck!
Jun 18, 2008 | GE Kitchen Ranges
Stove handle/door
need strong fingers and a helper... lay the door on the floor push open the hinges and there is a hole on the side of the hinge have your helper slide in a small nail only about 1/4 " in to the hole this will keep the hinge out do the same on the other side then reinstall the door open up and remove your nails
Feb 26, 2008 | Whirlpool RF315 Dual Fuel (Electric and...
Kitchen Ranges Logo
88 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
