Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Hunter model 4415c wont turn ac on oly blinks #4
Hunter model 20754 Can I replace the 4-light fixture with a globe? If so, please direct to where I can find a globe. Thank you
look up where hunter products are sold or online catalog for different lighting set ups
Jun 24, 2018 | Hunter Dryers
I have a hunter sprinkler box for ten years, it's a 3 zone system.zone 3 stopped functioning.i changed the cellanoid. still isn't working .what do i check next?
If you have a meter you need to check the voltages at the manifold. They should be 24 Volts AC and also if the solenoid is turned into the socket to deep it wont open.
Mar 31, 2017 | Hunter Garden
Has anyone had problems with their Hunter alignment rack
Yea mine has the green light starts blinking then the rack wont do anything
Feb 13, 2013 | Hunter Dsp600 Alignment Rack/lift
Flashing 4
Reprogram it and then hold down the button that says hold until it goes back to the screen that should fix it the blinking 4 is just saying you are in the 4th programming stage of the day. Mine was blinking on 3 yesterday and when I reprogrammed it it stopped blinking
Jul 03, 2012 | Hunter Fan Company 5/1/1 Programmable...
Cp9430r
Fixed Hunter ceiling fan with remote light pin out wiring 9 wire plug search words
Hunter Ceiling Fan with remote, fails to turn on light, fails to turn on fan..remote receiver is Cp9430r
1) Test your remote, Hunter uses Radio Frequency remote, point RF remote one inch from antenna of working AM radio, press each button on remote, each button will produce static sound from AM radio, if no sound..check battery wiring or solder connection on loop antenna of remote. If no sound on one or more buttons, disassemble and wash key pad with dish soap, rinse and fan dry, retest. If still one button no work apply graphite paint to button to rebuild conductivity of button.
2) Cp9430r receiver is below fan and above light. Remove light assembly, check receiver dip switches, mine was #5 On 1~4 Off, check remote control dip switches in 9v battery compartment also set #5 On 1~4 Off, new 9v battery still no Fan reversal "click" sound heard coming from the large Blue fan reversal relay located inside the Cp9430 receiver. All other buttons control transistors and will make no sound even if they are working.
3) Disassemble / unplug 9 wire plug from Cp9430r receiver, place receiver on wooden table, 9 wire plug has two empty pin squares, one empty in the center, the other empty we will call #1 ..counting clockwise #2,#3...#4,#5..#6,#7and finally top center next to empty #1 is #8. Now #8 is 110v hot/black ...& #4 neutral/white.
4) Shock Danger..carefully apply ac volts to pins #8,#4 use tape if needed, locate quad operational amplifier i call it radio receiver chip HA17324 on board, google HA17324 Datasheet, locate leg #14 it is across from leg #1. Locate small yellow ceramic capacitor very near leg #14, use capacitor's neg as neg for voltmeter, test volts at #1,#7,#8 and #14. My #1 was 3.1v, #7 3.2v, #8 3.25v and #14 .01v ...why #14 so low? I monitored each leg while pressing remote control buttons...no changes. **Desperate, I sparked (1/2 second or less) #14 with 3.14v from positive leg of yellow capacitor** and retested all legs, no change except now #14 rests at .02v and jumps to 2.5v~2.8v when any button on the remote is pressed then rests at .02v. Now Lights work, Fan speeds work, Reverse rotation Works :-)
Pin Out on 9 wire plug, #1 Empty pin, #2 Alternates w up/down fan rotation, #3 goes to 5uf fan capacitor other side of cap goes to white/neutral AC Line, #4 AC Line neutral, #5 goes to Triac? speeds? , #6 Alternates up/down fan rotation goes to up/dn blue relay, #7 goes to up/dn blue relay looks to be AC hot looking for fan probably paired with #3 changing sides at up/dn blue relay, #8 AC Line hot in. Why did **sparking** work, smarter people might know, i think a small spark got stuck in the chip and sparking helped the chip release it out. No electrical education, novice. Jer. 51 8,9 and 11
Feb 24, 2012 | Hunter (25417) Ceiling Fan
I have a fairly new hunter ceiling fan/light. Often when we turn the light on it continuously blinks on and off. To remedy this problem we need to cycle the switch (sometimes many times). I am assuming...
on most of the hunter fans there is a watt governor in it. if problems with lights blinking, remove watt govrnor, then wire it direct without governor. governor part # 98480-02, have a good day !!
Dec 12, 2010 | Hunter (25417) Ceiling Fan
Wont turn on and wont charge plug light is blinking
Power darin the computer
1. remove the battery
2. remove the AC Adapter
3. press and hold the power button for 1 minute
4. once done plugged back in the battery and adapter
5. turn on the computer
6. if it does not work call the tech support for possible mechanical failure.
Hope it helps.
May 12, 2010 | Toshiba Satellite A20-S259 Notebook
My hunter thermostate keeps flashing a 4 and wont turn on !
hunter thermostats are not the highest quality. on the back of the thermostat there should be a not well identified reset button. You can locate and push this to attempt to fix the problem. Or purchase a new (i would suggest Robertshaw or braeburn) thermostat and install.
Dec 14, 2008 | Hunter Fan Company 5/1/1 Programmable...
Programmable Thermostat Model 43157
On my Hunter model, there is a "Span" setting that allows you to change how long the AC/Heat will run before it turns off. Basically, it sets the acceptable range (above and below) your temperature setting. To access this press both the up and down arrows and hold them. "Span" should show up with a number (1,2, or 3). For your problem, change the setting to 1 so the AC will run shorter, and more frequently to keep the temperature more constant.
Aug 29, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
208 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
