USB port is not connecting properly
I think that the USB port in the back of the drive might be damaged- when I plug into it, it is shaky, and the green power light flashes. It does not connect to my laptop. Is it fixable?
    President:
  • 392 Answers
It is just a loose contact... i think u are connecting an external hard drive .. this can be fixed by removing the chip (converter ) and replace it again.
Posted on Jun 22, 2009
  • losjims May 30, 2011
    my usb connection at the back of my external drive has no come away completely and was falling around loosely in the casing. Is it possible to connect my external HDD to my laptop using another way? - I can see some pins when I take the casing off......
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My hard drive is not visiable in system
Ok try to plug it to the USB port at the back of your CPU usually USB port at the back of the CPU supply sufficient power to the device that was plugged in that port so it functions properly cause a USB device plugged to a USB port w/ low or insufficient power supply in that device may cause the device not to work properly that's the reason why your portable HDD wasn't recognize by your system..
Jul 08, 2011 | Transcend INFORMATION : 320GB 2.5 inch...
My Iomega eGo Portable Hard drive 500 GB main light is not showing when i plug it in through the usb drive, i think this connection may be damaged. Is a way to solve it to buy dc5v to usb cable and plug it...
Have you tried connecting it with the Firewire cable that came with it? (your pc may not have the correct port) or connecting it with a different usb cable?
Has the drive been dropped? it has a protection system which shuts the drive down when it is dropped. you may need to put the HDD into a different caddy or plug it directly into a desktop pc's motherboard to retrieve you data.
I hope this helps.
Jan 21, 2011 | Iomega eGo Portable Hard drive 500 GB ...
My passport 500gb external just stopped working. It froze up so I removed it and plugged it back in. When I plugged it back into my computer it starts spinning but then makes a click sound and stops.
The clicking sound is caused by the spindle inside the hardrive, because it was not removed properly. Just connect you external hardrive to your computer, if it makes the clicking sound again dont remove it yet, just restart your computer properly. In that way all the devices connected to the computer will be refreshed and properly shut down. If it is not detected still, unplug the haardrive then try another USB port. Recommended ports are at the back of the CPU if your using a desktop. These USB ports have higher voltage output that can power up all external hardrives properly.
Jan 13, 2011 | Western Digital My Passport Essential...
L have forgotten how to use my USB to up music on it from ltunes.....when l plug it in to my computer it flashes for a few seconds and then nothing..not sure what l have to do ...l have tried finding it on...
Once you put the flash drive into the USB port, double click on the "my computer" icon. This will open up and show all available drives on your computer. The flash drive will have its' own drive letter. Once you log into i-tunes, when you go to save the file, make sure it goes to the flash drive. If your USB port is not recognizing the flash drive, try to do a system restore to a previous date. Try to go back at least 30 days (if you have created restore points on your system), then re-connect the flash drive and it should begin to install the proper drivers. If this is not your only USB port, try another one, if it is your only port, try plugging another USB device into it and see if it will recognize it.
Dec 28, 2010 | Verbatim ® Store `n` Go USB Flash Drive,...
Could not open the flash drive. i think the drivers is not loading
when you plug the usb dose the computer recognize it and gives you a pop up new device found.
if yes then right click on the my computer icon go to manage and go to diskmanagement and see the drive and its there but dosent have a drive letter on it just right click and say change or add drive letter and it will apear on the my computer .
if it dosent recognze it when you connect theneither your usb port is disabled or the flash drive have an issu
to be sure try to plug this device in other computer if it works over there then its your usb port blocked by anti virus you are using .
or the port is not working properly.
thanks
Dec 13, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My book was working properly on my PC & suddenly it is not working on my pc but when i tried connecting it to my laptop it worked properly and became recognized as my book, but still not working on my...
Try connecting it to a THIRD computer. If it works, then it's your PC that has a problem,
either software-related (Windows "plug-and-play" not working, or has been disabled,
or USB ports have been marked as "disabled") or hardware-related (USB port(s) have been
physically damaged.
Nov 04, 2010 | Western Digital My Book Essential Edition...
My front USB port do not detect nothing.so i use the back USB port of the CPU.my collegue has complained that his pendrive has been damage by the front USB port.is this true?
This is only true if the wires connecting the front USB port to the motherboard are connected incorrectly.There are 2 pairs of wires for each connector: one for the +5V & -5V (power) & the other one for the signal itself. If those are not connected properly, the power connectors could be connected to the signal, in which case if a device is connected to the port it will get damaged.
To connect those connectors properly, you have to refer back to your motherboard's manual.
Nov 16, 2009 | Intel Motherboard
My 2 usb ports on my monitor not working
In order for the two USB ports on the monitor to work, the monitor itself has to be connected to your computer via another USB cable with connectors that look like this:
The flat connector goes into an available USB port on your computer, the square one plugs into your monitor. Check if your cable is connected properly or exchange it with another one.
To eliminate that there is something wrong with your "not recognized device", plug this device into another USB port of your computer. The reason to preferably remove the device safely in Windows is that you can loose data if you just unplug it. If it is an external harddrive, it can get damaged, because you interrupt the power and the read/write head can get "stuck". So check this device on another computer or USB port.
If you have any other questions or something is not clear to you, just come back here and leave a comment and I'm happy to help.
Apr 13, 2009 | Computers & Internet
Back USB ports
I think maybe you are puting the usb connection in upside down or you are trying to put it in an iee1394(firewire) port or the LAN connector.
Nov 11, 2006 | Insignia D400a PC Desktop
Computers & Internet Logo
121 people viewed this question
Alun Cox
David Payne
David Payne
