Question about Panasonic SC-HT670 System
Same problem DVD tray won't open and also won't let me change to any other mode. Makes loud clicking when turning on and off. Only had the thing 6 months. Real bummer
  • 47 Answers
You might have a broken tray drive belt. Take off the outside cover and look for a small black rubber belt or its pieces.
Posted on Jun 22, 2009
Dvd stuck in computer
push eject button, slap the top of computer sould eject. the rubber type band that turns the wheel to open tray is worn out needs replaced
Apr 10, 2013 | Apple Televison & Video
Tip
INITIALIZE THE DVD PLAYER -FIRMWARE UPDATE
FIRMWARE UPDATE
1. Turn the power on and remove the disc on the tray.
2. To put the DVD player into version up mode, press [9], [8], [7], [6], and [SEARCH MODE] buttons on the remote control unit in that order. The tray will open automatically.
The DVD player can also enter the version up mode with the tray open.
3. Load the disc for version up.
4. The DVD player enters the F/W version up mode automatically. If you enter the F/W for different models, "Disc Error" will appear on the screen, then the tray will open automatically.
5. After programming is finished, the tray opens automatically.
At this time, no button is available.
6. Remove the disc on the tray.
How to Eject Manually
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
on Jan 19, 2016 | Denon DVD-1740 DVD Player
CHANGE REGION RHT390H
see this steps:
Turn on the DVD player.
  • 2 Open the DVD disc tray and keep it open. Power on your DVD player and open the disk tray. Leave the tray open as DVD region code hacks need the tray to be open as the code is entered for it to get activated.
  • 3 Press the "Home" key on the DVD remote.
  • 4 Select the "Setup" option.
  • 5 Select the "Lock" icon by using the arrow keys on the remote control.
  • 6 Press the number key "0," seven times on the remote. This is the code-"0000000."
  • God bless you
    Jul 16, 2012 | LG Televison & Video
    Memorex 3202-3223 dvd burner disc tray won't open
    Try reseating the DVD drive so it makes proper connection.
    Mar 05, 2012 | Computers & Internet
    How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
    Hi
    Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
    1. Switch power on
    2. Open the DVD tray (leave it open with no DVD in it)
    3. Press "stop"
    4. Press "734466"
    5. Use cursor to scroll up or down until it says "Region 0"
    6. Press "OK/Enter"
    7. Switch power off
    8. Switch power on
    It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Jan 30, 2010 | Teac DV-H500 DVD Player
    Cd tray won't open
    get it serviced as it happens due to the old band or ring kinda thing in the tray which aids in opening of it.
    Aug 28, 2009 | Panasonic SA-HE70K
    DVD tray makes noise when it rotates
    This noise can be casued by two things:
    1) The tray is not completely in the loaded position and the "clamper" is rubbing. Replace the loading belt and the loading sequence will complete and the noise should stop.
    2) The "CD table" that is part of the spindle motor assembly has slipped a bit. This will make the CD/DVD ride too low and strike the lower tray support. This will require that the table be "re-aligned" to the proper height which may not be possible on your model without special measurement equipment. The height is critical to proper operation of the unit.
    Try replacing the load belt first and report your results.
    Thanks,
    Dan
    May 30, 2009 | Kenwood DV-605 Multi-disc DVD Player
    Ilo DVDR05 Vibration and loud humming noise
    i experienced that problem before.one cause is the cd itself.there cd's that are too thick so the motor has hard time rotating that makes vibrating sound.the other ,don't put something over your unit.the cover is touching the holder of the cd and makes a sound.just do the necessary things to be done like don't put something on top your unit.if not, then a manual analysis of the tech is the last option.
    May 17, 2009 | iLO DVDR05 DVD Recorder
    Nesesito un codigo para un dvd marca jwin grasias
    Some unlock codes for Jwin DVD players are:
    Jwin JD-VD100 / JD-VD703 / JD-VD753
    1. Press SETUP
    2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
    3. "VerX" is displayed (X=RC)
    4. Select the RC with RIGHT and LEFT (255=Codefree)
    5. Press RETURN
    Jwin JD-VD120
    1. Press SETUP
    2. Press 1, 3, 6, 9
    3. Current RC should be displayed
    4. Select RC with UP, "DOWN" (0=codefree)
    5. Press ENTER
    Jwin JD-VD130
    1. Method 1:Press SETUP
    2. Press 1, 3, 6, 9
    5. Press ENTER
    1. Method 2:Open the disc tray
    2. Press PROG
    3. Press ENTER 3 x
    4. A menu should appear.
    5. Select RC with UP, "DOWN" (0=codefree)
    6. Press STOP
    7. Close the disc tray
    Jwin JD-VD135 / JD-VD147
    1. Open the disc tray
    2. Press SETUP
    3. Press 1, 3, 8, 9
    4. Use Up/Down keys to change the region
    5. Press SETUP
    Jwin JD-VD140 / JD-VD501
    2. Press 2, 8, 1, 2
    3. Use the arrow keys to change the region (9 = multiregion)
    4. Press SETUP
    5. Close the disc tray
    Jwin JD-VD145
    2. Press 9, 7, 3, 5
    3. Change the region
    Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
    1. (Open the disc tray)
    2. Press SETUP
    3. Press 1, 3, 6, 9
    4. Press LEFT 3 x
    5. Press RIGHT
    6. A new menu entry appears (Version)
    7. Select it and select RC (0=codefree)
    Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
    no known hacks
    or you can try here.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards.
    Thank you for using FixYa.
    Mar 18, 2008 | Televison & Video
    Panasonic SC-HT670 System Logo
    267 people viewed this question
    Top Panasonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
