Question about D-Link Express EtherNetwork DSS-5+ (NTSWDLDSS5PL)
D-link dss-5 setup (please help!)
Hello me and my friend want to share the cable connection. he has d-link dss-5 ethernet switch but we cannot figure out how to make this work. we have comcast high speed internet and so far only his computer is accepting the connection. when i plug the ethernet cable into my desktop, all i get is "acquiring the network address", then after a min it turns out to being connected but no packets are received on this connection. please help!
  • Anonymous Nov 09, 2007
    can's install
    President:
  • 2,961 Answers
You need to make sure that DHCP is enabled in the router settings and that your network cards TCP/IP is set to obtain an ip address automatically.
Also check that your computers workgroup is the same as your friends eg, Home or Workgroup.
Posted on Nov 05, 2007
When I plug a cable into the computer from the switch, I am getting ethernet cable unplug error. I know the cable is good and my router is set up correctly. I have 15 computers using this switch and only...
check individual IP of your computer..try to obtain each PC..let you router assign the ip.check your router maybe you need to add addition numbers of clients.
Jun 26, 2011 | D-Link DSS 16 Plus (DSS-16+) 16x10/100...
How do i join and set up xbox live from my laptop to my xbox360 console using a ethernet cable/help
1) Connect your ethernet cable to your computer and xbox
2) On your PC, Go to network connections and right click on your wireless connection
3) Click the advanced tab on top
4) Go to Internet connection sharing and check the box, click OK
5) On your xbox, Go to your network settings
6) Edit settings and set everything to automatic
7) Test Connection
You must have your PC on at all times to connect to Xbox live this way.
If this setup doesnt work.
1) Go to Network connections
2) Select both your wireless connection and your LAN connection
3) Right click and bridge the connections
4) Same setup on Xbox as the previous instructions
5) Test Connection.
Apr 29, 2011 | Microsoft Xbox 360 Console
1 connected ethernet cable from modem to dynex hub in "uplink port", ran another ethernet cable from laptop to 2nd port on dynex hub and ethernet cable from ps3 to 3rd port and nothing happens. Please help...
If your trying to use this to share an internet connection.. sorry to say but it's not going to happen. The hub that you purchased will not handle the DHCP settings that need to be processed to share an internet connection.
Best advice... go back to Best Buy and smack the agent that sold you this and get a router instead. :D That's what you're needing to share your connection.
Oct 23, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
Setting up a small network using DSL and a DLink router
1.) The setup needs changing
2.) first off the dss-24 is a network switch not a router
3.) all of your pc equipment should be pluged into that device.
4.) chose one port as an uplink to your att modem
I think your problem is that the new modem is only giving out one ip address. So what ever first pc is turned on that is the one that grabs the address.
5.) you will most likly need a router to take the one ip address assigned via att then dole out additional ones. Remember the dss-24 is not a router. It simply connects everyone together. Each device still needs an ip address given from somewhere. Your old cable modem probibly did that but your new att dsl most likly does not.hence the new router will do that.....
to set it up do the following
2.) Find out the ip setup needed for your dsl service
A.) gateway ip
B.) primary & secondary dns server ip`s
C.) subnet mask
3.) get into the setup of your new router and then plugg in
all of these values using a fixed if address in the router
4.) connect routers wan port to one of the modems port. u may have to use a cross cable or straight look at the link lites to find out if they are talking to each other
5.) make sure that the routers lan side is setup for DHCP
6.) connect one lan port off the router to an uplink
of the dss-24. Then reboot everything
7.) viola it should all work internet on evey machine and file sharring.
Apr 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
I am trying to setup up a D-Link DES-1016D, 10/100 Fast Ethernet Switch to allow 5 laptops to connect, 1 cat 5 is connected to another switch that will provide these 5 laptops internet how can i do this? I...
The Simplest Way of doing this is this:
You will need just 1 switch and 5 Straight-Through cables.
(This is Provided that your laptop will connect to the internet through another method. e.g (Though a USB Modem or WIFI) ).
