Question about Gateway GT5220 PC Desktop
Gateway 5056 Media center doesn't boot everytime.
I push the power button it lights up. whithin the next 15 seconds, dvd & harddrive light flashes in unison normally, if you place a cd in it seems to be trying to read it. After that just sets there untill you hold the power button untill it shuts down. No beeps, no video to monitor, the CPU fan running at top speed. I can push the power button again maybe once, twice,three or it could be 10's of times before it boots up and runs perfectly. Even when I installed software that auto reboots it runs smoothly thru the restart perfectly. I do know when it's going to boot, within that first 15 seconds if the CPU fan drops substantal rpms then the harddrive boots and were good to go again.
  • 331 Answers
Did you look on gateways website for a bios update. the firmware on your motherboard maybe corrupt. go here and check since I dont have your serial number... gateway has a java based scanner that might be able to repair it for you
http://support.gateway.com/support/drivers/dlcenter.asp
please rank me if you can
Posted on Jun 22, 2009
I have a Gateway all in one model zx4931. When power button is pushed the blue light does not come on. The vanity light comes on & off as if its booting & shutting down. I have a green light at the...
Sounds exactly like a failing power supply. Hopefully you bought an extended warranty when you purchased the computer. You should look into having the PSU replaced.
Jun 02, 2014 | Gateway One Hd Zx4931 21.5" All In One...
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
Have Gateway M6866 Laptop. Will not boot. when power button is pressed. you hear a fan start power light comes on, harddrive light and a few others comes on for 2 seconds then goes off. screen is always...
If it never posts anything to the screen then more than likely you've got a video card issue. It could be the memory also.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 24, 2012 | Gateway Computers & Internet
I have a gateway model # gm5088. I power on the computer and work fine, but the blue light doesnt work and the pc doesn't want to boot. What seems to be the problem?
sorry i could not understand u said it work fine but the pc doesnt want to boot. if its only the light issue then the connection of that light to the motherboard must be lossed or the bulb must have been fused
and if ur pc not booting then it ur power supply on *********** board problem
good day
May 29, 2010 | Gateway GM5088 PC Desktop
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
How do I setup the homelink feature in my 2000 chevy impala with my garage opener?
First clear it pushing the 2 outer buttons for about 20 seconds till the lite blinks.
Then here is the weird part take the old remote that you use for your garage door opener and hold it next to the home link in the car.
Push the button on your old remote then the button on the home link. the home link will flash slow then quickly (about 10 sec).
Now go push the learn button on the main door unit then back to the car and push the home link again for 2 seconds.
Oct 22, 2009 | Chevrolet Impala Cars & Trucks
GT5034 has power, blue light on power button, no beep, no boot, sounds like fan running hard. Hard drive light is on for a while and both CD drives green lights flicker. Nothing comes up on the monitor. HD...
powersource is good.motherboard might be the problem.harddrive can be tested by putting it in
another computer and see if it boot up.to test the mother board unhook the cd drives and harddrive.turn
on the computer and see if the gateway logo comes on.if it still does the the samething with everything unhooked
then it might be the bios.you might have to flash the bios and reinstall it.to do this i recommend you take it to a
shop.if the comp runs with everything still unpluged and stops then you know that you have a wrong
setting on the harddrive or cd drive.if you got two of anything make sure that you have a slave or master.if you nned me to
write a guide email me at gamecrazy944@yahoo.com or if you got anymore questions.
Jun 29, 2009 | Gateway GT5034 PC Desktop
Gateway 200arc motherboard problem
If there are two wires running from the power button on your case to the motherboard, take them off and try jumpering those two terminals with a jumper or something that will make contact for just a second and them take back off. Your power button may have fried along with the power supply.
May 18, 2009 | Gateway Refurbished $30 P1 TO USA - BOARD...
Boot everytime
POBLEM WITH THE MOTHERBOARD...SORRY...
IF IT IS WITHIN WARRANTY TRY GET IT DONE THRU VENDOR IT WILL SAVE MONEY
May 22, 2008 | HP Compaq nx6125 Notebook
Gateway GT5220 PC Desktop Logo
277 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
