Heating & Cooling Logo
A
Anonymous Posted on Aug 29, 2017
Replace compacitor on Carrier 5 ton 3 phase AC
I have old Carrier condenser 5 ton 3 phase split unit. The Furnace is running and signal to start Ac good. I replaced the capacitor (single capacitor) and nothing started. I can manually start the unit at the contact switch. The compressor start but fan does not run. I wired the capacitor by power to one side and motor & Compressor on other. If correct how do I check the motor.
Matt
Level 1:
New Friend:
  • Contributor 52 Answers
  • Posted on Aug 29, 2017
Matt
Contributor
Level 1:
New Friend:
Answers
52
Questions
0
Helped
24708
Points
90
A three phase compressor does not use a capacitor! The fan can be single phase however even though the supply is 3 phase. Call an HVAC tech before you cost yourself more than you are trying to save!
Thomas Woodburn
Level 3:
  • Carrier Master 2,638 Answers
Thomas Woodburn
Carrier Master
Level 3:
Answers
2638
Questions
Helped
1251886
Points
7008
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
5 Related Answers
christian nielsen
  • 358 Answers
  • Posted on Mar 29, 2009
SOURCE: home unit 3 ton won't run
The small capacitor is for the fan motor the other for thecompresor .You can try conecting a booster (or hot start) in paralel to the comp.capacitor .If this doesnt work you have to replace the compresor.
jdthefixer
  • 747 Answers
  • Posted on May 03, 2009
SOURCE: COMPRESSOR NOT RUNNING, HOT
The high side/low side pressure equalization you describe is normal for a compressor sitting idle.
If you have an ohm meter you can check the compressor windings for opens and shorts. If your compressor is 3 phase as you state (this would be very unusual for a residential unit) you should have continuity across all 3 phases and no continuity to ground. Take the compressor out of the circuit before you check.
If the compressor does have crankcase heat, it should have been left on for at least 24 hours before starting the unit. Another cause for failure could be overcharging which could have resulted in refrigerant slugging back to the compressor.
Does the unit have any low or high pressure control safeties? If so, check them too - some have resets. You said the condenser fan ran so it's not likely the breaker blew, but check anyway and also check to make sure you have available power on all 3 phases.
Anonymous
  • 116 Answers
  • Posted on May 11, 2009
SOURCE: My ac fan went out on a carrier ac unit. Need wiring help
use a seperate capicitor for the fan only pick up 1 leg of power from common side of the compressor cap and the other from the contactor or the board in a heat pump situation
Anonymous
  • 614 Answers
  • Posted on Nov 09, 2009
SOURCE: I had to change the compressor of my 2 ton
I would say control board. Get on Samsung web site and go to technical support and get there 800 number. I have called several times and they can walk you thru it. Just have your m They model number handy. They can also tell you wether you need a service tech or not. Be sure to ask for free estimate. Rus
Anonymous
  • 16 Answers
  • Posted on Jun 22, 2012
SOURCE: carrier 48NMX042 IFM wont stop, condenser fan motor and compressor wont run
Ok first thing is it sounds like a wiring problem. So first step is to make sure the thermostat is properly connected. Which... the main thing here is there needs to be 24v dc power coming from your control board (transformer) going to the thermostat..generally that is the red wire. All the thermostat does is connect that "red" wire (power) to one of the other wires to complete a circuit. So make sure you have 24 volts... (generally about .5amps) . if you have power than switch thermostat to fan only should energize the green wire only. then switch to ac and move temp low enough that the ac should turn on and that should energize the yellow wire. for sure one of those wires is incorrect now or the fan wouldn't be on OR THE THERMOSTAT IS NOT CONNECTING THEM AND IT IS BAD. Now about the compressor and fan.... those same wires run out to the compressor unit... ok the yellow for ac.. greeen does not go to compressor unit that is for fan only (vent).. red carries the same 24 volts... one difference here is that most carrier units only have the one transformer....so you run the red wire is the +pos 24 volt..and then a "common " wire is needed which is the Ground or neg... that wire on a carrier is brown usually but could be different depending installer. The orange wire goes to the pump reversing valve it is always energized when on ac mode...when heater is on in the winter it is heat pump and is not energized so just connect the orange and yellow together... tell me more specifics if this doesn't help and i'm sure I can help you... thanks Chuck
What is the tonnage of a carrier furnace model number 58gp100-2
It can handle five tons, or a 60000 btu ac. Tonnage is a measurment for the ac, 1 ton-12000 btus. The ac dose the cooling. the furnace simply blows the air, so if its a good furnace, and sized right, no need to replace it. Simply add the split system to the existing furnace. If you want the tonnage of the ac size, let me know your homes squarefootage, age, condition. Do NOT include the basement in the sq. ft.
What could cause carrier fault code 42 besides bad inducer
Could be several causes.
1. Blockage on piping
2. Water in inducer housing slowing down inducer impeller
3. Condensate trap for furnace clogged up.
4. Inducer motor going bad.
5. Leak in vacuum hoses or not connected.
Welcome To the Best HVAC
Dgaa056bdtb
The relay on the outside unit is stuck
2answers
I have Carrier 38TKB036 3 ton A/C condensing unit and one 28CCA036 3 ton A-coil to provide A/C to home thru existing furnice. A/C was on and stopped working. Turned off/on, but will not come on. Any...
Is the furnace fan (indoor fan ) running. If not the problem is with the inside unit. It supplies the control power to operate the entire system and has a control fuse on the circuit board. If it is running but not the outside unit then the problem is outside.
3answers
WHICH IS BEST A/C NOW
Check out this site. you will get an idea about the types of AC so that you can buy it according to your choice.
http://www.hellogiri.com/home-air-conditioner-split-ac-window-ac-price-details-in-india-best-cost/
thanks for rating Good luck
2helpful
2answers
Is the Model #25HBA360A300 a 5 ton unit?
36k-car-ms Key Features AC Type: Split System Additional Features: Ductless Cooling Capacity: 36000 BTU/hr Electrical Requirements Voltage: 220It is a 3 ton aprox 550 sq feet per ton is required
Top Carrier Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