Connect the Main laptop to the internet through either a USB Modem or a WIFI.
Next, Connect a straight-through cable to the LAN Port of the laptop, and the other end to one of the ports of the switch.
On the network connections page, right-click on the ethernet adapter, go to TCP/IP, and give the laptop a static IP-Address, e.g 192.168.0.1 and Subnet 255.255.255.0
For the other laptops, connect each one of them to the switch using the straight-through cables, and on their ethernet adapter TCP/IP Properties, give them different IP Adresses, but in the same subnet. e.g
192.168.0.2 and 255.255.255.0 for the 1st one
192.168.0.3 and 255.255.255.0 for the 2nd one
192.168.0.4 and 255.255.255.0 for the 3rd one, ....and so on.
Next, in the default gateway for these other laptops, put the IP-Address of the First laptop that is connected to the internet. i.e 192.168.0.1.
Also repeat the same IP Address of the 1st laptop in the Preferred DNS Server for these other ones.
Next, setup home or office network on all of them,
follow on-screen instructions and when you get to the place where you have to select the type of network setup, Just select :
"This computer connects directly to the internet........" for the 1st laptop,
For the others, select : " This Computer Connect through a residential gateway or other computer on my network.".
Then give them all the same workgroup name, and accept file and printer sharing for all of them.
In case you are using Windows Vista.
The only different things include:
When you get to the TCP/IP Place, select TCP/IPv4 and Not TCP/IPv6.
Also, When you are changing the workgroup, all you need to do is to right-click on My Computer Icon, then Properties then go to Advanced, then Select Computer Name, and change the workgroup from there and restart the computer.
What I have told you is a typical, very easy network setup, and I do hope it helps you out.
Keep me posted about the problem.
Hope it helps you out.
Good luck
Nov 20, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
Same thing as above, want to se up a LAN connection
Once you connect the 2nd switch - you must power down the cable modem and the original router along with all PC's connected to the network.
Then power up the cable modem,wait 2 minutes,
power up the router - wait 2 minutes, then power up all the switches. Once all downstream devices are on - power up all the PC's and you should be OK.
Sep 13, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Where is the cap 5 cable located?
The Question is not clear. Pls be more specific
Sep 08, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I dont how to connect my pc's using D-Link
Dear! first of all you need a 4 port hub or 8 port switch that have easily available. Now, first of all, put three wires (Straight Through Cable) in three different ports and other side its ends put in that nodes or computers. Now they are connected to each other. You want to sharing data for each you should run setup wizard for sharing inside the network places after that computer required a restart. Now the computer will start and data will share to each oher. You should use IP address for computers, first of all IP 192.168.0.1 for first PC and 192.168.0.5 for second PC and 192.168.0.10 IP for 3rd PC. Enjoy, everything is accessible now ...........
Thank You
Jul 28, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
About connectiong two pc.
You can connect the computers with a serial cable, or using hyper terminal. If you have a home network, most windows operating systems will aid you to setup a home network so that you can share information
Jul 09, 2009 | Microsoft Windows Vista Ultimate Edition
I have a d link DES-1105. cant get more than one computer to work on hub/switch.
Hi!
Unfortunately, hubs or switches cannot be use to share internet access specially if it's connected to a modem. To share internet access, you will need a router. If you prefer not to use a router, you can enable ICS (Internet Connection sharing) on one PC and share internet access to the others. However, the PC that will share internet access will need two ethernet cards (or LAN cards).
Your setup will look like this:
If internet is not a concern, and you just want to connect the computers to share files and resources, you will have to se your computers to static IP. You do not need any additional device - just connect your computers to the hub, setup a static IP on all the computers.
If you need further assistance setting up static IP on the computers, please reply and I'll give you the step by step instruction for that.
For any setup, a router will be the best option.
I hope that helps.
Good luck and have a nice day!
Nov 30, 2008 | Computers & Internet
D-Link Express EtherNetwork DSS-5+ (NTSWDLDSS5PL) Logo
1,914 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
