Question about Intel D101GGC Motherboard
CD ROM DOES NOT APPEARS ON MY DESKTOP. WHEN I OPENS MY COMPUTER THERE`S DOES NOT APPEARS THE CD-ROM`S ICON.
  • 255 Answers
1.check your connections of CD Rom inside the Cpu box, if any loose contacts there, then your cd rom wont appears on the computer,
2. change the data cable
3. connect different power socket to the cd rom
4. goto Bios setup, press Del key or F2 key to enter the Bios setup
5. check your cd to detect
6. save it and restart your computer
Posted on Jun 22, 2009
I have a cd I put in, but do not know how to remove it from my computer need help
1. Open the Computer window on your PC: Either double-click the Computer icon on the desktop, or open the Start menu and choose Computer.
2. Click the DVD drive icon: Clicking the icon selects that drive.
3. Right click on it and choose 'Eject' from the drop-down list.
OR
Try the following only if the above steps didn't work or in times of urgency, such as when the computer is locked up (or turned off), you can manually eject a disc/cd by pushing a straightened paper clip into the tiny hole (the "beauty mark") on the front of the DVD drive.
f90a6593-7fec-4205-a633-379cc4b71e53.jpg8572a8b8-67cd-4c33-bbf8-d5d51bfdd48d.jpg8681c4da-0608-43dc-b4b8-cee760b38e11.jpg
Nov 28, 2013 | Computers & Internet
Trouble installing my Samsung SCX-4200 printer
Good day Sir, That is common macintosh problem. There is described "driver not installed" at product List Window after you click Add and select USB. I suggest Reintall the software and make sure that you are using a high-quality cable.
Installing software Samsung scx-4200 for Macintosh
Verify the following before you install the software.
Operating System - Mac OS 10.3x or higher
RAM - 128 MB
Free Disk Space - 200MB
  1. Make sure that you connect your printer to the computer. Turn on your computer and printer.
  2. Insert the CD-ROM which came with your printer into the CD-ROM drive.
  3. Double-click CD-ROM icon that appears on your Macintosh desktop.
  4. Double-click the Mac_Installer folder.
  5. Double-click the Mac_printer folder.
  6. Double-click the Samsung SPL2 Installer icon.
  7. Enter the password and click OK.
  8. The Samsung SPL Installer window opens. Click Continue and then click Continue.
  9. Select Easy Install and click Install.
  10. After the installation is finished, click Quit.
Have a nice Day.
Dec 24, 2009 | Samsung SCX 4200 All-In-One Laser Printer
PLEASE INSERT CORRECT CD-ROM CLICK OK AND RESTART APPLICA
insert the cricket cd right click and open he cd there wil be a folder named crack open that folder and copy the cricket icon
now right click on ur desktop cricket 2007 icon and go to properties click on find target the window that opens up paste the copied icon in the window if it ask to replace click on ok
Jun 21, 2009 | EA Sports Cricket 07 for Windows
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
I nees a setup sheet to re-install my P4350
from the desktop,click start programs lexmark 4300 series uninstall. follow the instructions on screen to remove the printer software.restart the computer.click cancel on any add new hardware screens insert the installation cd
IF the software installation screen does not appear. from the desktop double click my computer in windows xp click start to access the MY Computer icon.Double click the cd rom drive icon. If nessessary,double click SETUP ExE .when the software installation screen appears, click install or install now Follow the instructions on the computer screen to complete the installation.
Feb 21, 2009 | Lexmark P4350 All-In-One InkJet Printer
Forgot pin number for epson stylus cx6400
If you forget your PIN code, you can regain access to the CX6400 by running the security lock program from your computer:
1.
Insert your Stylus CX6400 software CD-ROM.
2. Windows: If you see the Software Installation screen, click Exit.
Open the
SecurityLock Tool folder on your CD-ROM, then double-click the program file located in that folder.
Macintosh: The EPSON folder automatically opens (if it doesn’t, double-
click the EPSON CD-ROM icon). Then double-click the Security Lock icon.
Nov 24, 2008 | Epson Stylus CX6400 All-In-One InkJet...
CD rom can't read CD XP
yes i think the cd rom is the problem ,use external cd drive for the re installation or you can use a flash disc
Jul 12, 2008 | Acer Aspire 4315 Notebook
No cd-rom icon appears
install a mp3 player /take i tt o
Feb 09, 2008 | Computers & Internet
Cd rom does not working
the auto-notification could not be enabled, do the following:
# Double click on the My Computer icon on your Desktop until it opens.
# Then gently click on your CD / DVD Rom Drive just until it becomes highlighted.
# Then click on the word File, which is contained in your top tool bar area.
# This will pull down a menu for you to now click on Properties.
# Then click on the Auto Play tab at the top of the screen.
# You can adjust settings for Music CDs, Music Files, Pictures, Video Files and Mixed Content.
# Now select a multimedia types by using the pull down arrow to the right with your mouse.
# Then for each multimedia type, use your mouse to encircle the Select an action to perform: option.
# To disable that multimedia type, click on the Take no action icon at the bottom of the screen.
# Now click on the Apply button at the bottom of the screen to save your changes.
# Continue in the above fashion for each multimedia type, choosing the Take no action option.
# And ensure that you click on the Apply button at the bottom of the screen to save your changes.
# Once all options have been set, then click on OK button to exit the CD Drive Properties window.
# Repeat the above procedure on any additional CD Rom Drives you have in your system.
# Note: If you feel you have made a mistake, you can click on the Restore Defaults icon at any time.
Jan 10, 2008 | Compaq Laptop / Notebook Video-336970-001...
Intel D101GGC Motherboard Logo
88 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
