It starts with choke on but will only idle if you give it any fuel it dies
Sounds like the carb is gummed up
here is a link to all the Arctic cat ATV service manuals
Parts House Lawn Mower Parts and Chain Saw Trimmer Parts
SOURCE: How to fix a leak fuel from the carbuator or primer for a atv arctic cat 500 2005
YOUR GOING TO HAVE TO TAKE APART AND PUT A BIGGER RUBBER O RING INTO IT.
SOURCE: arctic cat snowmobile problems
yes but I would also suspect the carbs we not cleaned fully. main jets and emulsion tubes as well as the idle air circuit... these all are important for proper operation. you will need to pull the idle mixture screws out as well.... if they are plugged from the factory you need to drill into them and use an easy out to remove them
