Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic, model # PT-52LCX15
How can I get the front screen off,so I can clean the mirrp inside of the TV.
I took off all the screws behine the screen, but it seem to be stuck at the bottom, Is ther some thing else holding it?
Thank you
  • buzzardtx Nov 03, 2007
    I removed 12 screws from the top and sides.
    I see no other screws. Is there a proper way to remove this screen without damaging it?
    Thanks
    See no other screws below the screen. Does anyone know what's keeping it from coming out?
    I'll be waiting for reply.
    Thanks
    buzzardtx@sbcglobal.net
  • 363 Answers
Be careful how you clean the mirror, it will have the silver on the outside of the glass The coating is quite easily scratched.
Posted on Nov 04, 2007
  • 143 Answers
You might have more screws on the bottom i strongly suggest you be very carefull doing this the sreens are very delcate and cost lots of money
Posted on Nov 03, 2007
Green haze on panasonic pt-52lcx15
Your EEPROM is corrupted and needs to be reprogrammed. You need a EEPROM data corection tool. Part# LSUQ0100. It will come with instructions on how to restore your EEPROM data. Good luck.
Apr 19, 2012 | Panasonic PT-52LCX15
Tip
PANASONIC WITH FUZZY SPOTS
FIXYA TIP PANASONIC
I hope this not AN old TIP, but I still see it asked and not answered properly by some.
TIP:
PANASONIC:
MODELS: PT-44LCX65, PT-52LCX15, PT-52LCX65, PT-52LCX35,
PT-61LCX65, PT-61LCX35.
SYMPTOMS:
1. FUZZY SPOTS
2. FUZZY SPOTS WITH STAINS
3. FUZZY SPOTS & UPSIDE DOWN
4.. FUZZY SPOTS WITH LINES
5. LOOK LIKE BAD LIGHT ENGINE.
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM CORRECTION TOOL; (LSUQ0100).
It is an easy repair (about 7 minutes), it takes longer to take the back off to perform this procedure.
Can't be purchased unless you have an account, customers can not purchase.
Thanks, Big IRISH.
on Dec 15, 2009 | Dishwashers
How do you reset the bulb life counter after you put in a new bulb?
For models:
PT-44LCX65/PT-52LCX65/PT-61LCX65/PT-52LCX15.
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down the SPLIT DVD/VCR CH UP button on the remote until a message appears on the screen that the lamp timer has been reset. If this does not work, use SPLIT DVD/VCR CH DOWN instead.
Good luck
Dec 14, 2010 | Panasonic PT-52LCX65 44" HDTV
I have a panasonic model PT-52LCX15 and and as a today dont stay on. It was a light or two like a ''flaslight Pointing at the screen.'' Now I put it on the light on th ''on'' botton goes green then turns...
I have the same one that I bought from Sam's in 2006. My lamp (TY-LA1000) just burned out recently. Most likely that is the same issue for your TV as well. You can buy direct from Pansonic or lookup on one of the many providers online. You can buy the lamp with housing or for less money you can buy just the lamp and use existing housing but will require more time.
Jun 25, 2010 | Panasonic PT-53TW53 53" Rear Projection...
MODEL # PT-52LCX15. GREEN AND BLUE SPOT ON SCREEN.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine.You can find it here: http://www.discount-merchant.com/PANASONIC-521A2C52-p/1177904.htm Have a blessed one!
Mar 22, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic multimedia projection HDGT tv color spots displayed
PANASONIC..PT-52LCX15. STARTED TO A LIGHT COMES ON THE SCREEN. THEN TWO LIGHTS. FINALLY TV DONT COMES ON. I PUT ON THE TV, AND ON BOTTON START BLINKING AND TV DONT COME ON..I TAKE OUT THE TV LAMP..IT LOOKS GOOD NOT BURN. SHOULD I REPLACE IT??
Oct 18, 2009 | Panasonic Televison & Video
OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Sep 28, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Lamp timer
hold the Volume Down button on the TV and the Mute button on the remote for 5 seconds.
Sep 12, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
117 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
