Question about Goodman CLQ36AR49 Air Conditioner
10 ton goodman not cooling - Goodman CLQ36AR49 Air Conditioner
    Novelist:
  • 166 Answers
Your problem description is quite broad. There are a variety of factors that may cause your AC to not cool your house. With that said, given your ambiguous description, I can offer you a diagnostic article that provides the most probable causes of your AC's failure to cool your house, and from there you can read it and then, step by step, rule out each possible cause listed in the article:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Of course, a low level of Freon/refrigerant may be the problem, but there may be other problem causers as well, as noted in the article---it may just be that debris is obstructing your AC as well. Read the article, and, if need be, take advantage of the link for free quotes and "pick the brain" of these technicians who offer you a free quote to discern what could be the problem.
Brad
Posted on Jun 22, 2009
What is the tonnage of an Goodman ck361-b older,15 yrs
That unit is a 3 ton and that term ton has been retired. The term used is now called SEER. SEER and ton are not the same.
Jun 29, 2018 | Goodman Heating & Cooling
CPJ18-1B Goodman heat pump. has a slow leak. I need to know what Ton or BTU to replace it with.
you have a 1.5 ton. 12000 btu's per ton. your model number has an 18 in it. tells you 18000 btu's
Apr 13, 2017 | Goodman Heating & Cooling
Where can I find the specs for an earlier Goodman heat pump?
You say 2 to 3 years... I'm assuming the unit is older than that. Especially being r22. What about the first 10 years??? Normally you will get 400 to 500 sqft per ton of cooling, but, that depends on heat load calculations. If the unit wasn't big enough you would have had this issue 10 years ago, not when the system kept running low on refrigerant. At first guess I would say a 2 ton unit is not big enough but if it worked fine for 10 years...wuth all that in mind, if it were me, (a seasoned professional) I would spend 1800 to fix my 15 year old r22 unit before I spent $4000 on a new r410a piece of junk. Best Wishes!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 29, 2017 | Goodman GMS90703BXA Heater
I have a Goodman 4 ton unit that is 7 years old.The capacitor went out. Now the unit cools great until it cycles out. The compressor will not restart until it cools down for a couple of hours. Is there...
Just replace the capacitor...with the same size or even one that is a slightly higher MFD rating...you can go up to 10% higher with no problems...
heatman101
Aug 05, 2011 | Goodman CKL36AR36 Air Conditioner
My AC unit model is CPLE60-1. It is running, blowing cool air but not cooling house. Any Suggestions? and what is the life expectancy of this unit?
Your Goodman unit is a five ton and should last 15 to 10 years with proper maintenance. Parts do wear out though during the normal life of piece of equipment.
Cooling problem may be due to low charge, broken ducting, or other low airflow problem. Need to verify freon charge and then go from there.
Jul 27, 2011 | Goodman CKL36AR36 Air Conditioner
Goodman ac model # G8C13024AE what tonage is it
That is a 2 ton system. Look at the model number and the 24 is the giveaway. A ton is = to 12,000 btu's. 24 = 24,000 btu's whick is 2 tons of cooling.
Hope this help's!
Audie
Dec 10, 2010 | Goodman CLJ30AR32 Air Conditioner
What ton and seer would a goodman unit be if seriel number is gsh13061bb
Is there a btu rating tag for cooling on this unit?
If so 12.000 btu is = to 1 ton.
So 24.000 would be two tons and so on.
Aug 18, 2010 | Goodman Heating & Cooling
I am looking for how many tons of cooling my goodman condensor provides
  • Here's the data you requested:
  • Goodman CKL42AR42 Split System Air Conditioner
  • Type: Split System
  • Cooling Capacity: 40000 BTU/hr (3.3 tons)
  • Energy Efficiency Rating: 9 EER
Mar 19, 2010 | Goodman CKL42AR42 Air Conditioner
Do you know how I can get a Goodman Ht pmp Manual
this manual willl not help your system perform better , have a qualified tech check your sub-cooling. temp diff, and match your piston with your coil. many goodman systems may say they are 3 or 4 ton but are half a ton smaller than advertised at the compressor. a three ton system will have a two and a half ton compressor
Oct 01, 2009 | Goodman Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
147 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
