Question about Maytag Legacy Series Top Load Washer
Leak from the drainpump - Maytag Legacy Series Top Load Washer
  • 6,784 Answers
HI, if the drain hose is OK, replace the pump. the housing is compromised.
Posted on Jun 25, 2009
Asko 1375
May be the drainpump that has something stuck into it. Check that
Jun 08, 2008 | Asko 1375 Dishwasher
Why doesn't it fill or start?
Check drain pump. Normaly washing machines always start with drain first. But not all brands like Miele and a few others. Some cheap machines wont even display a error when drainpump i blocked.
Feb 13, 2016 | Washing Machines
Water wont pump out code f-05
Clogged drain pump.
Check the drain pump filter. Use a flashligth and you will se if the impeller is stuck on something. If not check the hose from the drum to the drainpump housing. May be clogged.
If not, replace drainpump
Apr 14, 2014 | Hotpoint Washing Machines
Fault coming up as "E1"
First disconnect power for at least30 seconds. Re-apply power and observe for at least one minute. If codere-appears, you need to replace control board (also called ERC or clock). For draining problem: Verify drainpump operation - verify that the pressure switch hose is in good condition andproperly connected to tub and pressure switch. Please check these -
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves, pressure switch, drainpump, flow meter,
and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuringthe resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
If you findanything, replace failed component. Hope this willhelp you. Good Luck.
Jul 14, 2011 | Tecnik Kitchen Ranges
Water leaking from bottom of machine - machine not washing well
It is important that you look underthe washer to confirm the point of leak so as to get a first hand information.If the leak is during the wash cycle it can be from fault of the celing gasket or a leak from the drum moving spindle.However if it is during the rinse cycle,the leak can be from the out let hose,drainvalve/drainpump.If so the hose can be tighten or the valve pump can be removed,repaired and reset.
Aug 31, 2010 | Samsung WF337AA Front Load Washer
Bosch dishwaher doe not drain water
you have something in the drainpump locking it up or a blockage somewhere between the sink and the unit or the pump itself has failed
Dec 21, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Washing Machines Logo
44 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
